Hi Again Anil
Thank you for coming back to me.
- I have already mentioned that I cannot run the automated Fix It. I get a message stating "Scripted Diagnostics Native Host has encountered a user-defined break point" It then tells me that Scripted Diagnostics Host has stopped working"
Do you have a solution to this problem? This was an error I received previously before I re-installed windows and it has recurred. I had little involvement with the loading of the OS certainly I was not asked to add any break points. Refer to my original post for more information.
- I previously ran the readiness tool prior to re-installing and it did nothing to solve the problem. I ran it yesterday before posting this request for help. It did complete and told me what would and would not run under Windows 8. Sadly it did not cure the updating problem.
- I used the SFC command as an administrator (and also signed on as the hidden administrator) before re-installing W Pro 64 and it did say some files were corrupt. It appears it often says this. As soon as the installation was complete I ran SFC /scannow out of curiosity. this time it again stated some files were corrupt so figured that this was a standard response. I have just run it again and it reports corrupt files, some of which it cannot repair. If I can get access to the CBS log I will post it below. No I will have to try and access as the hidden administrator as I am denied access.
No doing very well are we? What do you suggest now?
