Microsoft Fix It encountered an unexpected problem and cannot continue.
2014-06-18T11:21:06+00:00
I was having trouble with updates. So much so that I was tired of the crashes, hangs, restarts, etc. I re-formatted my drive and reinstalled Windows 7 Professional SP1 64 from my disk. Re-installed all the drivers, programmes, registered with Microsoft and got authenticated. Whoopee! Still wont update. So I decided to run the Fix It but no. Apparently it encounters a user induced break point. During the installation I did not amend or adjust any settings and therefore am innocent I tell you! Ahem, I have searched Microsoft and the internet for a solution but nothing appears to work. Anyone know of a Fix It to Fix a Fix it?  When I run updates (which is why I sought help in the first place) I get error 800B0100 which does not help very much at all. Can't say I am that impressed with Microsoft at the moment but maybe someone there will be able to put that right. I pasted a screen shot of the error below but I bet its not here once I submit.
    2014-07-06T09:29:19+00:00
    Nigel
    Please provide an updated copy of your System Information file. Type System Information in the Search Box above the start Button and press the ENTER key (alternative is Select Start, All Programs, Accessories, System Tools, System Information). Select File, Export and give the file a name noting where it is located. Do not place the cursor within the body of the report before exporting the file. The system creates a new System Information file each time system information is accessed. You need to allow a minute or two for the file to be fully populated before exporting a copy. Please upload to your OneDrive (formerly Sky Drive), share with everyone and post a link here. Reports in normal mode preferred. Please say if the report has been obtained in safe mode.
    Please upload and share with everyone fresh copies of your System and Application logs from your Event Viewer to your One Drive (formerly Sky Drive) and post a link here. You can remove the earlier copies of the logs from your OneDrive.
    To access the System log select Start, Control Panel, Administrative Tools, Event Viewer, from the list in the left side of the window expand Windows Logs and select System. Place the cursor on System, select Action from the Menu and Save All Events as (the default evtx file type) and give the file a name. Do the same for the Applications log. Do not provide filtered files. Do not clear logs whilst you have a continuing problem.
    2014-07-06T10:31:12+00:00
    Hi Gerry,
    You are missing all the excitement. I still get the 0x800B100 error but! I decided to give SFC one more run and it reported that it couldn't run because there was a repair update pending. I restarted and low and behold I was presented with the updating screen. 96/149 in actual fact. The hard drive was taking a right pounding so I left things alone. After about 20 minutes the waiting was becoming tedious. So after 30 minutes I pressed and held my on button. On restarting I was advised to wait as updates were being configured. After several minutes I was advised that the configuration had failed and the system was reverting.
    So is that progress? Are we half way there (as that old joke goes). Is there hope? Do fairies live at the bottom of gardens?
    2014-07-06T10:40:29+00:00
    Hi Gerry
    I have to be quick as Windows has scheduled a restart following an update. Here I the link. http://1drv.ms/1vN1efd
    Nige bugger....
    2014-07-06T15:54:27+00:00
    Nigel
    Your uploads proved interesting.
    Select Start, All Programs, Windows Update, Change Settings. Under Important Updates is a box showing the current setting. Click on the Arrow down to the right and change the selection to “Check for Updates but let me choose whether to download and install them” and click on OK. Restart your computer three times to clear pending updates.
    I suggest you run the Microsoft Genuine Advantage Diagnostics Tool in normal mode and copy and paste the results in a reply for further analysis:
    http://go.microsoft.com/fwlink/?linkid=52012
    Run the Tool and when it completes click the Copy button, open a text file like Word or Notepad and select Edit, Paste. You can paste directly into a reply here. Open a reply, right click and select Paste.
    2014-07-07T08:56:07+00:00
    Hi Gerry
    Here is the diagnosric report.
    Diagnostic Report (1.9.0027.0):
    Windows Validation Data-->
    Validation Code: 0
    Cached Online Validation Code: 0x0
    Windows Product Key: *****-*****-CB373-Q9PBD-JJHQG
    Windows Product Key Hash: E1ExUpA2YooojXoA1uy5ztNfCy0=
    Windows Product ID: 00371-OEM-9317035-11855
    Windows Product ID Type: 8
    Windows License Type: COA SLP
    Windows OS version: 6.1.7601.2.00010100.1.0.048
    Is Admin: Yes
    TestCab: 0x0
    LegitcheckControl ActiveX: N/A, hr = 0x80070002
    Signed By: N/A, hr = 0x80070002
    Product Name: Windows 7 Professional
    Architecture: 0x00000009
    Build lab: 7601.win7sp1_gdr.130828-1532
    TTS Error:
    Validation Diagnostic:
    Resolution Status: N/A
    Vista WgaER Data-->
    ThreatID(s): N/A, hr = 0x80070002
    Version: N/A, hr = 0x80070002
    Windows XP Notifications Data-->
    Cached Result: N/A, hr = 0x80070002
    File Exists: No
    WgaTray.exe Signed By: N/A, hr = 0x80070002
    WgaLogon.dll Signed By: N/A, hr = 0x80070002
    OGA Notifications Data-->
    OGAExec.exe Signed By: N/A, hr = 0x80070002
    OGAAddin.dll Signed By: N/A, hr = 0x80070002
    OGA Data-->
    Office Status: 109 N/A
    OGA Version: N/A, 0x80070002
    Office Diagnostics: 025D1FF3-364-80041010_025D1FF3-229-80041010_025D1FF3-230-1_025D1FF3-517-80040154_025D1FF3-237-80040154_025D1FF3-238-2_025D1FF3-244-80070002_025D1FF3-258-3
    Browser Data-->
    Proxy settings: N/A
    User Agent: Mozilla/4.0 (compatible; MSIE 8.0; Win32)
    Default Browser: C:\Program Files\Internet Explorer\iexplore.exe
    Download signed ActiveX controls: Prompt
    Download unsigned ActiveX controls: Disabled
    Run ActiveX controls and plug-ins: Allowed
    Initialize and script ActiveX controls not marked as safe: Disabled
    Allow scripting of Internet Explorer Webbrowser control: Disabled
    Active scripting: Allowed
    Script ActiveX controls marked as safe for scripting: Allowed
    File Scan Data-->
    File Mismatch: C:\Windows\system32\wat\watadminsvc.exe[Hr = 0x80070003]
    File Mismatch: C:\Windows\system32\wat\npwatweb.dll[Hr = 0x80070003]
    File Mismatch: C:\Windows\system32\wat\watux.exe[Hr = 0x80070003]
    File Mismatch: C:\Windows\system32\wat\watweb.dll[Hr = 0x80070003]
    Other data-->
    Office Details: <GenuineResults><MachineData><UGUID>{930A6ECC-629B-4A95-8499-D66C627DD0F9}</UGUID><Version>1.9.0027.0</Version><OS>6.1.7601.2.00010100.1.0.048</OS><Architecture>x64</Architecture><PKey>*****-*****-*****-*****-JJHQG</PKey><PID>00371-OEM-9317035-11855</PID><PIDType>8</PIDType><SID>S-1-5-21-1586545971-2169922943-2575928213</SID><SYSTEM><Manufacturer>Gigabyte Technology Co., Ltd.</Manufacturer><Model>GA-78LMT-USB3</Model></SYSTEM><BIOS><Manufacturer>Award Software International, Inc.</Manufacturer><Version>F4</Version><SMBIOSVersion major="2" minor="4"/><Date>20121019000000.000000+000</Date></BIOS><HWID>7B5A3907018400FC</HWID><UserLCID>0809</UserLCID><SystemLCID>0409</SystemLCID><TimeZone>GMT Standard Time(GMT+00:00)</TimeZone><iJoin>0</iJoin><SBID><stat>3</stat><msppid></msppid><name></name><model></model></SBID><OEM/><GANotification/></MachineData><Software><Office><Result>109</Result><Products/><Applications/></Office></Software></GenuineResults>
    Spsys.log Content: 0x80070002
    Licensing Data-->
    Software licensing service version: 6.1.7601.17514
    Name: Windows(R) 7, Professional edition
    Description: Windows Operating System - Windows(R) 7, OEM_COA_SLP channel
    Activation ID: da22eadd-46dc-4056-a287-f5041c852470
    Application ID: 55c92734-d682-4d71-983e-d6ec3f16059f
    Extended PID: 00371-00186-170-311855-02-2057-7601.0000-1752014
    Installation ID: 003612390423674313194345320102863382688035870392553832
    Processor Certificate URL: http://go.microsoft.com/fwlink/?LinkID=88338
    Machine Certificate URL: http://go.microsoft.com/fwlink/?LinkID=88339
    Use License URL: http://go.microsoft.com/fwlink/?LinkID=88341
    Product Key Certificate URL: http://go.microsoft.com/fwlink/?LinkID=88340
    Partial Product Key: JJHQG
    License Status: Licensed
    Remaining Windows rearm count: 3
    Trusted time: 07/07/2014 09:54:30
    Windows Activation Technologies-->
    HrOffline: 0x00000000
    HrOnline: N/A
    HealthStatus: 0x0000000000000000
    Event Time Stamp: N/A
    ActiveX: Not Registered - 0x80040154
    Admin Service: Not Registered - 0x80040154
    HealthStatus Bitmask Output:
    HWID Data-->
    HWID Hash Current: OAAAAAEABAABAAEAAAADAAAAAwABAAEAln00Upa94KgYiBAzVPIYzq7A6kX0ASeU1q+YawADFA8=
    OEM Activation 1.0 Data-->
    N/A
    OEM Activation 2.0 Data-->
    BIOS valid for OA 2.0: yes, but no SLIC table
    Windows marker version: N/A
    OEMID and OEMTableID Consistent: N/A
    BIOS Information:
      ACPI Table Name OEMID Value OEMTableID Value
      APIC   GBT     GBTUACPI
      FACP   GBT     GBTUACPI
      HPET   GBT     GBTUACPI
      MCFG   GBT     GBTUACPI
      MSDM   GBT     GBTUACPI
      SSDT   AMD     POWERNOW
