nVidia graphic card does not show up in device manager, unable to update drivers
2014-04-21T16:41:34+00:00
Original Title: NVidia graphic card disappeared
Before three weeks ago, I connected my two laptops via network sharing (but it didn't work) . After that my laptop (ASUS X52J with nVidia GeForce 310M) did not respond, it restarted. But with some errors. After that my laptop didn't detect nVidia card (detected only Intel graphic card). I uninstalled my drivers and tried to installed. But it occurred error..
"This graphic driver could not find compatible graphic hardware"
And Device manager also didn't detect the nVidia adapter..what should i do now..Please Help
    2015-02-13T07:26:49+00:00
    hi
    i received a zotac 780 oc 3 gb . my motherboard is gigabyte z68xp-UD4 . i installed the graphic card and try to install the driver. but graphic driver setup shows that " graphic driver could not find compatible graphics hardware. i have plugged the HDMI cable in graphic card and its working fine. device manager also not showing the graphics hardware other than inbuilt intel video chip**.**please help. i tried above methods but doesnt work with it . please tell me how uninstall updated bios too in specified motherboard.
    2015-02-18T15:47:59+00:00
    Thank you for keeping us updated on the issue and apologies for late response.
    You may try Windows Compatibility Mode to use an old program with new Windows.
    Kindly refer to: **Make older programs compatible with this version of Windows**
    In order to uninstall the BIOS update and bring it factory settings, I would recommend contacting the computer manufacturer for the best support.
    IMPORTANT: Modifying BIOS/ complementary metal oxide semiconductor (CMOS) settings incorrectly can cause serious problems that may prevent your computer from booting properly. Microsoft cannot guarantee that any problems resulting from the configuring of BIOS/CMOS settings can be solved. Modifications of the settings are at your own risk.
    Hope this information is helpful. Do feel free to write to us in case if you have further questions related to Windows. We'll be happy to answer.
    2015-06-02T13:29:43+00:00
    It is not detcting my nvidia drivers in my laptop acer v3 571g has not showed in my device manager
    2015-06-03T09:23:20+00:00
    Hi Karanam,
    Thank you for the update.
    I would recommend updating drivers from the Acer Support website and check.
    2015-07-04T09:25:38+00:00
    Thank you guys for this help method 1 really helped me. Any problems u can ask me too thank you all!!
