Consumer Cellular APN MMS settings not working after WP 8.1 Update
2014-08-21T21:32:18+00:00
My folks' two Lumia 520s on Consumer Cellular (an AT&T MNVO) took the 8.1 upgrade without issue a couple weeks back, however they now can't receive MMS messages (a photo attached to a text message for example) anymore, the settings we used successfully previously were:
Navigate to: Settings / cellular + SIM (add Internet APN and MMS APN if not present)
Edit Internet APN:
APN= att.mvno
Edit MMS APN:
APN= att.mvno
WAP gateway= proxy.mvno.ccmobileweb.com
WAP port= 80
MMSC= http://mmsc.cingular.com
MMSC port= 80
Maximum MMS size= 10485
Has anyone successfully gotten this to work post WP 8.1 upgrade?  Currently it indicates that there is media attached to the message but will not download it when clicked.  Thanks -
2015-01-03T13:15:28+00:00
I upgraded my folks' 520s to 635s this Christmas still on Consumer Cellular and had to enable their APN settings, was able to just use the same SIM card.
The 635s come with 8.1.  These settings worked, note that to get MMS images and videos to come through I had to choose IP type as IPv4 *only*:
Edit Internet APN:
APN= att.mvno
Edit MMS APN:
APN= att.mvno
WAP port= 80
MMSC port= 80
IP Type= IPV4
Good luck.
Thank you thank you for posting this!!!  My husband and I just bought a pair of 635's and instantly fell in love with the format and capabilities of the phone.  We went through the 2 hour long phone call to consumer cellular with absolutely no luck (the operator ended the call with "well you must just have a phone that can't send pictures on our network").  I am so glad that I read through the message boards and found this.
The above settings work people!!!  The line that was throwing a wrench in it for me was the IP Type.  After 8.1 the default setting is IPV4V6.  After changing this to IPV4 I was able to successfully send and receive picture messages.  Thank you johnhardyiv, thank you!  I will be calling consumer cellular to inform them of the fix so they can update their "troubleshooting" software and hopefully pass this information on to others who are having this issue.
You are a life saver!
56 additional answers
    2015-02-21T17:02:53+00:00
    I have a similar problem as well, except we are  using Consumer Cellular and a Win HD 501u Phone by Blu and sold by Microsoft with windows 8,1.
    I used the exact settings as above (since consumer cellular uses ATT network) and have virtually no luck in being able to send a picture attached to a message.  I have three (3) of these phones just recently purchased and have had success with one phone working for both send and receive over a 4 hour period and then suddenly unable to send or receive any pictures associated with messaging since.  I have made sure WIFI was turned off during all these processes.  Consumer Cellular keeps saying it's a windows problem.  So far I have spent over 30 hours attempting to get this working using various settings.  It would be great if someone with access to the programs would at least compare these issues and correct the protocol to fix it, whether it be the cell phone carriers or Microsoft configuration issues.  I just don't now where to access these departments that may have a little intelligence to track out these issues.
    Yes Frustrated.!
    2015-02-22T04:29:55+00:00
    Did you try sending a pic from a phone to itself?
    2015-02-22T05:43:25+00:00
    Yes, made sure the picture was also less than 1 meg in the event size was an issue. I have also completely reset the phone back to original factory specs and then retried and verified Wi-Fi was off as well.  No luck.
    2015-02-24T14:54:30+00:00
    Edit Internet APN:
    APN= att.mvno
    Edit MMS APN:
    APN= att.mvno
    WAP port= 80
    MMSC port= 80
    Had a similar problem as was noted in this thread:  Using a BLU WIN HD 510u pone. Consumer cellular finally got back to me after an email I sent.  Someone was gracious enough to evaluate the issue and got every thing in sync.  Settings as follows:  based on LTE windows phones ( They updated the account to LTE network)
    APN: ccdata
    User Name: blank
    Password: blank
    Proxy Server: Leave blank
    Proxy Port: Leave Blank
    MMS APN settings:
    APN: ccdata
    WAP Gateway URL: proxy.mobile.att.net
    WAP Gateway Port: 80
    MMSC URL: http://mmsc.mobile.att.net
    MMSC Port: 80
    Save this APN information and make sure it is the active APN in the phone; turn on data roaming, turn off WiFi; Power off the phone and bring back up (make sure it is connecting to the right configuration) open up a browser to connect to any webpage or do a quick search to see if the phone is connecting properly. Don't forget to turn WiFi back on!
    These settings worked like a charm on My Blu Win HD 510u Phones.  Note: I also left the network settings on automatic, and the IP address on IPV4V6  maximum size is also left blank.  Consumer Cellular 800.686.4460
