Consumer Cellular APN MMS settings not working after WP 8.1 Update
2014-08-21T21:32:18+00:00
My folks' two Lumia 520s on Consumer Cellular (an AT&T MNVO) took the 8.1 upgrade without issue a couple weeks back, however they now can't receive MMS messages (a photo attached to a text message for example) anymore, the settings we used successfully previously were:
Navigate to: Settings / cellular + SIM (add Internet APN and MMS APN if not present)
Edit Internet APN:
APN= att.mvno
Edit MMS APN:
APN= att.mvno
WAP gateway= proxy.mvno.ccmobileweb.com
WAP port= 80
MMSC= http://mmsc.cingular.com
MMSC port= 80
Maximum MMS size= 10485
Has anyone successfully gotten this to work post WP 8.1 upgrade?  Currently it indicates that there is media attached to the message but will not download it when clicked.  Thanks -
2015-01-03T13:15:28+00:00
I upgraded my folks' 520s to 635s this Christmas still on Consumer Cellular and had to enable their APN settings, was able to just use the same SIM card.
The 635s come with 8.1.  These settings worked, note that to get MMS images and videos to come through I had to choose IP type as IPv4 *only*:
Edit Internet APN:
APN= att.mvno
Edit MMS APN:
APN= att.mvno
WAP port= 80
MMSC port= 80
IP Type= IPV4
Good luck.
Thank you thank you for posting this!!!  My husband and I just bought a pair of 635's and instantly fell in love with the format and capabilities of the phone.  We went through the 2 hour long phone call to consumer cellular with absolutely no luck (the operator ended the call with "well you must just have a phone that can't send pictures on our network").  I am so glad that I read through the message boards and found this.
The above settings work people!!!  The line that was throwing a wrench in it for me was the IP Type.  After 8.1 the default setting is IPV4V6.  After changing this to IPV4 I was able to successfully send and receive picture messages.  Thank you johnhardyiv, thank you!  I will be calling consumer cellular to inform them of the fix so they can update their "troubleshooting" software and hopefully pass this information on to others who are having this issue.
You are a life saver!
56 additional answers
    2015-01-04T03:50:35+00:00
    I don't have their phones in front of me any more, I don't recall having to enter anything for the SIM name at all.  Are you actually on Consumer Cellular's network, do you have bars at this point?  I experienced some issues w/ signal strength having to be above a certain floor to get MMS messages the first time I tried this on their 520s.
    Are you using Lumia 635s?
    2015-01-04T04:16:29+00:00
    I am on the Lumia 635 windows 8.1 ( Just got it and installed the micro sim )  Everything works fine except the MMS or image texting. I have poor data coverage at home at all times, use WIFI  most of the time, right now I have 1 bar.
    2015-01-04T07:12:58+00:00
    I would have someone send an MMS message when you have a stronger signal and see if that impacts it; to confirm it's at least working out and about.
    Also I think you have to actively toggle that feature on in your Consumer Cellular plan, make sure they have it on.
    Do you receive a message that you've got media content in the message and then when you click it it never gets it? Or do you even get the message?
    Some T-Mobile people were saying they had a damaged sim that prevented this on a 521.  Perhaps search for 'MMS signal lumia' or similar.
    2015-01-04T22:29:45+00:00
    First, eliminate the lack of strong signal as a cause.
    Second, these settings are now working on a Nokia 920 and 520 with Consumer Cellular:
    Edit Internet APN:
    APN= att.mvno
    user  name= EMPTY
    password= EMPTY
    proxy server url= proxy.mvno.ccmobileweb.com
    proxy port= 80
    ip type= IPv4
    Edit MMS APN:
    APN= att.mvno
    user  name= EMPTY
    password= EMPTY
    WAP port= 80
    MMSC url= http://mmsc.cingular.com
    MMSC port= 80
    Maximum MMS size= 99999
    IP Type= IPV4
    A comment on this second step, the 520 is at version 8.0.0517.150 as delivered and works, the 920 was at 8.0.????.???? and worked.  The 920 got updated in early September and stopped working.  Another 920 was updated at the same time and not only did stop working, but the camera stopped working.  The first 920 mentioned, had everything tried with no success on the MMS problem.  Not until the OS was redone using the Nokia Software Recovery Tool, did the MMS function return to operational.  The second 920, we did manage to get the MMS working, but the camera still didn't work.  That unit was returned to Nokia for repair.  Still waiting on that.
    While the second 920 is out for repair, I ordered 6 520's for my business.  They all came with 8.0, but apparently there are "different" released versions of 8.0 out there.  I have new 520's that report different version numbers, some are at 8.0.0517.150 others are at 8.0.10327.77.  These all work at the above settings.
    So, thirdly, what does this mean?  Not all 8.0's are the same - they have slightly different behaviors.  This is provable.  Not all 8.1 upgrades are the same, I can prove this also.
    Conclusion:  If when you can eliminate the poor signal issue and you have again verified the settings, I would strongly recommend either sending the phone in for "repair" (it sounds like they are recent purchases and Nokia has a 1 year warranty (I believe)) or do the previously mention Nokia Software Recovery Tool OS redo.
    IMHO, Microsoft has a severe issue in the handling and deploying of updates.
    That is my 2 cents.
