Volume taskbar icon vanished / greyed-out in Control Panel
2014-04-20T14:08:38+00:00
Since installing the latest major 8.1 update, my Volume Notification Area icon has disappeared. (It returned briefly but the default seems for it to inexplicably go away again to not return).
It still shows up as active when I go to Control Panel > All Control Panel Items > Notification Area Icons
But toggling this a bubble appears saying "This notification icon is not currently active"
Going then into "Turn system icons on or off", the Volume System Icon is turned off, and greyed-out for access.
Why would this happen?
I see old threads for this happening in Win7, and I'm wary of downloading a registry fix in case my 8.1 computer blows up.
2015-02-19T14:07:54+00:00
  1. Hit Ctrl-Alt-Delete and open Task Manager
  2. Click on DETAILS tab
  3. Find explorer.exe, right-click, and click on END TASK
  4. On the top Menu Bar, click on FILE, RUN NEW TASK
  5. Enter explorer.exe in the task entry box and click on OK
  6. On the top Menu Bar, click on VIEW and REFRESH NOW
  7. Volume icon should reappear after refresh
2014-05-06T16:56:20+00:00
I checked and my drivers are up to date.
The problem actually fixed itself as suddenly as it started... no idea what that was about.
70 additional answers
    2015-02-23T19:30:30+00:00
    Make sure you went into File -> Run New Task and opened explorer.exe back up, did the job for me
    Thanks Keiki
    Alternatively you can just manually search for "Volume" and use the mixer instead.
    (Can't believe this is still happening. A proper KB fix for Win8.1 would be nice...)
    2015-02-24T03:16:50+00:00
    You're welcome, Elias and AShewan :-)
    2015-03-12T17:06:27+00:00
    I've been trying to find a solution for the last few weeks now and Keiki's worked.
    Thank-you so muck Keiki!
