Volume taskbar icon vanished / greyed-out in Control Panel
2014-04-20T14:08:38+00:00
Since installing the latest major 8.1 update, my Volume Notification Area icon has disappeared. (It returned briefly but the default seems for it to inexplicably go away again to not return).
It still shows up as active when I go to Control Panel > All Control Panel Items > Notification Area Icons
But toggling this a bubble appears saying "This notification icon is not currently active"
Going then into "Turn system icons on or off", the Volume System Icon is turned off, and greyed-out for access.
Why would this happen?
I see old threads for this happening in Win7, and I'm wary of downloading a registry fix in case my 8.1 computer blows up.
2015-02-19T14:07:54+00:00
  1. Hit Ctrl-Alt-Delete and open Task Manager
  2. Click on DETAILS tab
  3. Find explorer.exe, right-click, and click on END TASK
  4. On the top Menu Bar, click on FILE, RUN NEW TASK
  5. Enter explorer.exe in the task entry box and click on OK
  6. On the top Menu Bar, click on VIEW and REFRESH NOW
  7. Volume icon should reappear after refresh
2014-05-06T16:56:20+00:00
I checked and my drivers are up to date.
The problem actually fixed itself as suddenly as it started... no idea what that was about.
70 additional answers
    2016-04-02T19:27:21+00:00
    TY so much for these instructions. I tried all kinds of solutions in my W 10 laptop and this is the only one that worked!
    2016-05-05T18:32:35+00:00
    Thanks! It worked - most helpful! :-)
    2016-05-07T03:20:24+00:00
    Everyone who's found my post helpful is very welcome! I'm glad it works for you :-)
