BackgroundContainer.dll module not found
2013-10-17T17:54:09+00:00
When my computer starts up, I get the following error message:
c:\Users\Owner\AppData\Local\Conduit\BackgroundContainer\BackgroundContainer.dll
Specific module not found
Anyone have any idea what this is?
2013-10-29T14:35:58+00:00
We’ve already identified the problem – it’s a scheduled task named “BackgroundContainer” that’s attempting to run the BackgroundContainer.dll malware file, which has already been removed. The fact that the “startup item” for the malware’s dll file is a scheduled task is actually “good news”, because it means that you don’t have to edit your registry, or use Autoruns, or uninstall/reinstall any program in order to remove the error message – all you have to do is delete the BackgroundContainer scheduled task. I originally used a link for the removal procedure because that’s where you’ll also find the “authorization” and testimonials for the procedure. So here’s the proof that this procedure will work:
http://answers.microsoft.com/en-us/protect/forum/protect\_other-protect\_scanning/error-message-on-start-up-windows-8/7f29c7ad-2d55-4f1c-8110-ddca3902f596
And, for the benefit of those who maybe just don’t understand what’s going on in that thread, here’s the procedure for removing the BackgroundContainer scheduled task:
Press the Windows key + R
Type “taskschd.msc”
Press the Enter key
Click on the Task Scheduler Library folder
Right-click on the BackgroundContainer task
Select "Delete”
Here’s a good removal guide that you can follow up with to make sure that all traces of the malware are removed:
http://malwaretips.com/blogs/conduit-search-removal/
And here’s the main thread for this issue in the Virus and Malware Forum:
http://answers.microsoft.com/en-us/protect/forum/protect\_scanner-protect\_scanning/run-dll-error-messagebackground-containerdll/49612202-667e-4a71-8e9a-d02161d8bc19
GreginMich
49 additional answers
    2014-02-17T17:13:32+00:00
    thanks..
    2014-03-16T05:52:54+00:00
    Thanks Greg for posting so many helpful options. Your simple, step-by-step was easy enough, done in seconds!  :)
    2014-10-17T21:54:10+00:00
    I have the same problem and have tried the procedure you give but when I look for the background container in the task scheduler library folder, it is not listed so I can not delete it. any other suggestions?
    2014-10-18T03:48:02+00:00
    The only other suggestion I have is the one that you'll find at the top of this page: If you can’t find the task, then use Autoruns to find and remove the BackgroundContainer.dll “startup entry”. Use the File > Find option as per the instructions of quietman7 MS MVP:
    GreginMich
