BackgroundContainer.dll module not found
2013-10-17T17:54:09+00:00
When my computer starts up, I get the following error message:
c:\Users\Owner\AppData\Local\Conduit\BackgroundContainer\BackgroundContainer.dll
Specific module not found
Anyone have any idea what this is?
2013-10-29T14:35:58+00:00
We’ve already identified the problem – it’s a scheduled task named “BackgroundContainer” that’s attempting to run the BackgroundContainer.dll malware file, which has already been removed. The fact that the “startup item” for the malware’s dll file is a scheduled task is actually “good news”, because it means that you don’t have to edit your registry, or use Autoruns, or uninstall/reinstall any program in order to remove the error message – all you have to do is delete the BackgroundContainer scheduled task. I originally used a link for the removal procedure because that’s where you’ll also find the “authorization” and testimonials for the procedure. So here’s the proof that this procedure will work:
http://answers.microsoft.com/en-us/protect/forum/protect\_other-protect\_scanning/error-message-on-start-up-windows-8/7f29c7ad-2d55-4f1c-8110-ddca3902f596
And, for the benefit of those who maybe just don’t understand what’s going on in that thread, here’s the procedure for removing the BackgroundContainer scheduled task:
Press the Windows key + R
Type “taskschd.msc”
Press the Enter key
Click on the Task Scheduler Library folder
Right-click on the BackgroundContainer task
Select "Delete”
Here’s a good removal guide that you can follow up with to make sure that all traces of the malware are removed:
http://malwaretips.com/blogs/conduit-search-removal/
And here’s the main thread for this issue in the Virus and Malware Forum:
http://answers.microsoft.com/en-us/protect/forum/protect\_scanner-protect\_scanning/run-dll-error-messagebackground-containerdll/49612202-667e-4a71-8e9a-d02161d8bc19
GreginMich
49 additional answers
    2013-12-19T03:49:23+00:00
    I was looking at all the different answers regarding that darn question:
    I managed to get that error message whenever I logged on to my laptop with Windows 7.  I had downloaded Adobe AIR, hoping to be able to get access to Photo Shop - I think it is called.  Next thing I knew, I logged on to my laptop, and from then on - this dang error message came up.  I am a senior citizen and cancer survivor, and I don't have the money to take my laptop to someone to "fix" it for me.
    I found your answers and they were simple for someone like me to understand.  The chemotherapy has affected my memory and it is almost like now I have a learning disability.
    Your answer where you replied to someone on October 29, 2013, worked for me! And I have Windows 7.  I was willing to try almost anything, but I needed to find an answer that was pretty simple, and yours was.  I was stunned.  I don't get that darn (that is a mild word I use!!!) error message anymore, and I am just beside myself with excitement!!!!!
    My Gratitude and thanks to you for making your answer to these people that were having the same problem I was - for making it simple and easy to understand.  It sure worked for me!
    Many thanks.
    Enie
    cancer survivor
    2013-12-24T19:50:28+00:00
    Man, you rocked this question, Bill.  You gave us an Excellent clear and correct answer.  Thanks so much for helping us on this obscure nuisance. BTW people, I go this Conduit malware when I D/L MSI Afterburner from the Cnet web portal.  Cnet has great information but I will never use their site to D/L any software from now on.
    2014-01-01T08:32:45+00:00
    Right on time and I have windows 8.1 enterprise and just used what you suggested, I am glad that it was not a serious problem and more of a fail safe that could be remedied as easy as a delete Thanks again.
    PS. for some reason I come to this forum last instead of 1st. and I apologize for that because this is a very good support group that you guys have put together, hopefully I can offer some relevant suggestions one day.
    2014-01-25T17:23:50+00:00
    Thanks very helpful.
