BackgroundContainer.dll module not found
2013-10-17T17:54:09+00:00
When my computer starts up, I get the following error message:
c:\Users\Owner\AppData\Local\Conduit\BackgroundContainer\BackgroundContainer.dll
Specific module not found
Anyone have any idea what this is?
2013-10-29T14:35:58+00:00
We’ve already identified the problem – it’s a scheduled task named “BackgroundContainer” that’s attempting to run the BackgroundContainer.dll malware file, which has already been removed. The fact that the “startup item” for the malware’s dll file is a scheduled task is actually “good news”, because it means that you don’t have to edit your registry, or use Autoruns, or uninstall/reinstall any program in order to remove the error message – all you have to do is delete the BackgroundContainer scheduled task. I originally used a link for the removal procedure because that’s where you’ll also find the “authorization” and testimonials for the procedure. So here’s the proof that this procedure will work:
http://answers.microsoft.com/en-us/protect/forum/protect\_other-protect\_scanning/error-message-on-start-up-windows-8/7f29c7ad-2d55-4f1c-8110-ddca3902f596
And, for the benefit of those who maybe just don’t understand what’s going on in that thread, here’s the procedure for removing the BackgroundContainer scheduled task:
Press the Windows key + R
Type “taskschd.msc”
Press the Enter key
Click on the Task Scheduler Library folder
Right-click on the BackgroundContainer task
Select "Delete”
Here’s a good removal guide that you can follow up with to make sure that all traces of the malware are removed:
http://malwaretips.com/blogs/conduit-search-removal/
And here’s the main thread for this issue in the Virus and Malware Forum:
http://answers.microsoft.com/en-us/protect/forum/protect\_scanner-protect\_scanning/run-dll-error-messagebackground-containerdll/49612202-667e-4a71-8e9a-d02161d8bc19
GreginMich
49 additional answers
    2013-12-02T16:38:32+00:00
    You can also use this free Program to do that, too:
    "Autoruns for Windows v11.32"
    http://technet.microsoft.com/en-us/sysinternals/bb963902.aspx
    Cheers.
    Autoruns is now a prized addition to my toolbox. Thank you ever so much for your help. I solved this problem and found three other programs that led to "file not found" errors, what a great tool!
    Thanks again and God Bless you, Rotten Ron.
    2013-12-03T20:09:50+00:00
    Thanks GreginMich for your help.  It appears that your short version solution solved my problem.  Thanks . . . A. Buffington - Texas
    2013-12-15T00:32:12+00:00
    First thanks a bunch for the fix.
    Next this was a remnant of connect toolbar dlc2 that caused the issue. For me it was what you say I removed the toolbar from both explorer and firefox. It took over the browser, adds, popup and revised homepage. severely affected performance. Once I realized it was on the computer I got rid of it but this annoying bug was there until I read your post
    Thanks!
    2013-12-15T05:21:23+00:00
    YES
    ITS A REPEAT DESKTOP COMMAND AFTER CRASH PIC EMULATER
    how its fix only Billy Boy knows
    mine
    C:\Users\user\AppData\Local\Conduit\BackgroundContainer\BackgroundContainer.dll
    drive poor user namig Hdd sys32 fill pic missing root missing delivery file **** up !!!
    in lay mans turms ....
    feb I'm nailing solar p's in the congo on a sat' lap ..... next year is my sister stil pressing "close"
    your guess is as good as mine
    mrXtec close
    4mm in depters ?
