BackgroundContainer.dll module not found
2013-10-17T17:54:09+00:00
When my computer starts up, I get the following error message:
c:\Users\Owner\AppData\Local\Conduit\BackgroundContainer\BackgroundContainer.dll
Specific module not found
Anyone have any idea what this is?
2013-10-29T14:35:58+00:00
We’ve already identified the problem – it’s a scheduled task named “BackgroundContainer” that’s attempting to run the BackgroundContainer.dll malware file, which has already been removed. The fact that the “startup item” for the malware’s dll file is a scheduled task is actually “good news”, because it means that you don’t have to edit your registry, or use Autoruns, or uninstall/reinstall any program in order to remove the error message – all you have to do is delete the BackgroundContainer scheduled task. I originally used a link for the removal procedure because that’s where you’ll also find the “authorization” and testimonials for the procedure. So here’s the proof that this procedure will work:
http://answers.microsoft.com/en-us/protect/forum/protect\_other-protect\_scanning/error-message-on-start-up-windows-8/7f29c7ad-2d55-4f1c-8110-ddca3902f596
And, for the benefit of those who maybe just don’t understand what’s going on in that thread, here’s the procedure for removing the BackgroundContainer scheduled task:
Press the Windows key + R
Type “taskschd.msc”
Press the Enter key
Click on the Task Scheduler Library folder
Right-click on the BackgroundContainer task
Select "Delete”
Here’s a good removal guide that you can follow up with to make sure that all traces of the malware are removed:
http://malwaretips.com/blogs/conduit-search-removal/
And here’s the main thread for this issue in the Virus and Malware Forum:
http://answers.microsoft.com/en-us/protect/forum/protect\_scanner-protect\_scanning/run-dll-error-messagebackground-containerdll/49612202-667e-4a71-8e9a-d02161d8bc19
GreginMich
49 additional answers
    2014-12-24T07:21:24+00:00
    Thank you for the update on the issue and good to hear that your issue is resolved by running the Autorun mentioned by Gregin. In addition to that feel free to post on the forum and we will be glad to assist you again.
    Regards,
    2015-01-11T17:39:13+00:00
    I'm new at this.  What do you mean.... 'Press the Windows key + R'?  I have a Lenovo T500 and I don't see a Windows key.  I am using Windows 7  64bit.  Thanks
    2015-01-12T03:42:48+00:00
    Hi Merrill,
    Welcome to Microsoft Community forum.
    Pressing Windows key + R open run box. Windows key is located at the left bottom of your keyboard between Ctrl and Alt key.
    There is another way to open run box in Windows 7. You may refer to the steps provided below to do so.
    Click on start key located at the left bottom of your screen.
    Then type run in the search box.
    Now try to follow the rest of troubleshooting steps.
    Do get back to us if you have any more concern related to your issue and we will be happy to assist you.
    Regards,
    2015-12-05T00:49:59+00:00
    Finally. I had tried so much other stuff like replacing the run.dll in the directory and trying to kill processes. This is what finally fixed that annoying error message.
    Thank you!
