Device driver was not successfully installed (no driver found) on Windows 7 x64
2014-07-23T15:44:09+00:00
I have had this problem for quite some time now, but tried to fix it on and off.
I knew I had problems with USB devices. Not even a standard keyboard will install.
Here is what I have found out:
I have a standard keyboard which I have used on this computer before.
Now it ONLY works if I plug it into the port I installed it on originally.
ALL other USB ports fail.
I then started trying moving other devices around.
They all ONLY work in the ports they were installed on originally.
ALL report a "no driver found" message when trying to use another port.
I then decided to check with a webcam that I never installed on this computer.
It fails on ALL ports.
So it's not only one port or one device.
I now want to move a 3TB harddisk from another computer of mine.
I have a USB3.0 dock that I KNOW supports 3TB drives as it already run one, but on another pc.
On this one I get the same error as in the title, no matter what port I try.
I then decided to pull the drive from the USB dock and mount it internally.
It STILL gives the above error as shown here:
It's almost as if Windows have lost ALL drivers for ALL devices??!?
I have tried the following:
commandline as admin > SFC /SCANNOW
That reports that eveything is fine.
I ran CHKDSK on all drives
No errors.
I tried running the following antispyware:
superantispyware
Malwarebytes Anti-Malware
AdwCleaner
CCleaner
All gives a clean bill of health.
I read other people went into the device manager and deleted all the USB devices, so I tried that.
That made my mouse and keyboard die. Forced shutdown. Boot.
Then Windows showed me I needed USB drivers, but I could not get them as mouse and keyboard didn't work.
I had to boot on my Recovery Disc, and do a system restore.
I don't know if it's any help but I have this from an attempt to run a repair:
I am really getting deperate.
Oh, as a sidenote. Reinstalling/resetting Windows is NOT an option!
    2014-08-26T21:51:59+00:00
    Here are the updated files:
    I don't use OneDrive, but I put the files on my personal site in a temporary folder.
    The event logs are zipped together with the locales.
    http://snowmans.dk/tmp/Events.zip
    http://snowmans.dk/tmp/SysInfo.txt
    2014-08-26T22:36:05+00:00
    [Problem Devices]
    Device PNP Device ID Error Code
    Problem device gone!
    Log Name:      System
    Source:        Microsoft-Windows-UserPnp
    Date:          26/08/2014 21:21:04
    Event ID:      20001
    Level:         Information
    Description:
    Driver Management concluded the process to install driver NULL Driver for Device Instance ID USBSTOR\DISK&VEN_GENERIC&PROD_ULTRA_HS-SD/MMC&REV_1.91\000000264001&0 with the following status: 0xe0000203.
    Google suggests that  0xe0000203 is an error code but I am not sure that it is true. I suspect this report will repeat at regular intervals. It looks harmless.
    2014-08-28T17:27:12+00:00
    Just an update.
    I have wiped my event logs, and then I started testing different devices.
    I tested 2 different USB drives (both failed before), and the Ultra HS-SD/MMC USB device (that always failed).
    Windows fails finding drivers for all of them.
    But if I go and manually point to "C:\WINDOWS\SYSTEM32\DRIVERSTORE\FILEREPOSITORY" then it finds drivers for all devices.
    The log still shows the HS-SD device with error code 0xe0000203, but it seems to be installed correctly.
    Then I tested my webcam that also failed earlier.
    It's as if after I got the other devices installed now it finds the webcam too.
    I'll test more devices later when I have more time, and report back.
    I have uploaded updated files here:
    2014-08-28T21:33:39+00:00
    I just tested my old Olympus u760 camera, which I know works as it connects fine on another Win7 pc.
    Windows fails again until I manually point to "C:\WINDOWS\SYSTEM32\DRIVERSTORE\FILEREPOSITORY".
    Even if I manually point to the inf folder it still fails.
    I verified all the security settings and TrustedInstaller, Administrator and SYSTEM have full rights, and Users have the correct read/traverse etc...
    Still it acts as it can't be bothered to read in the inf folder... I am puzzled...
    2014-08-29T17:01:17+00:00
    I am beginning to wonder if there is some issue that causes it to not get the .sys files needed from the "%Systemdrive%\Windows\System32\drivers" folder... The files are present there, as are the .inf and .PNF files in the "%Systemdrive%\Windows\inf" folder.
    Are there some registry settings that should make sure it gets the .sys files form the correct folder?
