Device driver was not successfully installed (no driver found) on Windows 7 x64
2014-07-23T15:44:09+00:00
I have had this problem for quite some time now, but tried to fix it on and off.
I knew I had problems with USB devices. Not even a standard keyboard will install.
Here is what I have found out:
I have a standard keyboard which I have used on this computer before.
Now it ONLY works if I plug it into the port I installed it on originally.
ALL other USB ports fail.
I then started trying moving other devices around.
They all ONLY work in the ports they were installed on originally.
ALL report a "no driver found" message when trying to use another port.
I then decided to check with a webcam that I never installed on this computer.
It fails on ALL ports.
So it's not only one port or one device.
I now want to move a 3TB harddisk from another computer of mine.
I have a USB3.0 dock that I KNOW supports 3TB drives as it already run one, but on another pc.
On this one I get the same error as in the title, no matter what port I try.
I then decided to pull the drive from the USB dock and mount it internally.
It STILL gives the above error as shown here:
It's almost as if Windows have lost ALL drivers for ALL devices??!?
I have tried the following:
commandline as admin > SFC /SCANNOW
That reports that eveything is fine.
I ran CHKDSK on all drives
No errors.
I tried running the following antispyware:
superantispyware
Malwarebytes Anti-Malware
AdwCleaner
CCleaner
All gives a clean bill of health.
I read other people went into the device manager and deleted all the USB devices, so I tried that.
That made my mouse and keyboard die. Forced shutdown. Boot.
Then Windows showed me I needed USB drivers, but I could not get them as mouse and keyboard didn't work.
I had to boot on my Recovery Disc, and do a system restore.
I don't know if it's any help but I have this from an attempt to run a repair:
I am really getting deperate.
Oh, as a sidenote. Reinstalling/resetting Windows is NOT an option!
    2014-08-11T22:20:55+00:00
    I uninstalled and reinstalled them, not that it helped, but can't see how they can affect a harddisk not being installed.
    If that was the reason then I would not even be able to install Windows as the drivers for the chipset wasn't installed at the time.
    2014-08-12T01:41:29+00:00
    Chipset drivers are typically involved with the Hard drive controllers. There are generic drivers as part of the Windows 7 installation DVD for initial installation purposes.
    Sometimes the driver may become corrupt. That is why I suggested reinstalling them.
    2014-08-21T19:42:07+00:00
    Just to let everyone know...
    I still have no solution to this issue.
    2014-08-21T21:25:24+00:00
    Your original post referred to a different drive to the one I posted about earlier.
    Check you have the latest firmware for this drive "ST3000DM001":
    http://knowledge.seagate.com/articles/en_US/FAQ/223651en
    2014-08-21T22:52:16+00:00
    Well I gave up on that drive and mounted it on another pc, just after my initial post.
    Sorry I didn't mention that.
    Regarding my Generic Ultra HS-SD/MMC USB Device...
    I uninstalled it as you suggested, and now Windows can't find the drivers for it anymore.
