How do I disable split screen for opening links?
2013-10-21T19:00:24+00:00
I am running Win 8.1 on a TABLET.  I have about 9 inches of screen real estate to work with.
If I click a link in, say, the Mail app, it will launch IE in 50/50 mode with the existing mail app (which then rearranges itself to only show the single message I was looking at).
This is not at all helpful.  This gives me a four inch web browser, which isn't big enough to see clearly at all.  The controls are all too close together to operate by touch, etc.  I am then forced to manually drag to expand the IE window to full screen.  Unfortunately, the control to do this is also rather small, and I usually miss the first two times.  It typically takes me about 10-15 seconds between clicking a link in email and being able to read the corresponding web page.
Windows 8 handled this correctly.  I would like to revert to the behavior of always opening apps in full screen mode.  How can I accomplish this?
I know it should be possible.  If I hold the tablet in portrait mode, the annoying split window thing does not happen.  (It's not natural for me to hold it this way all the time.)
Is there a registry setting or something for "Always open new apps in full screen mode"?
    2014-01-28T21:28:01+00:00
    OP here.  Little Fly has it right.
    Using a tablet, the "cursor" solution just doesn't work.
    Still waiting on an answer from MSFT.
    2014-02-12T10:48:46+00:00
    I totally agree. It is not at all helpful on an 8" tablet! Please Microsoft, how can I disable it?
    2014-02-12T17:09:39+00:00
    I don't know how to disable it.  But if you move your cursor to the top of the new app till it turns into the hand, you can double-click and it will make the app full screen.  If you double-click the hand again, it will go back to split-screen.
    Thanks, it helps but it's still jacked up (when I swipe back to the mail app for instance, it stays at half the screen size, I have to double click everytime to make it full screen).
    I still hate that automatic split/snap so hard that I had to come back to this thread to complain. Let me be full screen all the time it's simple I never want to be half and half, I am a whole milk man. Wait.
    It was great in 8 and I don't understand the need to kill a feature that works beautifully with modern apps, on laptops or tablets. At least make it an option. I really don't get it. You can't handle full screen? Stay on the desktop or 7.
    Please someone tell me it's being fixed forever.
    2014-02-13T12:57:12+00:00
    I agree. I WANT TO BE ABLE TO TURN OFF SPLIT SCREEN! Shouting intended! It's really annoying, especially on an 8" tablet screen. Come on, Microsoft, let us choose.
    2014-02-14T04:24:46+00:00
    If not Microsoft, at least some third party app. I would pay to be able to turn off split screen..
