Right click 8.1 'start' button does nothing
2013-11-01T18:45:56+00:00
Hi;
Upgraded from windows store (original 8.0 clean install) to 8.1.  Everything worked fine, except the windows start button does not respond to a right mouse click.  Left button works fine (switches between desktop and start menu), Right mouse clicks works as expected on every other object.  I don't have any of the windows 8.1 start screen navigation settings checked  (I.E. stop using the start screen).
Ideas?
    2013-11-02T14:57:32+00:00
    -Did you check if the issue persists in new user account?
    I would suggest you to check if the issue persists in Safe Mode, if right click works place the computer in Clean Boot.
    Method 1:
    Step 1: Boot the computer in **Safe mode******and check if the issue persists. Safe mode starts Windows with a limited set of files and drivers. Startup programs don't run in safe mode, and only the basic drivers needed to start Windows are installed.
    **Step 2:**If the issue does not persists in Safe Mode then perform a **clean boot** to check if any third party application is causing the issue, as clean boot helps in eliminating software conflicts.
    Note: After troubleshooting, see the section “Reset the computer to start as usual” to return the computer to a Normal startup mode.
    Method 2:
    Run a system file checker scan and check if that helps. Refer the following steps to run SFC scan.
    a) Press Windows key + X which bring up a list of Windows settings.
    b) Click on ‘Command Prompt (Admin) to bring up elevated command prompt. Note: Click ‘Yes’ if it prompts for permission.
    c) In the command prompt type in the following command: ‘sfc /scannow’.
    Let us know the status of the issue. If you need further assistance, please post back. We will be glad to help you.
    2013-11-02T15:40:38+00:00
    A probing question to possibly improve the answer: aside from respond, what do you expect to happen when you right-click on the Start button? What are you looking for it to do, that perhaps it did before in 8.0?
    ( I expect it to show the "power user" shortcuts menu -- you can also press Windows+X to get the same menu -- and this is what right-clicking it does for me.)
    2013-11-02T23:26:28+00:00
    Created a non-administrator account, the problem is not there, right mouse click pulls up the expected menu of options.
    Method 1 changed nothing for the admin account used to apply the upgrade.
    Method 2: Because I can't right click the start button and pull up the advanced options menu (and windows key + x does not work either), I had to go to the start menu, search on command, then right click and select run as administrator the command prompt option.
    Ran sfc, got this result:
    Microsoft Windows [Version 6.3.9600]
    (c) 2013 Microsoft Corporation. All rights reserved.
    C:\WINDOWS\system32>sfc /scannow
    Beginning system scan.  This process will take some time.
    Beginning verification phase of system scan.
    Verification 100% complete.
    Windows Resource Protection found corrupt files but was unable to fix some
    of them. Details are included in the CBS.Log windir\Logs\CBS\CBS.log. For
    example C:\Windows\Logs\CBS\CBS.log. Note that logging is currently not
    supported in offline servicing scenarios.
    So it appears I have corruption of some sort that impacts the administrator account.  I will dig into this and see if I can figure out what is going on.
    thanks
    2013-11-02T23:35:46+00:00
    Forgot to mention: this is the 3rd windows 8.1 update I have done thus far;  1 was on a system running the 8.1 preview, 2 was on a system running windows 8.0 from a clean install (just as this 3rd system).
    Both of the previous updates had no issues.
    2013-11-03T23:30:27+00:00
    Ok, figured this issue out.  However, I am not real wild about this problem happening during the 8.1 upgrade process.
    The problem was missing shortcut entries in:
    c:\User<user>\AppData\Local\Microsoft\Windows\WinX\Group1
    c:\User<user>\AppData\Local\Microsoft\Windows\WinX\Group2
    c:\User<user>\AppData\Local\Microsoft\Windows\WinX\Group3
    I copied the entries from the non-administrator account I had created, rebooted, and everything is as expected, including windows + x.
