Ctrl Panel,
search for Troubleshoot,
select Troubleshhoting,
at the bottom, under System and Security
select Fix problems with Windows Update.
I'd tried it yesterday, it's fixed something, but not solved my problem.
I'll try it again.
Strange
Hi I have a TABLET Dell Latitude 10 ST2 Windows 8 Pro. Same problem here, update fails undoing screen. I tried the fix windows update advice above and it fixed 2 items. I noticed that this time it took a lot less time for windows update to download the updates, say 20 minutes (it took upwards of 1-2 hours in the past).
I am waiting for the "preparing to install" thing to stop, to finally get done, and its taking a while. It's been at least 40 minutes. Before this fix try I tried setting 3 things to Automatic in Services, being led by someone on YouTube. That didn't work. I fell asleep last night while the updates were installing, when I woke up at 8 am it had failed hours and hours previous, signifying that waiting 30 minutes doesn't do anything to help you.
We'll see here in a few if it worked. I'll keep posted. I hope there is someone still alive here.
