I started my own thread trying to get this resolved and sent an email to realtek.
I have researched the way drivers are handled a little bit and since this driver will work until its time to reboot, I have been disabling the device in device manager before shutting the tablet down, then after booting up I enable it again, this has allowed to to function but is a pain. But that being said drivers are handle in a couple of different ways, some are loaded as the system is initializing and some are as plug and play (or loaded on demand) after the system is booted up. It seems to me that this driver can function as plug and play since that is what I am doing manually through device manager, if someone could write the configuration file for the driver to operate like that it might solve the issue.
Anyone know how to do that?
So to be clear: It is a driver configuration error, the driver for the realtek hardware is causing the system to hang during boot.
If your system is hanging, you must restart in safe mode, then go to device manager and disable to the realtek sound device. Then reboot in normal mode and again enable the sound device, thendo not shut down the tablet unless you disable the sound device first.
I keep the tablet in sleep mode when I am not using it, it will wake up fine, but if you shut it down without disabling you will have to do the safe mode thing again. Until they fix the driver this is the only way to have the tablet function with sound.
