Asus M80TA stylus is not working I2C HID Device Error Code10
2014-04-25T19:03:01+00:00
I have an M80TA Asus vivotab note 8, which has worked fine for almost 2 months. Then suddenly the stylus wasn't registered, but after a reboot everything seemed to work again. The next day it happened again but then the stylus stopped working at all. I receive code 10 error message regardless whether the wacom driver is installed or not. I also went through the latest wacom driver install / remove, removed the display adapter but to no avail (this was suggested in a related thread).
I've reinstalled the whole windows wiping the whole drive, but still nothing. The same error 10 appears. Is it possible that the wacom stylus has gone out of work? Are there any fixes I should download from Microsoft?
Please help me in solving this issue.
Roland
2014-04-26T16:01:27+00:00
Hi Roland,
Let’s check the following registry location:
Note: You need to log in as administrator to perform this task.
Important: Follow the steps in this section carefully. Serious problems might occur if you modify the registry incorrectly. Before you modify it, back up the registry for restoration in case problems occur.
  • Use your hand to perform these steps.
  • Press Windows key + R key.
  • Type regedit in the run box, hit Enter in the keyboard.
  • In the Registry Editor, navigate to the below location:
*HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class*
  • You should see a long list of registry subkeys, try to find the below registry key.
4D36E968-E325-11CE-BFC1-08002BE10318
  • Right click on it and click Delete.
  • When you are prompted to confirm the deletion, click Yes.
  • Exit Registry Editor.
  • Restart the computer.
If the issue still persists, please contact the Asus support.
http://vip.asus.com/FORUM/
Try these steps and let us know the results.
40 additional answers
    2017-02-03T07:44:03+00:00
    Worked to fix my touch screen issue (had to use command line as given in another reply, though). Only a new problem arose. No brightness button in Action Center anymore, and battery saver button grayed out.
    This Asus Vivo Tab was way more trouble than it's worth! Looking forward to getting a non-Asus tablet soon.
    2017-01-22T17:17:34+00:00
    Attempted to delete key specified, failed due to error.
    2016-07-23T16:23:46+00:00
    In your case, that definitely sounds like a software issue.
    My pen also does not work, but neither starting up in diagnosis mode, nor stopping the Wacom service changed anything.
    2015-12-17T09:50:03+00:00
    I have given up on the stylus. As far as I am concerned, stylus is not there. Will upgrade soon to a better tablet
