Asus M80TA stylus is not working I2C HID Device Error Code10
2014-04-25T19:03:01+00:00
I have an M80TA Asus vivotab note 8, which has worked fine for almost 2 months. Then suddenly the stylus wasn't registered, but after a reboot everything seemed to work again. The next day it happened again but then the stylus stopped working at all. I receive code 10 error message regardless whether the wacom driver is installed or not. I also went through the latest wacom driver install / remove, removed the display adapter but to no avail (this was suggested in a related thread).
I've reinstalled the whole windows wiping the whole drive, but still nothing. The same error 10 appears. Is it possible that the wacom stylus has gone out of work? Are there any fixes I should download from Microsoft?
Please help me in solving this issue.
Roland
2014-04-26T16:01:27+00:00
Hi Roland,
Let’s check the following registry location:
Note: You need to log in as administrator to perform this task.
Important: Follow the steps in this section carefully. Serious problems might occur if you modify the registry incorrectly. Before you modify it, back up the registry for restoration in case problems occur.
  • Use your hand to perform these steps.
  • Press Windows key + R key.
  • Type regedit in the run box, hit Enter in the keyboard.
  • In the Registry Editor, navigate to the below location:
*HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class*
  • You should see a long list of registry subkeys, try to find the below registry key.
4D36E968-E325-11CE-BFC1-08002BE10318
  • Right click on it and click Delete.
  • When you are prompted to confirm the deletion, click Yes.
  • Exit Registry Editor.
  • Restart the computer.
If the issue still persists, please contact the Asus support.
http://vip.asus.com/FORUM/
Try these steps and let us know the results.
40 additional answers
    2015-02-08T02:43:37+00:00
    Hi, jed72
    Thank you for this reply and the link to YouTube. It is useful to know how to open the back cover.
    I guess you have had no problems with the pen since September 2014 after straightening the cables on both sides?
    My tablet is still under warranty from amazon.com? Removing the back cover will make the warranty void? I don't mind voiding the warranty, if it is going to work for me.
    I am only concerned about the cable straightening part. What do you do exactly? Is there YouTube clip on straightening the cables on both sides? Please reply soon. Thank you again!
    At least people who follow this thread in future will have a closure on this Wacom pen issue with the proper solution in their hands.
    Kind regards
    Wilfred
    2015-02-06T12:14:47+00:00
    Hi Wilfred,
    sadly the problem resurfaced again after 3 months of constant usage. The same issue was reported by Asus Repair.
    I hope this lasts a little longer.
    Kind regards,
    Roland
    2015-02-06T06:05:33+00:00
    Hi Wilfred,
    My pen stopped working completely after a month or so.
    I did some research on YouTube
    I removed the back cover and straightened the cables on both sides.
    I have not had any problems since.
    Please follow the link:  https://www.youtube.com/watch?v=dNH2837P6AM
    Hope this is helpful.
    Jan
    2015-02-06T05:15:24+00:00
    Hi, jed72
    Your method worked for me as well. I have done this so many times. Just curious! Has the pen stopped working again? Did you have to do it many times like I did.
    Please reply if you have anything to add.
    Kind regards
    Wilfred
