Why does Store Broker (wshost.exe) keep killing my CPU?
2014-01-24T23:58:25+00:00
I've got a new Windows 8 machine and, for some reason, the Store Broker keeps pegging my CPU. It seems to pop up every time I do anything with the Windows Store (makes sense) or use some Metro apps (also makes sense). However, for some reason, this process takes up 33% of my CPU and never lets go of it once it starts. This causes the machine to get hot which causes the fan to come on and the combination drastically reduces my battery life (from 11hrs to 3).
Aside from frequently checking for and killing this app, is there anything else I can do about this? Is anyone else having this problem? Is it a misconfiguration on my end? I'm running this on a new Surface Pro 2.
Thanks!
2014-03-19T01:17:01+00:00
I SOLVED this. At least for myself. It's been a 3-day journey. Argh!
The upshot is this:
Kill Store and Store Broker from task list.
Rename the Cache folder to CacheOld at:
C:\Users(Your User Account)\AppData\Local\Packages\WinStore_cw5n1h2txyewy\LocalState
(Your WinStore_gobblygook might be a different bunch of gobbblygook)
Create an empty folder called Cache.
Solved! For me anyway.
Enjoy,
Ron
PS
I have been at this for days. I've read every article and post everywhere. I have updated graphics drivers, set date and time, run wsreset, sfc /scannnow, created new user account (store did work for new account), app troubleshooter, etc, etc, etc...
Today I just started digging around and looking at dates. I don't have log files to back this up but I believe I broke Store with CCleaner. I'm not sure exactly when the Store broke so this is a best guess but it makes some sense since Ccleaner does clean Store cache.
I also recently installed Tor Browser but my gut is that that was totally unrelated.
I might create a sandbox user and try to break Store with Ccleaner to confirm. But honestly I am tired of this little adventure.
220 additional answers
    2014-02-10T22:11:45+00:00
    It is related to Windows Store application. Store broker start to consume 100% of CPU immediately after Windows Store startup.
    What I noticed is also, that I am not able to install one application called "Prima Play" maybe it is somehow related...
    2014-02-11T09:13:54+00:00
    I cannot install the App called "Goal" -
    its the only one i've tried to install recently tbh
    any other ideas on how to stop this from taking so much of my CPU everytime i bootup ?
    2014-02-11T21:05:07+00:00
    well its not ideal but the only solution ive found apart from refreshing windows 8.1 is to disable the store via regedit -
    i contacted MS via twitter and they said a OS refresh would be the best solution -
    so i tried disabling the store via regedit and im 5 minutes into a bootup and storebroker is NOT causing my CPU to calculate like mad for no apparent reason -
    2014-02-11T22:11:51+00:00
    Did they really recommend an OS refresh? Does that indicate that there's some sort of corruption going on? Is that a full re-install or re-install and maintain files?
    Did they indicate they are working on a solution?
