DISM /restoreHealth fails with 0x800f081f AFTER 8.1 update successfully installed
2014-04-11T16:18:28+00:00
I'm concerned about having a machine in a broken state going forward, though.
here's what I ran:
C:\Windows\Logs\CBS>dism /online /cleanup-image /restoreHealth
Deployment Image Servicing and Management tool
Version: 6.3.9600.17031
Image Version: 6.3.9600.17031
[==========================100.0%==========================]
The restore operation failed. Either the repair source was not found or the comp
onent store cannot be repaired.
Error: 0x800f081f
DISM failed. No operation was performed.
For more information, review the log file.
The DISM log file can be found at C:\Windows\Logs\DISM\dism.log
here is the DISM.log:
2014-04-11 11:38:04, Info                  DISM   PID=11556 TID=8436 Scratch directory set to 'C:\Users\tripp\AppData\Local\Temp'. - CDISMManager::put_ScratchDir
2014-04-11 11:38:04, Info                  DISM   PID=11556 TID=8436 DismCore.dll version: 6.3.9600.17031 - CDISMManager::FinalConstruct
2014-04-11 11:38:04, Info                  DISM   PID=11556 TID=8436 Successfully loaded the ImageSession at "C:\Windows\System32\Dism" - CDISMManager::LoadLocalImageSession
2014-04-11 11:38:04, Info                  DISM   DISM Provider Store: PID=11556 TID=8436 Found and Initialized the DISM Logger. - CDISMProviderStore::Internal_InitializeLogger
2014-04-11 11:38:04, Info                  DISM   DISM Provider Store: PID=11556 TID=8436 Failed to get and initialize the PE Provider.  Continuing by assuming that it is not a WinPE image. - CDISMProviderStore::Final_OnConnect
2014-04-11 11:38:04, Info                  DISM   DISM Provider Store: PID=11556 TID=8436 Finished initializing the Provider Map. - CDISMProviderStore::Final_OnConnect
2014-04-11 11:38:04, Info                  DISM   DISM Provider Store: PID=11556 TID=8436 Getting Provider DISMLogger - CDISMProviderStore::GetProvider
2014-04-11 11:38:04, Info                  DISM   DISM Provider Store: PID=11556 TID=8436 Provider has previously been initialized.  Returning the existing instance. - CDISMProviderStore::Internal_GetProvider
2014-04-11 11:38:04, Info                  DISM   DISM Manager: PID=11556 TID=8436 Successfully created the local image session and provider store. - CDISMManager::CreateLocalImageSession
2014-04-11 11:38:04, Info                  DISM   DISM.EXE:
2014-04-11 11:38:04, Info                  DISM   DISM.EXE: <----- Starting Dism.exe session ----->
2014-04-11 11:38:04, Info                  DISM   DISM.EXE: Host machine information: OS Version=6.3.9600, Running architecture=amd64, Number of processors=8
2014-04-11 11:38:04, Info                  DISM   DISM.EXE: Dism.exe version: 6.3.9600.17031
2014-04-11 11:38:04, Info                  DISM   DISM.EXE: Executing command line: dism  /online /cleanup-image /restoreHealth
2014-04-11 11:38:04, Info                  DISM   DISM Provider Store: PID=11556 TID=8436 Getting Provider FolderManager - CDISMProviderStore::GetProvider
2014-04-11 11:38:04, Info                  DISM   DISM Provider Store: PID=11556 TID=8436 Provider has not previously been encountered.  Attempting to initialize the provider. - CDISMProviderStore::Internal_GetProvider
2014-04-11 11:38:04, Info                  DISM   DISM Provider Store: PID=11556 TID=8436 Loading Provider from location C:\Windows\System32\Dism\FolderProvider.dll - CDISMProviderStore::Internal_GetProvider
2014-04-11 11:38:04, Info                  DISM   DISM Provider Store: PID=11556 TID=8436 Connecting to the provider located at C:\Windows\System32\Dism\FolderProvider.dll. - CDISMProviderStore::Internal_LoadProvider
2014-04-11 11:38:04, Info                  DISM   DISM Manager: PID=11556 TID=8436 physical location path: C:\ - CDISMManager::CreateImageSession
2014-04-11 11:38:04, Info                  DISM   DISM Manager: PID=11556 TID=8436 Copying DISM from "C:\Windows\System32\Dism" - CDISMManager::CreateImageSessionFromLocation
2014-04-11 11:38:05, Info                  DISM   DISM Manager: PID=11556 TID=8436 Successfully loaded the ImageSession at "C:\Users\tripp\AppData\Local\Temp\DA023AD7-BFB2-4FA5-9784-B6E1ED49DF38" - CDISMManager::LoadRemoteImageSession
2014-04-11 11:38:05, Info                  DISM   DISM Image Session: PID=8880 TID=212 Instantiating the Provider Store. - CDISMImageSession::get_ProviderStore
2014-04-11 11:38:05, Info                  DISM   DISM Provider Store: PID=8880 TID=212 Initializing a provider store for the IMAGE session type. - CDISMProviderStore::Final_OnConnect
2014-04-11 11:38:05, Info                  DISM   DISM Provider Store: PID=8880 TID=212 Provider has not previously been encountered.  Attempting to initialize the provider. - CDISMProviderStore::Internal_GetProvider
2014-04-11 11:38:05, Info                  DISM   DISM Provider Store: PID=8880 TID=212 Loading Provider from location C:\Users\tripp\AppData\Local\Temp\DA023AD7-BFB2-4FA5-9784-B6E1ED49DF38\OSProvider.dll - CDISMProviderStore::Internal_GetProvider
2014-04-11 11:38:05, Info                  DISM   DISM Provider Store: PID=8880 TID=212 Connecting to the provider located at C:\Users\tripp\AppData\Local\Temp\DA023AD7-BFB2-4FA5-9784-B6E1ED49DF38\OSProvider.dll. - CDISMProviderStore::Internal_LoadProvider
2014-04-11 11:38:05, Info                  DISM   DISM OS Provider: PID=8880 TID=212 Defaulting SystemPath to C:\ - CDISMOSServiceManager::Final_OnConnect
2014-04-11 11:38:05, Info                  DISM   DISM OS Provider: PID=8880 TID=212 Defaulting Windows folder to C:\Windows - CDISMOSServiceManager::Final_OnConnect
2014-04-11 11:38:05, Info                  DISM   DISM OS Provider: PID=8880 TID=212 Host OS verion is 6.3 - CDISMOSServiceManager::SetDllSearchPath
2014-04-11 11:38:05, Info                  DISM   DISM Provider Store: PID=8880 TID=212 Attempting to initialize the logger from the Image Session. - CDISMProviderStore::Final_OnConnect
2014-04-11 11:38:05, Info                  DISM   DISM Provider Store: PID=8880 TID=212 Loading Provider from location C:\Users\tripp\AppData\Local\Temp\DA023AD7-BFB2-4FA5-9784-B6E1ED49DF38\LogProvider.dll - CDISMProviderStore::Internal_GetProvider
2014-04-11 11:38:05, Info                  DISM   DISM Provider Store: PID=8880 TID=212 Connecting to the provider located at C:\Users\tripp\AppData\Local\Temp\DA023AD7-BFB2-4FA5-9784-B6E1ED49DF38\LogProvider.dll. - CDISMProviderStore::Internal_LoadProvider
2014-04-11 11:38:05, Info                  DISM   DISM Provider Store: PID=8880 TID=212 Found and Initialized the DISM Logger. - CDISMProviderStore::Internal_InitializeLogger
2014-04-11 11:38:05, Info                  DISM   DISM Provider Store: PID=8880 TID=212 Loading Provider from location C:\Users\tripp\AppData\Local\Temp\DA023AD7-BFB2-4FA5-9784-B6E1ED49DF38\PEProvider.dll - CDISMProviderStore::Internal_GetProvider
2014-04-11 11:38:05, Warning               DISM   DISM Provider Store: PID=8880 TID=212 Failed to Load the provider: C:\Users\tripp\AppData\Local\Temp\DA023AD7-BFB2-4FA5-9784-B6E1ED49DF38\PEProvider.dll. - CDISMProviderStore::Internal_GetProvider(hr:0x8007007e)
2014-04-11 11:38:05, Info                  DISM   DISM Provider Store: PID=8880 TID=212 Failed to get and initialize the PE Provider.  Continuing by assuming that it is not a WinPE image. - CDISMProviderStore::Final_OnConnect
2014-04-11 11:38:05, Info                  DISM   DISM Provider Store: PID=8880 TID=212 Finished initializing the Provider Map. - CDISMProviderStore::Final_OnConnect
2014-04-11 11:38:05, Info                  DISM   DISM Provider Store: PID=8880 TID=212 Getting Provider DISMLogger - CDISMProviderStore::GetProvider
2014-04-11 11:38:05, Info                  DISM   DISM Provider Store: PID=8880 TID=212 Provider has previously been initialized.  Returning the existing instance. - CDISMProviderStore::Internal_GetProvider
2014-04-11 11:38:05, Info                  DISM   DISM Manager: PID=11556 TID=8436 Image session successfully loaded from the temporary location: C:\Users\tripp\AppData\Local\Temp\DA023AD7-BFB2-4FA5-9784-B6E1ED49DF38 - CDISMManager::CreateImageSession
2014-04-11 11:38:05, Info                  DISM   DISM Provider Store: PID=8880 TID=212 Getting Provider OSServices - CDISMProviderStore::GetProvider
2014-04-11 11:38:05, Info                  DISM   DISM.EXE: Target image information: OS Version=6.3.9600.17031, Image architecture=amd64
2014-04-11 11:38:05, Info                  DISM   DISM Provider Store: PID=8880 TID=212 Getting the collection of providers from an image provider store type. - CDISMProviderStore::GetProviderCollection
2014-04-11 11:38:05, Info                  DISM   DISM Provider Store: PID=8880 TID=212 Loading Provider from location C:\Users\tripp\AppData\Local\Temp\DA023AD7-BFB2-4FA5-9784-B6E1ED49DF38\CbsProvider.dll - CDISMProviderStore::Internal_GetProvider
2014-04-11 11:38:05, Info                  DISM   DISM Provider Store: PID=8880 TID=212 Connecting to the provider located at C:\Users\tripp\AppData\Local\Temp\DA023AD7-BFB2-4FA5-9784-B6E1ED49DF38\CbsProvider.dll. - CDISMProviderStore::Internal_LoadProvider
2014-04-11 11:38:05, Info                  DISM   DISM Provider Store: PID=8880 TID=212 Encountered a servicing provider, performing additional servicing initializations. - CDISMProviderStore::Internal_LoadProvider
2014-04-11 11:38:06, Info                  DISM   DISM Package Manager: PID=8880 TID=212 Finished initializing the CbsConUI Handler. - CCbsConUIHandler::Initialize
2014-04-11 11:38:06, Info                  DISM   DISM Package Manager: PID=8880 TID=212 CBS is being initialized for online use. More information about CBS actions can be located at: %windir%\logs\cbs\cbs.log - CDISMPackageManager::Initialize
2014-04-11 11:38:06, Info                  DISM   DISM Package Manager: PID=8880 TID=212 Loaded servicing stack for online use only. - CDISMPackageManager::RefreshInstanceAndLock
2014-04-11 11:38:06, Info                  DISM   DISM Provider Store: PID=8880 TID=212 Provider has not previously been encountered.  Attempting to initialize the provider. - CDISMProviderStore::Internal_GetProvider
2014-04-11 11:38:06, Info                  DISM   DISM Provider Store: PID=8880 TID=212 Loading Provider from location C:\Users\tripp\AppData\Local\Temp\DA023AD7-BFB2-4FA5-9784-B6E1ED49DF38\MsiProvider.dll - CDISMProviderStore::Internal_GetProvider
2014-04-11 11:38:06, Info                  DISM   DISM Provider Store: PID=8880 TID=212 Connecting to the provider located at C:\Users\tripp\AppData\Local\Temp\DA023AD7-BFB2-4FA5-9784-B6E1ED49DF38\MsiProvider.dll. - CDISMProviderStore::Internal_LoadProvider
2014-04-11 11:38:06, Info                  DISM   DISM Provider Store: PID=8880 TID=212 Encountered a servicing provider, performing additional servicing initializations. - CDISMProviderStore::Internal_LoadProvider
2014-04-11 11:38:06, Info                  DISM   DISM Provider Store: PID=8880 TID=212 Loading Provider from location C:\Users\tripp\AppData\Local\Temp\DA023AD7-BFB2-4FA5-9784-B6E1ED49DF38\IntlProvider.dll - CDISMProviderStore::Internal_GetProvider
2014-04-11 11:38:06, Info                  DISM   DISM Provider Store: PID=8880 TID=212 Connecting to the provider located at C:\Users\tripp\AppData\Local\Temp\DA023AD7-BFB2-4FA5-9784-B6E1ED49DF38\IntlProvider.dll. - CDISMProviderStore::Internal_LoadProvider
2014-04-11 11:38:06, Info                  DISM   DISM Provider Store: PID=8880 TID=212 Loading Provider from location C:\Users\tripp\AppData\Local\Temp\DA023AD7-BFB2-4FA5-9784-B6E1ED49DF38\IBSProvider.dll - CDISMProviderStore::Internal_GetProvider
2014-04-11 11:38:06, Info                  DISM   DISM Provider Store: PID=8880 TID=212 Connecting to the provider located at C:\Users\tripp\AppData\Local\Temp\DA023AD7-BFB2-4FA5-9784-B6E1ED49DF38\IBSProvider.dll. - CDISMProviderStore::Internal_LoadProvider
2014-04-11 11:38:06, Info                  DISM   DISM Provider Store: PID=8880 TID=212 Loading Provider from location C:\Users\tripp\AppData\Local\Temp\DA023AD7-BFB2-4FA5-9784-B6E1ED49DF38\DmiProvider.dll - CDISMProviderStore::Internal_GetProvider
2014-04-11 11:38:06, Info                  DISM   DISM Provider Store: PID=8880 TID=212 Connecting to the provider located at C:\Users\tripp\AppData\Local\Temp\DA023AD7-BFB2-4FA5-9784-B6E1ED49DF38\DmiProvider.dll. - CDISMProviderStore::Internal_LoadProvider
2014-04-11 11:38:06, Info                  DISM   DISM OS Provider: PID=8880 TID=212 Successfully loaded the hive. - CDISMOSServiceManager::DetermineBootDrive
2014-04-11 11:38:06, Info                  DISM   DISM Driver Manager: PID=8880 TID=212 Further logs for driver related operations can be found in the target operating system at %WINDIR%\inf\setupapi.offline.log - CDriverManager::Initialize
2014-04-11 11:38:06, Info                  DISM   DISM Provider Store: PID=8880 TID=212 Loading Provider from location C:\Users\tripp\AppData\Local\Temp\DA023AD7-BFB2-4FA5-9784-B6E1ED49DF38\UnattendProvider.dll - CDISMProviderStore::Internal_GetProvider
2014-04-11 11:38:06, Info                  DISM   DISM Provider Store: PID=8880 TID=212 Connecting to the provider located at C:\Users\tripp\AppData\Local\Temp\DA023AD7-BFB2-4FA5-9784-B6E1ED49DF38\UnattendProvider.dll. - CDISMProviderStore::Internal_LoadProvider
2014-04-11 11:38:06, Info                  DISM   DISM Provider Store: PID=8880 TID=212 Loading Provider from location C:\Users\tripp\AppData\Local\Temp\DA023AD7-BFB2-4FA5-9784-B6E1ED49DF38\Wow64provider.dll - CDISMProviderStore::Internal_GetProvider
2014-04-11 11:38:06, Warning               DISM   DISM Provider Store: PID=8880 TID=212 Failed to get the IDismObject Interface - CDISMProviderStore::Internal_LoadProvider(hr:0x80004002)
2014-04-11 11:38:06, Warning               DISM   DISM Provider Store: PID=8880 TID=212 Failed to Load the provider: C:\Users\tripp\AppData\Local\Temp\DA023AD7-BFB2-4FA5-9784-B6E1ED49DF38\Wow64provider.dll. - CDISMProviderStore::Internal_GetProvider(hr:0x80004002)
2014-04-11 11:38:06, Info                  DISM   DISM Provider Store: PID=8880 TID=212 Loading Provider from location C:\Users\tripp\AppData\Local\Temp\DA023AD7-BFB2-4FA5-9784-B6E1ED49DF38\SmiProvider.dll - CDISMProviderStore::Internal_GetProvider
2014-04-11 11:38:06, Info                  DISM   DISM Provider Store: PID=8880 TID=212 Connecting to the provider located at C:\Users\tripp\AppData\Local\Temp\DA023AD7-BFB2-4FA5-9784-B6E1ED49DF38\SmiProvider.dll. - CDISMProviderStore::Internal_LoadProvider
2014-04-11 11:38:06, Info                  DISM   DISM Provider Store: PID=8880 TID=212 Loading Provider from location C:\Users\tripp\AppData\Local\Temp\DA023AD7-BFB2-4FA5-9784-B6E1ED49DF38\EmbeddedProvider.dll - CDISMProviderStore::Internal_GetProvider
2014-04-11 11:38:06, Warning               DISM   DISM Provider Store: PID=8880 TID=212 Failed to Load the provider: C:\Users\tripp\AppData\Local\Temp\DA023AD7-BFB2-4FA5-9784-B6E1ED49DF38\EmbeddedProvider.dll. - CDISMProviderStore::Internal_GetProvider(hr:0x8007007e)
2014-04-11 11:38:06, Info                  DISM   DISM Provider Store: PID=8880 TID=212 Loading Provider from location C:\Users\tripp\AppData\Local\Temp\DA023AD7-BFB2-4FA5-9784-B6E1ED49DF38\AppxProvider.dll - CDISMProviderStore::Internal_GetProvider
2014-04-11 11:38:06, Info                  DISM   DISM Provider Store: PID=8880 TID=212 Connecting to the provider located at C:\Users\tripp\AppData\Local\Temp\DA023AD7-BFB2-4FA5-9784-B6E1ED49DF38\AppxProvider.dll. - CDISMProviderStore::Internal_LoadProvider
2014-04-11 11:38:06, Info                  DISM   DISM Provider Store: PID=8880 TID=212 Loading Provider from location C:\Users\tripp\AppData\Local\Temp\DA023AD7-BFB2-4FA5-9784-B6E1ED49DF38\AssocProvider.dll - CDISMProviderStore::Internal_GetProvider
2014-04-11 11:38:06, Info                  DISM   DISM Provider Store: PID=8880 TID=212 Connecting to the provider located at C:\Users\tripp\AppData\Local\Temp\DA023AD7-BFB2-4FA5-9784-B6E1ED49DF38\AssocProvider.dll. - CDISMProviderStore::Internal_LoadProvider
2014-04-11 11:38:06, Info                  DISM   DISM Provider Store: PID=8880 TID=212 Loading Provider from location C:\Users\tripp\AppData\Local\Temp\DA023AD7-BFB2-4FA5-9784-B6E1ED49DF38\GenericProvider.dll - CDISMProviderStore::Internal_GetProvider
2014-04-11 11:38:06, Info                  DISM   DISM Provider Store: PID=8880 TID=212 Connecting to the provider located at C:\Users\tripp\AppData\Local\Temp\DA023AD7-BFB2-4FA5-9784-B6E1ED49DF38\GenericProvider.dll. - CDISMProviderStore::Internal_LoadProvider
2014-04-11 11:38:06, Info                  DISM   DISM Provider Store: PID=8880 TID=212 Loading Provider from location C:\Users\tripp\AppData\Local\Temp\DA023AD7-BFB2-4FA5-9784-B6E1ED49DF38\TransmogProvider.dll - CDISMProviderStore::Internal_GetProvider
2014-04-11 11:38:06, Info                  DISM   DISM Provider Store: PID=8880 TID=212 Connecting to the provider located at C:\Users\tripp\AppData\Local\Temp\DA023AD7-BFB2-4FA5-9784-B6E1ED49DF38\TransmogProvider.dll. - CDISMProviderStore::Internal_LoadProvider
2014-04-11 11:38:06, Info                  DISM   DISM Transmog Provider: PID=8880 TID=212 Current image session is [ONLINE] - CTransmogManager::GetMode
2014-04-11 11:38:06, Info                  DISM   DISM Transmog Provider: PID=8880 TID=212 Audit Mode: [No] - CTransmogManager::Initialize
2014-04-11 11:38:06, Info                  DISM   DISM Transmog Provider: PID=8880 TID=212 GetProductType: ProductType = [WinNT] - CTransmogManager::GetProductType
2014-04-11 11:38:06, Info                  DISM   DISM Transmog Provider: PID=8880 TID=212 Product Type: [WinNT] - CTransmogManager::Initialize
2014-04-11 11:38:06, Info                  DISM   DISM Transmog Provider: PID=8880 TID=212 Product Type ServerNT : [No] - CTransmogManager::Initialize
2014-04-11 11:38:06, Info                  DISM   DISM.EXE: Got the collection of providers. Now enumerating them to build the command table.
2014-04-11 11:38:06, Info                  DISM   DISM.EXE: Attempting to add the commands from provider: DISM Log Provider
2014-04-11 11:38:06, Info                  DISM   DISM.EXE: Attempting to add the commands from provider: OSServices
2014-04-11 11:38:06, Info                  DISM   DISM.EXE: Attempting to add the commands from provider: DISM Package Manager
2014-04-11 11:38:06, Info                  DISM   DISM.EXE: Succesfully registered commands for the provider: DISM Package Manager.
2014-04-11 11:38:06, Info                  DISM   DISM.EXE: Attempting to add the commands from provider: MsiManager
2014-04-11 11:38:06, Info                  DISM   DISM.EXE: Succesfully registered commands for the provider: MsiManager.
2014-04-11 11:38:06, Info                  DISM   DISM.EXE: Attempting to add the commands from provider: IntlManager
2014-04-11 11:38:06, Info                  DISM   DISM.EXE: Succesfully registered commands for the provider: IntlManager.
2014-04-11 11:38:06, Info                  DISM   DISM.EXE: Attempting to add the commands from provider: IBSManager
2014-04-11 11:38:06, Info                  DISM   DISM.EXE: Attempting to add the commands from provider: DriverManager
2014-04-11 11:38:06, Info                  DISM   DISM.EXE: Succesfully registered commands for the provider: DriverManager.
2014-04-11 11:38:06, Info                  DISM   DISM.EXE: Attempting to add the commands from provider: DISM Unattend Manager
2014-04-11 11:38:06, Info                  DISM   DISM.EXE: Succesfully registered commands for the provider: DISM Unattend Manager.
2014-04-11 11:38:06, Info                  DISM   DISM.EXE: Attempting to add the commands from provider: SmiManager
2014-04-11 11:38:06, Info                  DISM   DISM.EXE: Attempting to add the commands from provider: AppxManager
2014-04-11 11:38:06, Info                  DISM   DISM.EXE: Succesfully registered commands for the provider: AppxManager.
2014-04-11 11:38:06, Info                  DISM   DISM.EXE: Attempting to add the commands from provider: AssocManager
2014-04-11 11:38:06, Info                  DISM   DISM.EXE: Succesfully registered commands for the provider: AssocManager.
2014-04-11 11:38:06, Info                  DISM   DISM.EXE: Attempting to add the commands from provider: GenericManager
2014-04-11 11:38:06, Info                  DISM   DISM.EXE: Succesfully registered commands for the provider: GenericManager.
2014-04-11 11:38:06, Info                  DISM   DISM.EXE: Attempting to add the commands from provider: Edition Manager
2014-04-11 11:38:06, Info                  DISM   DISM.EXE: Succesfully registered commands for the provider: Edition Manager.
2014-04-11 11:38:06, Info                  DISM   DISM Provider Store: PID=8880 TID=212 Getting Provider DISM Package Manager - CDISMProviderStore::GetProvider
2014-04-11 11:38:06, Info                  DISM   DISM Provider Store: PID=8880 TID=212 Provider has previously been initialized.  Returning the existing instance. - CDISMProviderStore::Internal_GetProvider
2014-04-11 11:38:06, Info                  DISM   DISM Package Manager: PID=8880 TID=212 Processing the top level command token(cleanup-image). - CPackageManagerCLIHandler::Private_ValidateCmdLine
2014-04-11 11:38:06, Info                  DISM   DISM Package Manager: PID=8880 TID=212 Attempting to route to appropriate command handler. - CPackageManagerCLIHandler::ExecuteCmdLine
2014-04-11 11:38:06, Info                  DISM   DISM Package Manager: PID=8880 TID=212 Routing the command... - CPackageManagerCLIHandler::ExecuteCmdLine
2014-04-11 11:38:06, Info                  DISM   DISM Package Manager: PID=8880 TID=212 CBS session options=0x48100! - CDISMPackageManager::Internal_Finalize
2014-04-11 11:47:13, Info                  DISM   DISM Package Manager: PID=8880 TID=212  - CDISMPackageManager::Internal_Finalize
2014-04-11 11:47:13, Info                  DISM   DISM Package Manager: PID=8880 TID=212 <----- Starting corruption detect/repair info -----> - CDISMPackageManager::Internal_Finalize
Checking System Update Readiness.
Summary:
Operation: Detect and Repair
Operation result: 0x0
Last Successful Step: Entire operation completes.
Total Detected Corruption:     0
     CBS Manifest Corruption:     0
     CBS Metadata Corruption:     0
     CSI Manifest Corruption:     0
     CSI Metadata Corruption:     0
     CSI Payload Corruption:     0
Total Repaired Corruption:     0
     CBS Manifest Repaired:     0
     CSI Manifest Repaired:     0
     CSI Payload Repaired:     0
     CSI Store Metadata refreshed:     True
Total Operation Time: 546 seconds.
  • CDISMPackageManager::Internal_Finalize
2014-04-11 11:47:13, Info                  DISM   DISM Package Manager: PID=8880 TID=212 <----- Ending corruption detect/repair info -----> - CDISMPackageManager::Internal_Finalize
2014-04-11 11:47:13, Info                  DISM   DISM Package Manager: PID=8880 TID=212 Loaded servicing stack for online use only. - CDISMPackageManager::RefreshInstanceAndLock
2014-04-11 11:47:13, Error                 DISM   DISM Package Manager: PID=8880 TID=212 Failed while processing command cleanup-image. - CPackageManagerCLIHandler::ExecuteCmdLine(hr:0x800f081f)
2014-04-11 11:47:13, Info                  DISM   DISM Package Manager: PID=8880 TID=212 Further logs for online package and feature related operations can be found at %WINDIR%\logs\CBS\cbs.log - CPackageManagerCLIHandler::ExecuteCmdLine
2014-04-11 11:47:13, Error                 DISM   DISM.EXE: DISM Package Manager processed the command line but failed. HRESULT=800F081F
2014-04-11 11:47:13, Info                  DISM   DISM Provider Store: PID=8880 TID=212 Found the OSServices.  Waiting to finalize it until all other providers are unloaded. - CDISMProviderStore::Final_OnDisconnect
2014-04-11 11:47:13, Info                  DISM   DISM Provider Store: PID=8880 TID=212 Found the PE Provider.  Waiting to finalize it until all other providers are unloaded. - CDISMProviderStore::Final_OnDisconnect
2014-04-11 11:47:13, Info                  DISM   DISM Provider Store: PID=8880 TID=212 Finalizing the servicing provider(DISM Package Manager) - CDISMProviderStore::Internal_DisconnectProvider
2014-04-11 11:47:13, Info                  DISM   DISM Package Manager: PID=8880 TID=212 Finalizing CBS core. - CDISMPackageManager::Finalize
2014-04-11 11:47:13, Info                  DISM   DISM Provider Store: PID=8880 TID=212 Disconnecting Provider: DISM Package Manager - CDISMProviderStore::Internal_DisconnectProvider
2014-04-11 11:47:13, Info                  DISM   DISM Provider Store: PID=8880 TID=212 Finalizing the servicing provider(MsiManager) - CDISMProviderStore::Internal_DisconnectProvider
2014-04-11 11:47:13, Info                  DISM   DISM Provider Store: PID=8880 TID=212 Disconnecting Provider: MsiManager - CDISMProviderStore::Internal_DisconnectProvider
2014-04-11 11:4
2014-11-29T15:17:47+00:00
 get error 87 when I run the above statement in command prompt running as admin.
Make sure that the cmd window title is:  Administrator: Command Prompt.
Also, I don't think case is a factor but all the help does show it so it may be an idea to fix that too.
Here is another related command which could give you more information
    Dism.exe  /Online  /Cleanup-Image /AnalyzeComponentStore
Otherwise use the  DISM.log  to find out what is going on.  You could also run ProcMon to help find and supplement any other diagnostics which are available.
Good luck
Robert
95 additional answers
    2014-04-15T08:50:31+00:00
    Hi Bill,
    1. What is the exact issue you are facing with the Windows 8.1 update?
    2. Which instructions are you referring to?
    3. Are you deploying Windows 8.1 using image file?
    Please get back to us with the above information to assist you further.
    2014-04-18T20:19:33+00:00
    I did everything that you say,but i still get some strange errors on dism commands and still unable to load update kb2919355.Here is my Dism command results :
    Microsoft Windows [Version 6.3.9600]
    (c) 2013 Microsoft Corporation. Tüm hakları saklıdır.
    C:\WINDOWS\system32>dism /online /remove-package /packagename:Package_for_KB2919
    355~31bf3856ad364e35~amd64~~6.3.1.14
    Version: 6.3.9600.16384
    Logging is disabled: Unable to obtain access to the log file C:\WINDOWS\Logs\DIS
    M\dism.log.
    Image Version: 6.3.9600.16384
    An error occurred trying to open - Package_for_KB2919355~31bf3856ad364e35~amd64~
    ~6.3.1.14 Error: 0x800f0805
    The specified package is not valid Windows package.
    Error: 0x800f0805
    C:\WINDOWS\system32>dism /online /cleanup-image /startcomponentcleanup
    M\dism.log.
    Error: 1
    Yanlış işlev.
    C:\WINDOWS\system32>DISM.exe /Online /Cleanup-image /Restorehealth
    M\dism.log.
    Error: 0x800f081f
    And here is a part of dism.log file.Especially the underlined bold part is interesting  because my laptop is lenovo z510i with intel 4702qm processor not amd .What does it mean?is it a bug,or something that i missunderstand?Or MS's mistake in an update?
    Store: PID=1060 TID=1068 Getting Provider DISMLogger - CDISMProviderStore::GetProvider
    2014-04-18 21:26:26, Info                  DISM   DISM Provider Store: PID=1060 TID=1068 Provider has previously been initialized.  Returning the existing instance. - CDISMProviderStore::Internal_GetProvider
    2014-04-18 21:26:26, Info                  DISM   DISM.EXE:
    2014-04-18 21:26:26, Info                  DISM   DISM.EXE: <----- Starting Dism.exe session ----->
    2014-04-18 21:26:26, Info                  DISM   DISM.EXE: Host machine information: OS Version=6.3.9600, Running architecture=amd64, Number of processors=8
    2014-04-18 21:26:26, Info                  DISM   DISM.EXE: Dism.exe version: 6.3.9600.16384
    2014-04-18 21:26:26, Info                  DISM   DISM.EXE: Executing command line: dism  /online /remove-package /packagename:Package_for_KB2919355~31bf3856ad364e35~amd64~~6.3.1.14
    2014-04-18 21:26:26, Info                  DISM   DISM Provider Store: PID=1060 TID=1068 Getting Provider FolderManager - CDISMProviderStore::GetProvider
    2014-04-18 21:26:26, Info                  DISM   DISM Provider Store: PID=1060 TID=1068 Provider has not previously been encountered.  Attempting to initialize the provider. - CDISMProviderStore::Internal_GetProvider
    2014-04-20T06:34:09+00:00
    I would have you refer to the suggestions provided by Vivian Samartha on April 19, 2014 and check if it helps.
    http://answers.microsoft.com/en-us/windows/forum/windows8_1-windows_update/windows-81-update-1-failing-to-install-with-errors/c3071122-e903-4775-b659-e98784bc786c
    Hope this information helps.
  4. Deleted
