DISM /restoreHealth fails with 0x800f081f AFTER 8.1 update successfully installed
2014-04-11T16:18:28+00:00
I'm concerned about having a machine in a broken state going forward, though.
here's what I ran:
C:\Windows\Logs\CBS>dism /online /cleanup-image /restoreHealth
Deployment Image Servicing and Management tool
Version: 6.3.9600.17031
Image Version: 6.3.9600.17031
[==========================100.0%==========================]
The restore operation failed. Either the repair source was not found or the comp
onent store cannot be repaired.
Error: 0x800f081f
DISM failed. No operation was performed.
For more information, review the log file.
The DISM log file can be found at C:\Windows\Logs\DISM\dism.log
here is the DISM.log:
2014-04-11 11:38:04, Info                  DISM   PID=11556 TID=8436 Scratch directory set to 'C:\Users\tripp\AppData\Local\Temp'. - CDISMManager::put_ScratchDir
2014-04-11 11:38:04, Info                  DISM   PID=11556 TID=8436 DismCore.dll version: 6.3.9600.17031 - CDISMManager::FinalConstruct
2014-04-11 11:38:04, Info                  DISM   PID=11556 TID=8436 Successfully loaded the ImageSession at "C:\Windows\System32\Dism" - CDISMManager::LoadLocalImageSession
2014-04-11 11:38:04, Info                  DISM   DISM Provider Store: PID=11556 TID=8436 Found and Initialized the DISM Logger. - CDISMProviderStore::Internal_InitializeLogger
2014-04-11 11:38:04, Info                  DISM   DISM Provider Store: PID=11556 TID=8436 Failed to get and initialize the PE Provider.  Continuing by assuming that it is not a WinPE image. - CDISMProviderStore::Final_OnConnect
2014-04-11 11:38:04, Info                  DISM   DISM Provider Store: PID=11556 TID=8436 Finished initializing the Provider Map. - CDISMProviderStore::Final_OnConnect
2014-04-11 11:38:04, Info                  DISM   DISM Provider Store: PID=11556 TID=8436 Getting Provider DISMLogger - CDISMProviderStore::GetProvider
2014-04-11 11:38:04, Info                  DISM   DISM Provider Store: PID=11556 TID=8436 Provider has previously been initialized.  Returning the existing instance. - CDISMProviderStore::Internal_GetProvider
2014-04-11 11:38:04, Info                  DISM   DISM Manager: PID=11556 TID=8436 Successfully created the local image session and provider store. - CDISMManager::CreateLocalImageSession
2014-04-11 11:38:04, Info                  DISM   DISM.EXE:
2014-04-11 11:38:04, Info                  DISM   DISM.EXE: <----- Starting Dism.exe session ----->
2014-04-11 11:38:04, Info                  DISM   DISM.EXE: Host machine information: OS Version=6.3.9600, Running architecture=amd64, Number of processors=8
2014-04-11 11:38:04, Info                  DISM   DISM.EXE: Dism.exe version: 6.3.9600.17031
2014-04-11 11:38:04, Info                  DISM   DISM.EXE: Executing command line: dism  /online /cleanup-image /restoreHealth
2014-04-11 11:38:04, Info                  DISM   DISM Provider Store: PID=11556 TID=8436 Getting Provider FolderManager - CDISMProviderStore::GetProvider
2014-04-11 11:38:04, Info                  DISM   DISM Provider Store: PID=11556 TID=8436 Provider has not previously been encountered.  Attempting to initialize the provider. - CDISMProviderStore::Internal_GetProvider
2014-04-11 11:38:04, Info                  DISM   DISM Provider Store: PID=11556 TID=8436 Loading Provider from location C:\Windows\System32\Dism\FolderProvider.dll - CDISMProviderStore::Internal_GetProvider
2014-04-11 11:38:04, Info                  DISM   DISM Provider Store: PID=11556 TID=8436 Connecting to the provider located at C:\Windows\System32\Dism\FolderProvider.dll. - CDISMProviderStore::Internal_LoadProvider
2014-04-11 11:38:04, Info                  DISM   DISM Manager: PID=11556 TID=8436 physical location path: C:\ - CDISMManager::CreateImageSession
2014-04-11 11:38:04, Info                  DISM   DISM Manager: PID=11556 TID=8436 Copying DISM from "C:\Windows\System32\Dism" - CDISMManager::CreateImageSessionFromLocation
2014-04-11 11:38:05, Info                  DISM   DISM Manager: PID=11556 TID=8436 Successfully loaded the ImageSession at "C:\Users\tripp\AppData\Local\Temp\DA023AD7-BFB2-4FA5-9784-B6E1ED49DF38" - CDISMManager::LoadRemoteImageSession
2014-04-11 11:38:05, Info                  DISM   DISM Image Session: PID=8880 TID=212 Instantiating the Provider Store. - CDISMImageSession::get_ProviderStore
2014-04-11 11:38:05, Info                  DISM   DISM Provider Store: PID=8880 TID=212 Initializing a provider store for the IMAGE session type. - CDISMProviderStore::Final_OnConnect
2014-04-11 11:38:05, Info                  DISM   DISM Provider Store: PID=8880 TID=212 Provider has not previously been encountered.  Attempting to initialize the provider. - CDISMProviderStore::Internal_GetProvider
2014-04-11 11:38:05, Info                  DISM   DISM Provider Store: PID=8880 TID=212 Loading Provider from location C:\Users\tripp\AppData\Local\Temp\DA023AD7-BFB2-4FA5-9784-B6E1ED49DF38\OSProvider.dll - CDISMProviderStore::Internal_GetProvider
2014-04-11 11:38:05, Info                  DISM   DISM Provider Store: PID=8880 TID=212 Connecting to the provider located at C:\Users\tripp\AppData\Local\Temp\DA023AD7-BFB2-4FA5-9784-B6E1ED49DF38\OSProvider.dll. - CDISMProviderStore::Internal_LoadProvider
2014-04-11 11:38:05, Info                  DISM   DISM OS Provider: PID=8880 TID=212 Defaulting SystemPath to C:\ - CDISMOSServiceManager::Final_OnConnect
2014-04-11 11:38:05, Info                  DISM   DISM OS Provider: PID=8880 TID=212 Defaulting Windows folder to C:\Windows - CDISMOSServiceManager::Final_OnConnect
2014-04-11 11:38:05, Info                  DISM   DISM OS Provider: PID=8880 TID=212 Host OS verion is 6.3 - CDISMOSServiceManager::SetDllSearchPath
2014-04-11 11:38:05, Info                  DISM   DISM Provider Store: PID=8880 TID=212 Attempting to initialize the logger from the Image Session. - CDISMProviderStore::Final_OnConnect
2014-04-11 11:38:05, Info                  DISM   DISM Provider Store: PID=8880 TID=212 Loading Provider from location C:\Users\tripp\AppData\Local\Temp\DA023AD7-BFB2-4FA5-9784-B6E1ED49DF38\LogProvider.dll - CDISMProviderStore::Internal_GetProvider
2014-04-11 11:38:05, Info                  DISM   DISM Provider Store: PID=8880 TID=212 Connecting to the provider located at C:\Users\tripp\AppData\Local\Temp\DA023AD7-BFB2-4FA5-9784-B6E1ED49DF38\LogProvider.dll. - CDISMProviderStore::Internal_LoadProvider
2014-04-11 11:38:05, Info                  DISM   DISM Provider Store: PID=8880 TID=212 Found and Initialized the DISM Logger. - CDISMProviderStore::Internal_InitializeLogger
2014-04-11 11:38:05, Info                  DISM   DISM Provider Store: PID=8880 TID=212 Loading Provider from location C:\Users\tripp\AppData\Local\Temp\DA023AD7-BFB2-4FA5-9784-B6E1ED49DF38\PEProvider.dll - CDISMProviderStore::Internal_GetProvider
2014-04-11 11:38:05, Warning               DISM   DISM Provider Store: PID=8880 TID=212 Failed to Load the provider: C:\Users\tripp\AppData\Local\Temp\DA023AD7-BFB2-4FA5-9784-B6E1ED49DF38\PEProvider.dll. - CDISMProviderStore::Internal_GetProvider(hr:0x8007007e)
2014-04-11 11:38:05, Info                  DISM   DISM Provider Store: PID=8880 TID=212 Failed to get and initialize the PE Provider.  Continuing by assuming that it is not a WinPE image. - CDISMProviderStore::Final_OnConnect
2014-04-11 11:38:05, Info                  DISM   DISM Provider Store: PID=8880 TID=212 Finished initializing the Provider Map. - CDISMProviderStore::Final_OnConnect
2014-04-11 11:38:05, Info                  DISM   DISM Provider Store: PID=8880 TID=212 Getting Provider DISMLogger - CDISMProviderStore::GetProvider
2014-04-11 11:38:05, Info                  DISM   DISM Provider Store: PID=8880 TID=212 Provider has previously been initialized.  Returning the existing instance. - CDISMProviderStore::Internal_GetProvider
2014-04-11 11:38:05, Info                  DISM   DISM Manager: PID=11556 TID=8436 Image session successfully loaded from the temporary location: C:\Users\tripp\AppData\Local\Temp\DA023AD7-BFB2-4FA5-9784-B6E1ED49DF38 - CDISMManager::CreateImageSession
2014-04-11 11:38:05, Info                  DISM   DISM Provider Store: PID=8880 TID=212 Getting Provider OSServices - CDISMProviderStore::GetProvider
2014-04-11 11:38:05, Info                  DISM   DISM.EXE: Target image information: OS Version=6.3.9600.17031, Image architecture=amd64
2014-04-11 11:38:05, Info                  DISM   DISM Provider Store: PID=8880 TID=212 Getting the collection of providers from an image provider store type. - CDISMProviderStore::GetProviderCollection
2014-04-11 11:38:05, Info                  DISM   DISM Provider Store: PID=8880 TID=212 Loading Provider from location C:\Users\tripp\AppData\Local\Temp\DA023AD7-BFB2-4FA5-9784-B6E1ED49DF38\CbsProvider.dll - CDISMProviderStore::Internal_GetProvider
2014-04-11 11:38:05, Info                  DISM   DISM Provider Store: PID=8880 TID=212 Connecting to the provider located at C:\Users\tripp\AppData\Local\Temp\DA023AD7-BFB2-4FA5-9784-B6E1ED49DF38\CbsProvider.dll. - CDISMProviderStore::Internal_LoadProvider
2014-04-11 11:38:05, Info                  DISM   DISM Provider Store: PID=8880 TID=212 Encountered a servicing provider, performing additional servicing initializations. - CDISMProviderStore::Internal_LoadProvider
2014-04-11 11:38:06, Info                  DISM   DISM Package Manager: PID=8880 TID=212 Finished initializing the CbsConUI Handler. - CCbsConUIHandler::Initialize
2014-04-11 11:38:06, Info                  DISM   DISM Package Manager: PID=8880 TID=212 CBS is being initialized for online use. More information about CBS actions can be located at: %windir%\logs\cbs\cbs.log - CDISMPackageManager::Initialize
2014-04-11 11:38:06, Info                  DISM   DISM Package Manager: PID=8880 TID=212 Loaded servicing stack for online use only. - CDISMPackageManager::RefreshInstanceAndLock
2014-04-11 11:38:06, Info                  DISM   DISM Provider Store: PID=8880 TID=212 Provider has not previously been encountered.  Attempting to initialize the provider. - CDISMProviderStore::Internal_GetProvider
2014-04-11 11:38:06, Info                  DISM   DISM Provider Store: PID=8880 TID=212 Loading Provider from location C:\Users\tripp\AppData\Local\Temp\DA023AD7-BFB2-4FA5-9784-B6E1ED49DF38\MsiProvider.dll - CDISMProviderStore::Internal_GetProvider
2014-04-11 11:38:06, Info                  DISM   DISM Provider Store: PID=8880 TID=212 Connecting to the provider located at C:\Users\tripp\AppData\Local\Temp\DA023AD7-BFB2-4FA5-9784-B6E1ED49DF38\MsiProvider.dll. - CDISMProviderStore::Internal_LoadProvider
2014-04-11 11:38:06, Info                  DISM   DISM Provider Store: PID=8880 TID=212 Encountered a servicing provider, performing additional servicing initializations. - CDISMProviderStore::Internal_LoadProvider
2014-04-11 11:38:06, Info                  DISM   DISM Provider Store: PID=8880 TID=212 Loading Provider from location C:\Users\tripp\AppData\Local\Temp\DA023AD7-BFB2-4FA5-9784-B6E1ED49DF38\IntlProvider.dll - CDISMProviderStore::Internal_GetProvider
2014-04-11 11:38:06, Info                  DISM   DISM Provider Store: PID=8880 TID=212 Connecting to the provider located at C:\Users\tripp\AppData\Local\Temp\DA023AD7-BFB2-4FA5-9784-B6E1ED49DF38\IntlProvider.dll. - CDISMProviderStore::Internal_LoadProvider
2014-04-11 11:38:06, Info                  DISM   DISM Provider Store: PID=8880 TID=212 Loading Provider from location C:\Users\tripp\AppData\Local\Temp\DA023AD7-BFB2-4FA5-9784-B6E1ED49DF38\IBSProvider.dll - CDISMProviderStore::Internal_GetProvider
2014-04-11 11:38:06, Info                  DISM   DISM Provider Store: PID=8880 TID=212 Connecting to the provider located at C:\Users\tripp\AppData\Local\Temp\DA023AD7-BFB2-4FA5-9784-B6E1ED49DF38\IBSProvider.dll. - CDISMProviderStore::Internal_LoadProvider
2014-04-11 11:38:06, Info                  DISM   DISM Provider Store: PID=8880 TID=212 Loading Provider from location C:\Users\tripp\AppData\Local\Temp\DA023AD7-BFB2-4FA5-9784-B6E1ED49DF38\DmiProvider.dll - CDISMProviderStore::Internal_GetProvider
2014-04-11 11:38:06, Info                  DISM   DISM Provider Store: PID=8880 TID=212 Connecting to the provider located at C:\Users\tripp\AppData\Local\Temp\DA023AD7-BFB2-4FA5-9784-B6E1ED49DF38\DmiProvider.dll. - CDISMProviderStore::Internal_LoadProvider
2014-04-11 11:38:06, Info                  DISM   DISM OS Provider: PID=8880 TID=212 Successfully loaded the hive. - CDISMOSServiceManager::DetermineBootDrive
2014-04-11 11:38:06, Info                  DISM   DISM Driver Manager: PID=8880 TID=212 Further logs for driver related operations can be found in the target operating system at %WINDIR%\inf\setupapi.offline.log - CDriverManager::Initialize
2014-04-11 11:38:06, Info                  DISM   DISM Provider Store: PID=8880 TID=212 Loading Provider from location C:\Users\tripp\AppData\Local\Temp\DA023AD7-BFB2-4FA5-9784-B6E1ED49DF38\UnattendProvider.dll - CDISMProviderStore::Internal_GetProvider
2014-04-11 11:38:06, Info                  DISM   DISM Provider Store: PID=8880 TID=212 Connecting to the provider located at C:\Users\tripp\AppData\Local\Temp\DA023AD7-BFB2-4FA5-9784-B6E1ED49DF38\UnattendProvider.dll. - CDISMProviderStore::Internal_LoadProvider
2014-04-11 11:38:06, Info                  DISM   DISM Provider Store: PID=8880 TID=212 Loading Provider from location C:\Users\tripp\AppData\Local\Temp\DA023AD7-BFB2-4FA5-9784-B6E1ED49DF38\Wow64provider.dll - CDISMProviderStore::Internal_GetProvider
2014-04-11 11:38:06, Warning               DISM   DISM Provider Store: PID=8880 TID=212 Failed to get the IDismObject Interface - CDISMProviderStore::Internal_LoadProvider(hr:0x80004002)
2014-04-11 11:38:06, Warning               DISM   DISM Provider Store: PID=8880 TID=212 Failed to Load the provider: C:\Users\tripp\AppData\Local\Temp\DA023AD7-BFB2-4FA5-9784-B6E1ED49DF38\Wow64provider.dll. - CDISMProviderStore::Internal_GetProvider(hr:0x80004002)
2014-04-11 11:38:06, Info                  DISM   DISM Provider Store: PID=8880 TID=212 Loading Provider from location C:\Users\tripp\AppData\Local\Temp\DA023AD7-BFB2-4FA5-9784-B6E1ED49DF38\SmiProvider.dll - CDISMProviderStore::Internal_GetProvider
2014-04-11 11:38:06, Info                  DISM   DISM Provider Store: PID=8880 TID=212 Connecting to the provider located at C:\Users\tripp\AppData\Local\Temp\DA023AD7-BFB2-4FA5-9784-B6E1ED49DF38\SmiProvider.dll. - CDISMProviderStore::Internal_LoadProvider
2014-04-11 11:38:06, Info                  DISM   DISM Provider Store: PID=8880 TID=212 Loading Provider from location C:\Users\tripp\AppData\Local\Temp\DA023AD7-BFB2-4FA5-9784-B6E1ED49DF38\EmbeddedProvider.dll - CDISMProviderStore::Internal_GetProvider
2014-04-11 11:38:06, Warning               DISM   DISM Provider Store: PID=8880 TID=212 Failed to Load the provider: C:\Users\tripp\AppData\Local\Temp\DA023AD7-BFB2-4FA5-9784-B6E1ED49DF38\EmbeddedProvider.dll. - CDISMProviderStore::Internal_GetProvider(hr:0x8007007e)
2014-04-11 11:38:06, Info                  DISM   DISM Provider Store: PID=8880 TID=212 Loading Provider from location C:\Users\tripp\AppData\Local\Temp\DA023AD7-BFB2-4FA5-9784-B6E1ED49DF38\AppxProvider.dll - CDISMProviderStore::Internal_GetProvider
2014-04-11 11:38:06, Info                  DISM   DISM Provider Store: PID=8880 TID=212 Connecting to the provider located at C:\Users\tripp\AppData\Local\Temp\DA023AD7-BFB2-4FA5-9784-B6E1ED49DF38\AppxProvider.dll. - CDISMProviderStore::Internal_LoadProvider
2014-04-11 11:38:06, Info                  DISM   DISM Provider Store: PID=8880 TID=212 Loading Provider from location C:\Users\tripp\AppData\Local\Temp\DA023AD7-BFB2-4FA5-9784-B6E1ED49DF38\AssocProvider.dll - CDISMProviderStore::Internal_GetProvider
2014-04-11 11:38:06, Info                  DISM   DISM Provider Store: PID=8880 TID=212 Connecting to the provider located at C:\Users\tripp\AppData\Local\Temp\DA023AD7-BFB2-4FA5-9784-B6E1ED49DF38\AssocProvider.dll. - CDISMProviderStore::Internal_LoadProvider
2014-04-11 11:38:06, Info                  DISM   DISM Provider Store: PID=8880 TID=212 Loading Provider from location C:\Users\tripp\AppData\Local\Temp\DA023AD7-BFB2-4FA5-9784-B6E1ED49DF38\GenericProvider.dll - CDISMProviderStore::Internal_GetProvider
2014-04-11 11:38:06, Info                  DISM   DISM Provider Store: PID=8880 TID=212 Connecting to the provider located at C:\Users\tripp\AppData\Local\Temp\DA023AD7-BFB2-4FA5-9784-B6E1ED49DF38\GenericProvider.dll. - CDISMProviderStore::Internal_LoadProvider
2014-04-11 11:38:06, Info                  DISM   DISM Provider Store: PID=8880 TID=212 Loading Provider from location C:\Users\tripp\AppData\Local\Temp\DA023AD7-BFB2-4FA5-9784-B6E1ED49DF38\TransmogProvider.dll - CDISMProviderStore::Internal_GetProvider
2014-04-11 11:38:06, Info                  DISM   DISM Provider Store: PID=8880 TID=212 Connecting to the provider located at C:\Users\tripp\AppData\Local\Temp\DA023AD7-BFB2-4FA5-9784-B6E1ED49DF38\TransmogProvider.dll. - CDISMProviderStore::Internal_LoadProvider
2014-04-11 11:38:06, Info                  DISM   DISM Transmog Provider: PID=8880 TID=212 Current image session is [ONLINE] - CTransmogManager::GetMode
2014-04-11 11:38:06, Info                  DISM   DISM Transmog Provider: PID=8880 TID=212 Audit Mode: [No] - CTransmogManager::Initialize
2014-04-11 11:38:06, Info                  DISM   DISM Transmog Provider: PID=8880 TID=212 GetProductType: ProductType = [WinNT] - CTransmogManager::GetProductType
2014-04-11 11:38:06, Info                  DISM   DISM Transmog Provider: PID=8880 TID=212 Product Type: [WinNT] - CTransmogManager::Initialize
2014-04-11 11:38:06, Info                  DISM   DISM Transmog Provider: PID=8880 TID=212 Product Type ServerNT : [No] - CTransmogManager::Initialize
2014-04-11 11:38:06, Info                  DISM   DISM.EXE: Got the collection of providers. Now enumerating them to build the command table.
2014-04-11 11:38:06, Info                  DISM   DISM.EXE: Attempting to add the commands from provider: DISM Log Provider
2014-04-11 11:38:06, Info                  DISM   DISM.EXE: Attempting to add the commands from provider: OSServices
2014-04-11 11:38:06, Info                  DISM   DISM.EXE: Attempting to add the commands from provider: DISM Package Manager
2014-04-11 11:38:06, Info                  DISM   DISM.EXE: Succesfully registered commands for the provider: DISM Package Manager.
2014-04-11 11:38:06, Info                  DISM   DISM.EXE: Attempting to add the commands from provider: MsiManager
2014-04-11 11:38:06, Info                  DISM   DISM.EXE: Succesfully registered commands for the provider: MsiManager.
2014-04-11 11:38:06, Info                  DISM   DISM.EXE: Attempting to add the commands from provider: IntlManager
2014-04-11 11:38:06, Info                  DISM   DISM.EXE: Succesfully registered commands for the provider: IntlManager.
2014-04-11 11:38:06, Info                  DISM   DISM.EXE: Attempting to add the commands from provider: IBSManager
2014-04-11 11:38:06, Info                  DISM   DISM.EXE: Attempting to add the commands from provider: DriverManager
2014-04-11 11:38:06, Info                  DISM   DISM.EXE: Succesfully registered commands for the provider: DriverManager.
2014-04-11 11:38:06, Info                  DISM   DISM.EXE: Attempting to add the commands from provider: DISM Unattend Manager
2014-04-11 11:38:06, Info                  DISM   DISM.EXE: Succesfully registered commands for the provider: DISM Unattend Manager.
2014-04-11 11:38:06, Info                  DISM   DISM.EXE: Attempting to add the commands from provider: SmiManager
2014-04-11 11:38:06, Info                  DISM   DISM.EXE: Attempting to add the commands from provider: AppxManager
2014-04-11 11:38:06, Info                  DISM   DISM.EXE: Succesfully registered commands for the provider: AppxManager.
2014-04-11 11:38:06, Info                  DISM   DISM.EXE: Attempting to add the commands from provider: AssocManager
2014-04-11 11:38:06, Info                  DISM   DISM.EXE: Succesfully registered commands for the provider: AssocManager.
2014-04-11 11:38:06, Info                  DISM   DISM.EXE: Attempting to add the commands from provider: GenericManager
2014-04-11 11:38:06, Info                  DISM   DISM.EXE: Succesfully registered commands for the provider: GenericManager.
2014-04-11 11:38:06, Info                  DISM   DISM.EXE: Attempting to add the commands from provider: Edition Manager
2014-04-11 11:38:06, Info                  DISM   DISM.EXE: Succesfully registered commands for the provider: Edition Manager.
2014-04-11 11:38:06, Info                  DISM   DISM Provider Store: PID=8880 TID=212 Getting Provider DISM Package Manager - CDISMProviderStore::GetProvider
2014-04-11 11:38:06, Info                  DISM   DISM Provider Store: PID=8880 TID=212 Provider has previously been initialized.  Returning the existing instance. - CDISMProviderStore::Internal_GetProvider
2014-04-11 11:38:06, Info                  DISM   DISM Package Manager: PID=8880 TID=212 Processing the top level command token(cleanup-image). - CPackageManagerCLIHandler::Private_ValidateCmdLine
2014-04-11 11:38:06, Info                  DISM   DISM Package Manager: PID=8880 TID=212 Attempting to route to appropriate command handler. - CPackageManagerCLIHandler::ExecuteCmdLine
2014-04-11 11:38:06, Info                  DISM   DISM Package Manager: PID=8880 TID=212 Routing the command... - CPackageManagerCLIHandler::ExecuteCmdLine
2014-04-11 11:38:06, Info                  DISM   DISM Package Manager: PID=8880 TID=212 CBS session options=0x48100! - CDISMPackageManager::Internal_Finalize
2014-04-11 11:47:13, Info                  DISM   DISM Package Manager: PID=8880 TID=212  - CDISMPackageManager::Internal_Finalize
2014-04-11 11:47:13, Info                  DISM   DISM Package Manager: PID=8880 TID=212 <----- Starting corruption detect/repair info -----> - CDISMPackageManager::Internal_Finalize
Checking System Update Readiness.
Summary:
Operation: Detect and Repair
Operation result: 0x0
Last Successful Step: Entire operation completes.
Total Detected Corruption:     0
     CBS Manifest Corruption:     0
     CBS Metadata Corruption:     0
     CSI Manifest Corruption:     0
     CSI Metadata Corruption:     0
     CSI Payload Corruption:     0
Total Repaired Corruption:     0
     CBS Manifest Repaired:     0
     CSI Manifest Repaired:     0
     CSI Payload Repaired:     0
     CSI Store Metadata refreshed:     True
Total Operation Time: 546 seconds.
  • CDISMPackageManager::Internal_Finalize
2014-04-11 11:47:13, Info                  DISM   DISM Package Manager: PID=8880 TID=212 <----- Ending corruption detect/repair info -----> - CDISMPackageManager::Internal_Finalize
2014-04-11 11:47:13, Info                  DISM   DISM Package Manager: PID=8880 TID=212 Loaded servicing stack for online use only. - CDISMPackageManager::RefreshInstanceAndLock
2014-04-11 11:47:13, Error                 DISM   DISM Package Manager: PID=8880 TID=212 Failed while processing command cleanup-image. - CPackageManagerCLIHandler::ExecuteCmdLine(hr:0x800f081f)
2014-04-11 11:47:13, Info                  DISM   DISM Package Manager: PID=8880 TID=212 Further logs for online package and feature related operations can be found at %WINDIR%\logs\CBS\cbs.log - CPackageManagerCLIHandler::ExecuteCmdLine
2014-04-11 11:47:13, Error                 DISM   DISM.EXE: DISM Package Manager processed the command line but failed. HRESULT=800F081F
2014-04-11 11:47:13, Info                  DISM   DISM Provider Store: PID=8880 TID=212 Found the OSServices.  Waiting to finalize it until all other providers are unloaded. - CDISMProviderStore::Final_OnDisconnect
2014-04-11 11:47:13, Info                  DISM   DISM Provider Store: PID=8880 TID=212 Found the PE Provider.  Waiting to finalize it until all other providers are unloaded. - CDISMProviderStore::Final_OnDisconnect
2014-04-11 11:47:13, Info                  DISM   DISM Provider Store: PID=8880 TID=212 Finalizing the servicing provider(DISM Package Manager) - CDISMProviderStore::Internal_DisconnectProvider
2014-04-11 11:47:13, Info                  DISM   DISM Package Manager: PID=8880 TID=212 Finalizing CBS core. - CDISMPackageManager::Finalize
2014-04-11 11:47:13, Info                  DISM   DISM Provider Store: PID=8880 TID=212 Disconnecting Provider: DISM Package Manager - CDISMProviderStore::Internal_DisconnectProvider
2014-04-11 11:47:13, Info                  DISM   DISM Provider Store: PID=8880 TID=212 Finalizing the servicing provider(MsiManager) - CDISMProviderStore::Internal_DisconnectProvider
2014-04-11 11:47:13, Info                  DISM   DISM Provider Store: PID=8880 TID=212 Disconnecting Provider: MsiManager - CDISMProviderStore::Internal_DisconnectProvider
2014-04-11 11:4
2014-11-29T15:17:47+00:00
 get error 87 when I run the above statement in command prompt running as admin.
Make sure that the cmd window title is:  Administrator: Command Prompt.
Also, I don't think case is a factor but all the help does show it so it may be an idea to fix that too.
Here is another related command which could give you more information
    Dism.exe  /Online  /Cleanup-Image /AnalyzeComponentStore
Otherwise use the  DISM.log  to find out what is going on.  You could also run ProcMon to help find and supplement any other diagnostics which are available.
Good luck
Robert
95 additional answers
    2014-06-02T20:50:26+00:00
    I think I've found the way to do this via http://www.eightforums.com/tutorials/26095-repair-install-windows-8-a.html.
    It states clearly that "If you have Windows 8.1 Update installed, then you must use a Windows 8.1 Update ISO."
    If I download the ISO for 8.1 will it be the 8.1 update ISO or just the 8.1 ISO? I have 8.1 update installed so it says I need the ISO that contains the update in it? Ronnie - did you have 8.1 update already installed or were you having trouble installing the update? If already installed, wouldn't the ISO install the update too and therefore not need to re-install Kb2919355?
    The post you referenced looks to be about a year old, so I don't know how relevant the links are right now, but it did include some good instructions on cleaning up after the re-install to reclaim disk space.
    I used the instructions on the following site:
    http://mcakins.com/2013/10/19/download-windows-8-1-iso-using-you-windows-8-0-key/
    I downloaded the ISO file and burned it to a DVD so I always have it handy, just in case.
    I was able to find the generic key codes that you will need for the repair install on the following site:
    http://dellwindowsreinstallationguide.com/a-clean-install-of-windows/microsoft-product-activation/installation-of-windows-8-1-with-a-windows-8-0-retail-product-key-notes/
    To perform the in-place repair install, simply boot into your system normally without the DVD in the drive.  Then, insert the DVD, navigate to it's folder and double-click "setup.exe".  Remember to select that you want to keep all files, folders and programs when prompted.  Also, when it reboots several times during the install, always let it reboot from your hard drive.  Don't select the "press any key to boot from CD/DVD" if prompted.
    The Windows 8.1 ISO file I downloaded from the first website's Microsoft link did not contain any updates, so you have to download all of them via Windows Update, but it goes fairly quickly if you have high-speed internet.
    Yes, I had the update already installed on my system, but the re-install deletes all the user-installed updates.  I never originally had a problem installing KB2919355, but I did have the DISM component store corruption issues and the Chinese characters in the DISM log.  That's why I re-installed.
    Note that after the repair install, you will need to change to your actual Win 8.0 or Win 8.1 key code so you can activate Windows.  In my case, I have a retail DVD of Windows 8.0 that I originally purchased and used that key code.  I do not know if you can use an OEM key code to activate it.
    However, Microsoft is pretty good about helping out with activation issues in re-installs.  They have a dedicated telephone number for this (sorry, I don't have it now) and they are usually quick to help you.
    While you should not have any problems with the repair install, I would definitely recommend first making a backup image of your hard drive with a 3rd party imaging program.  That way, in case you run into trouble, you can revert everything back to way it was.  Good luck if you decide to try it and feel free to ask if you have any more questions.
    2014-06-02T21:10:53+00:00
     does anyone know where all the Chinese characters are originating?
    For DISM you could use its /LogLevel: and /LogPath: operands to avoid it.
    Otherwise I would wonder if you had some of the real corruption that this poster saw regarding dism.exe itself.
    http://answers.microsoft.com/en-us/windows/forum/windows8_1-windows_update/issue-with-installing-updates-on-windows-81/24b91da6-fdbe-42dd-96c6-3cc91062054b?page=5&tm=1401734795434
    Care to check your results for the same Powershell pipeline?
    PS C:\windows> dir -Filter "*dism.exe" -Recurse  -ErrorAction:SilentlyContinue ft Length, FullName -AutoSize -HideTableHeaders
    Note that shows you the complete command line including the prefix, so you know where to start it from.  In view of the fact that we were both having problems with Authorization (which accounts for the ErrorAction switch) it would probably be a good idea to do this in the Administrator Powershell window.  Then in order to get back to the desired directory level all you would need to enter from being at the Admin default of  $env:windir\System32  would be:  cd ..
    BTW the AutoSize switch only sizes according to the size of the window so it may help to make your window bigger than it already is, e.g. if necessary wider than Maximized.
    HTH
    Robert
    2014-06-02T21:13:01+00:00
    Thanks Ronnie. I greatly appreciate your help. I think I'm going to hold off doing the repair reinstall until after the June updates and/or I run into additional computer problems. I might try to save a copy of the Windows 8.1 ISO file though now for possible future use.
    I'm hoping the Dism restorehealth error is not valid the component store isn't corrupt. The Chinese characters sure make it seem like there is a bug.
    2014-06-02T21:34:27+00:00
    That sounds like a good idea.  When I had the DISM errors. I never noticed any other problems with my system, so it could just be a bug in DISM that was introduced with the KB2919355 update.
    Yes, I would download the ISO and burn it into a DVD now, just so you have it.  Also make a note of the generic key codes you'll need to  install.
    Unless you run into a serious problem preventing you from booting into Windows at all, the in-place repair install is always a future option for you.  Best regards.
