Can't start Dolby Audio driver after upgrading to Windows 8.1
2013-10-18T07:27:19+00:00
Lenovo U410 wirh Windows 8 pre-installed.
Upgrade to 8.1 went flawlessly, but every time I re-start or boot up the machine I get this:
I've uninstalled and re-installed Dolby Home Theater, done an extensive local and web search about this.
There appears to be NO mention on my machine anywhere for a Dolby Audio Driver" or anything that uses it.
I've been on the Lenovo forum and there's a thread there that says to disable driver signature, which I've done to no effect.
I still get this message.
Can anyone throw any light on this?
2013-10-28T16:20:59+00:00
Hi Everyone!!
I did something to my laptop and it worked!!! After messing around the fix was simple!
Of course make sure your computer has all the windows updates. I don't know if that's gonna be a contributing factor, but it was part of my methods.
After that go into your "D Drive" which is found under "My computer" --> "Drivers" -->"Audio"
Once you're in the audio folder, you're gonna scroll down, you will see a computer icon that says "setup" click on that. Once you do that you will follow the instructions. It seems by doing this it updates the conextant audio driver. I don't know why it didn't update in the device manager as others have suggested. But after I did this, I checked to make sure it was fixed
You can see if it was fixed by:
Going into your control panel and clicking the Dolby theater which can be found in the sounds, games, etc. --> you should see the actual program pop up instead of the error message!
I am so glad I finally fixed this! If this helps you, please label it as the answer so everyone else can fix theirs too! It seems to be a major issue
Have an "error" free day!
2014-02-04T00:06:17+00:00
Lenovo has updated the Conexant Audio Drivers for Windows 8.1 to correct this error.  You can download the updated drivers for your device at http://support.lenovo.com/en\_US/downloads/default.page.
147 additional answers
    2013-11-24T20:50:06+00:00
    thanks, when you explained it that way I was able to do it... IT WORKS!!!!
    2013-11-25T05:41:03+00:00
    I tried about 15 times to do the steps listed above. It did not work for me
    I  had to completely uninstall the Conexant Smart Audio HD driver and re-install from the Lenovo website. I have a Lenovo Yoga 13. Now that I have done that, Dolby Home Theatre v4 works.
    For those of you who can't get the above steps to work, you can try this:
    Follow steps 1 through 3 above. Once the Confirm device Uninstall window appears, make sure the "Delete the driver software" box is checked, then click uninstall.
    Go to website below and install the driver.
    http://support.lenovo.com/en_US/downloads/default.page?selector=expand
    same here, except I have an Idea Pad u410.  Your method worked for me so thank you!!
    2013-11-30T21:28:42+00:00
    Thanks so much! This worked for me!
