Can't start Dolby Audio driver after upgrading to Windows 8.1
2013-10-18T07:27:19+00:00
Lenovo U410 wirh Windows 8 pre-installed.
Upgrade to 8.1 went flawlessly, but every time I re-start or boot up the machine I get this:
I've uninstalled and re-installed Dolby Home Theater, done an extensive local and web search about this.
There appears to be NO mention on my machine anywhere for a Dolby Audio Driver" or anything that uses it.
I've been on the Lenovo forum and there's a thread there that says to disable driver signature, which I've done to no effect.
I still get this message.
Can anyone throw any light on this?
2013-10-28T16:20:59+00:00
Hi Everyone!!
I did something to my laptop and it worked!!! After messing around the fix was simple!
Of course make sure your computer has all the windows updates. I don't know if that's gonna be a contributing factor, but it was part of my methods.
After that go into your "D Drive" which is found under "My computer" --> "Drivers" -->"Audio"
Once you're in the audio folder, you're gonna scroll down, you will see a computer icon that says "setup" click on that. Once you do that you will follow the instructions. It seems by doing this it updates the conextant audio driver. I don't know why it didn't update in the device manager as others have suggested. But after I did this, I checked to make sure it was fixed
You can see if it was fixed by:
Going into your control panel and clicking the Dolby theater which can be found in the sounds, games, etc. --> you should see the actual program pop up instead of the error message!
I am so glad I finally fixed this! If this helps you, please label it as the answer so everyone else can fix theirs too! It seems to be a major issue
Have an "error" free day!
2014-02-04T00:06:17+00:00
Lenovo has updated the Conexant Audio Drivers for Windows 8.1 to correct this error.  You can download the updated drivers for your device at http://support.lenovo.com/en\_US/downloads/default.page.
147 additional answers
    2013-11-03T07:59:04+00:00
    Reloading the drivers from the backup D: drive or from the Lenovo website didn't work for me. I still get the error message. It didn't work to update from device manager. I had another Windows update (after the 8.1 update) and it knocked out my sound completely. I reloaded the drivers and the sound works but I still get the error message
    2013-11-03T20:28:56+00:00
    I tried all of these steps and none of them worked. I even went to the Lenovo website and installed the Conexant Smart Audio software again and it still doesn't let me install Home Theater.
    2013-11-05T03:01:05+00:00
    Hi Everyone!!
    This worked for me! Try this if the other previously mentioned options do not work for you!!
