Nokia Lumia 520( cyan) : Airplane mode stuck and rapidly switching on and off
2014-09-29T05:41:13+00:00
Find my details:-
software: windows phone 8.1
OS version: 8.10.12393.890
Firmware revision number: 3058.50000.1525.0001
Hardware revision number: 1.5.0.1
radio software version: 2.0.242037.8
chip SOC version: 8227
Extras+info
Lumia cyan
Device activation client 1.4.2.9
Firmware Updater Notifier 1.1.03
..... and so on
Manufacturer:-
RM-914_im_india_269
I was using Lumia Black and updated it to 8.1 ( Cyan) from my phone itself ( official release). I updated to Cyan OS not longer than a month back. Everything was fine, until recently, a couple of days earlier, when I was talking to a freind of mine on my phone, the call dropped. A notification to restart my phone appered so I did it. Ever since I am stuck on the , " Airplane mode". The flight mode will rapidly switch on and off. So, I am unable to use my Sim and thus, no whatsapp, no calls..social life has been paralyzed.
I tried Hard reset ( about menu-> reset your phone) :- three times
Soft reset:- several times
Changed SIM :- a dozen times
Tried the twitter team suggestion ( I had found on this forum itself :- http://discussions.nokia.com/t5/Nokia-Lumia/Lumia-1520-3-and-official-8-1-stuck-airplane-mode/td-p/2855086)
Now trying Nokia Software Recovery Tool 1.5.0 but the problem is that it is downloading 3058.50000.1425.0001, which I beleive is 'Cyan' again. I am also worried, I won't be able to downgrade to Lumia black  which I am missing a lot. Anwho, I am  currently downloading it and will see what happens, but If Nokia's Technical team can provide a solution for this software/firmware related glitch, I will be a happy fella. I am wondering, about the first occurence of this problem which I researched as being reported on Nokia official forums, 2-3 months back. By now a trustworthy solution should have been found and posted online.
    2014-10-16T16:14:57+00:00
    Have you tried dowgrading to 8.0 yet??? Does it work?
    I'm facing this issue too and really don't want to wipe GBs of Apps and Dictionaries on my 520.
    2014-10-17T11:43:23+00:00
    Airplane mode doesnt want to switch off on lumia 520
    Moderator's Note: The subject was edited as we have merged it to an existing and a more appropriate thread.
    2014-10-17T14:28:39+00:00
    hi mate are u up to date with the latest Nokia system app updates from the Store along with the latest firmware? also check that your microSIM is cut correctly and try performing a soft reset.
  4. Deleted
    2014-10-19T13:12:52+00:00
    Yes, I noticed in my phone also IMEI no is missing. That's strange. If we can recover the IMEI no. somehow probably the phone could work (with a SIM card) i guess...but the question is HOW?
    POST if you find anything.
    AND
    NO, THE PHONE CANNOT BE DOWNGRADED FROM 8.1 TO 8
    TRIED FOR IT BUT NO SUCH METHOD YET
