same with my lumia 520, i have tried to restore my phone from factory reset and still airplane stuck mode . may anyone have advice
Nokia Lumia 520( cyan) : Airplane mode stuck and rapidly switching on and off
Find my details:-
software: windows phone 8.1
OS version: 8.10.12393.890
Firmware revision number: 3058.50000.1525.0001
Hardware revision number: 1.5.0.1
radio software version: 2.0.242037.8
chip SOC version: 8227
Extras+info
Lumia cyan
Device activation client 1.4.2.9
Firmware Updater Notifier 1.1.03
..... and so on
Manufacturer:-
RM-914_im_india_269
I was using Lumia Black and updated it to 8.1 ( Cyan) from my phone itself ( official release). I updated to Cyan OS not longer than a month back. Everything was fine, until recently, a couple of days earlier, when I was talking to a freind of mine on my phone, the call dropped. A notification to restart my phone appered so I did it. Ever since I am stuck on the , " Airplane mode". The flight mode will rapidly switch on and off. So, I am unable to use my Sim and thus, no whatsapp, no calls..social life has been paralyzed.
I tried Hard reset ( about menu-> reset your phone) :- three times
Soft reset:- several times
Changed SIM :- a dozen times
Tried the twitter team suggestion ( I had found on this forum itself :- http://discussions.nokia.com/t5/Nokia-Lumia/Lumia-1520-3-and-official-8-1-stuck-airplane-mode/td-p/2855086)
Now trying Nokia Software Recovery Tool 1.5.0 but the problem is that it is downloading 3058.50000.1425.0001, which I beleive is 'Cyan' again. I am also worried, I won't be able to downgrade to Lumia black which I am missing a lot. Anwho, I am currently downloading it and will see what happens, but If Nokia's Technical team can provide a solution for this software/firmware related glitch, I will be a happy fella. I am wondering, about the first occurence of this problem which I researched as being reported on Nokia official forums, 2-3 months back. By now a trustworthy solution should have been found and posted online.
2014-10-12T22:50:05+00:00 -
2014-10-13T02:25:52+00:00 hi mate have u tried checking that your microSIM card is cut correctly and that u r in an area of decent network coverage befroe?
2014-10-13T05:07:44+00:00 Hello Guys, I went to Nokia Care and after inspecting my phone, they told me that the network chip of my phone's MOTHERBOARD has issues, They are charging INR3500/- odd something for a phone worth 7000 bucks.
The local repair store is telling the same thing and offered me change of motherboard for INR 1900.
My phone is outta warranty and I ain't getting it replaced. Will use it as a Tablet since WIFI works fine and everything else except for SIM card.
I even use whatsapp on my phone using the WIFI..
Done with Lumia for the rest of my life.
However If someone finds a solution plz reply on this page...meanwhile I Will try NOKIA SOFTWARE RECOVERY TOOL for the last time and post soon.
2014-10-13T05:08:40+00:00 :- Yes, Been there done that..ain't working
2014-10-16T02:32:10+00:00 I have also been facing the same probllem after some days of successful running of the cyan update. I have tried all kind of soiutions avaliable on the net but am unable to fix the same. Only recently did i notice that the IMEI no in the phone has been wiped off and it is showing blank.
Is there a process to restore/update the IMEI no in the phone?? I hope if I can restore the IMEI no the phone might work.
