flite mode automatically on - off hota he
Nokia Lumia 520( cyan) : Airplane mode stuck and rapidly switching on and off
Find my details:-
software: windows phone 8.1
OS version: 8.10.12393.890
Firmware revision number: 3058.50000.1525.0001
Hardware revision number: 1.5.0.1
radio software version: 2.0.242037.8
chip SOC version: 8227
Extras+info
Lumia cyan
Device activation client 1.4.2.9
Firmware Updater Notifier 1.1.03
..... and so on
Manufacturer:-
RM-914_im_india_269
I was using Lumia Black and updated it to 8.1 ( Cyan) from my phone itself ( official release). I updated to Cyan OS not longer than a month back. Everything was fine, until recently, a couple of days earlier, when I was talking to a freind of mine on my phone, the call dropped. A notification to restart my phone appered so I did it. Ever since I am stuck on the , " Airplane mode". The flight mode will rapidly switch on and off. So, I am unable to use my Sim and thus, no whatsapp, no calls..social life has been paralyzed.
I tried Hard reset ( about menu-> reset your phone) :- three times
Soft reset:- several times
Changed SIM :- a dozen times
Tried the twitter team suggestion ( I had found on this forum itself :- http://discussions.nokia.com/t5/Nokia-Lumia/Lumia-1520-3-and-official-8-1-stuck-airplane-mode/td-p/2855086)
Now trying Nokia Software Recovery Tool 1.5.0 but the problem is that it is downloading 3058.50000.1425.0001, which I beleive is 'Cyan' again. I am also worried, I won't be able to downgrade to Lumia black which I am missing a lot. Anwho, I am currently downloading it and will see what happens, but If Nokia's Technical team can provide a solution for this software/firmware related glitch, I will be a happy fella. I am wondering, about the first occurence of this problem which I researched as being reported on Nokia official forums, 2-3 months back. By now a trustworthy solution should have been found and posted online.
2017-11-02T07:52:08+00:00 -
Deleted
2018-07-25T08:33:21+00:00 I have also been facing the same probllem after some days of successful running of the cyan update. I have tried all kind of soiutions avaliable on the net but am unable to fix the same. Only recently did i notice that the IMEI no in the phone has been wiped off and it is showing blank.
Is there a process to restore/update the IMEI no in the phone?? I hope if I can restore the IMEI no the phone might work.
I have also been facing the same after some days of successful running of the cyan update.i have tried all kinds of solution available on the net but am unable to fix it. Only recently did i notice that the IMEI number in the phone has been wiped off and flightmode refused to go off.is there a process to restore or update the IMEI number in the phone?
2018-07-25T08:50:55+00:00 After long wait for an answer and frustration, I decided to change my phone and keep that device as a tablet
2018-07-25T09:05:40+00:00 Yes I moved onto Android phones and what a difference from that Windows rubbish. I've kept mine as a sat-nav running copilot as an emergency spare but nearly binned the junk.
