Having trouble: Adding RAM with a USB memory stick to a Windows XP desktop that has 4GB installed
2014-03-22T21:13:11+00:00
Short form:
I want to use a 16GB USB flash drive memory stick as RAM, but seem to be unable to use more than 4GB, due to the system requirements, limiting what I can enter for values (size). WHY??
More detail:
The computer is a desktop machine, having a 3.0GHz dual-core processor, and 4GB RAM installed. I believe the hard drive is a 1T.
I have a 16GB USB flash drive memory stick, which I want to use to boost the RAM, for games, and such. There are 3 spare USB ports on the back of the tower. The flash drive is new, with NO files saved on it.
When I go into the Settings; Computer; Virtual Memory, the computer is not allowing me to enter a value greater than 4096 in the field for "Initial Size" or "Maximum Size", for the Page File of the USB drive.
The Value for C: that I see is: "2096-4092".
Main Question:
Is there some reason why I cannot allocate more of the memory stick for RAM?
(Does the flash drive need to be formatted?)
Does the values for C: need to be changed?
I presently have "4090" entered for values "Initial Size" and "Maximum Size" in the custom size, for the Page File of the USB Drive.
Screenshot provided of Virtual Memory Settings screen: (you can see the L: drive settings (selected), and the C: settings, also)
http://prntscr.com/336ocy
Question 2:
Also, is the "4G" of RAM which I have added to the machine, being added to the 4GB which is already installed in the tower?
Question 3:
Does the OS wait until the system RAM is full before using the External RAM?
Thanks!
edit to add:
What I learned from Microsoft article "How To Set Performance Options in Windows XP":
http://support.microsoft.com/kb/308417/en-us
To manually change the size of virtual memory, follow these steps:
...Note After you change the size of the paging file, you may be prompted to restart Windows. If you are prompted to restart, the changes will not take effect until Windows is restarted.
  • To have Windows select the best paging file size, click System managed size. The recommended minimum size is the same as 1.5 times the RAM on your computer, and 3 times that figure for the maximum size. For example, if you have 256 MB of RAM, the minimum size is 384 MB, and the maximum size is 1152 MB.
  • For best performance, do not set the initial size to less than the minimum recommended size under Total paging file size for all drives. The recommended size is the same as 1.5 times the RAM on your computer. It is good practice to leave the paging file at its recommended size as performance can decrease if a paging file is too large. However, you may increase its size if you frequently use programs that use lots of memory, such as graphics programs or games.
What I am unclear of here, is that, as you can see in the screenshot, the Recommended Size under Total paging file size for all drives is 3019M.
And, the values set for the Paging File in C are 2046-4092.
The tower has been rebuilt, and has 4GB RAM.
I do not know if these numbers reflect an original build of 2GB, whereas 3GB (3019M) would be 1.5 times the installed RAM, perhaps.
Under Virtual Memory, I see the following (shown in screenshot):
Drive C
Space available: 725194MB
*Custom Size
Initial Size: 2046
Maximum Size: 4092
Total paging file size for all Drives
Minimum allowed: 2MB
Recommended: 3019MB
Currently Allocated: 2046MB
Given that the system has 4GB RAM installed, shouldn't the minimum be 1.5 times that value, or ~6000MB ? (not 3019MB), and the maximum be 3 times ? (not 4092)
"The recommended minimum size is the same as 1.5 times the RAM on your computer, and 3 times that figure for the maximum size."
Can I change the values on the Virtual memory for C drive to 2046-12000MB ?
That is what I am reading from the article. But, it also says to not have a paging file on the same drive as the programs.
"Try to avoid having a paging file on the same drive as the system files, usually drive C."
Also, why am I unable to enter values greater than 4096 for the USB drive in Initial or Maximum?
I also have a question as to whether I should select "Programs" or "System Cache" in memory usage, due to the cache requirements of games, running very few programs.
edit 2:
I learned that the usb drive needs to be formatted in NTFS, so I did that, which isn't easy, as that isn't a selection in the choices in the Format menu, without going into Device Mgr.
A friend was telling me about formatting a usb drive ex-fat for a newer application, and got me thinking. I had selected FAT32 for this one, and had noticed no change in the page file graph usage after adding the drive, like it wasn't getting any data placed on it.
So, as custom settings for this USB drive, I have the Initial value at 4091 and the Maximum at 4096, with "System Cache" selected as opposed to "Programs" in Memory usage, in Performance settings.
Any answers or tips would be appreciated.
Am I on the right track?
    2014-03-27T17:52:27+00:00
    I am a little confused, because I ran tasklist once, and posted the results. You asked me to run it again and post the text doc of the running processes on the machine.
    Is this different than what I had already posted? So, when I ran it, it automatically overwrote the text doc, but didn't open it?
    Yeah, you made one post with the results of the NET USE command only and when I replied I hadn't seen the other post that also included the results of the TASKLIST command.
    If you could please post the results again but please reboot the machine and let it settled down a bit (a minute or two) and run the commands again before you open programs and start using the computer, I would like to see the started services and processes when the machine is freshly booted.  Also post a snapshot again of the Task Manager's performance tab taken when the machine is freshly booted and before you open programs and start using the computer, that way we will get a better idea of the state of the machine when it boots.
    Again, the commands to run are:
    net start >C:\services.txt
    tasklist /svc >>C:\services.txt
    C:\services.txt
    John
    2014-03-27T19:26:41+00:00
    Got it.
    I just ran those command again, but I have things running, so the results will likely be similar to what is already posted.
    I will reboot, allow a couple minutes, run again, and then post.
    Thanks for your patience!
    Barry
    2014-03-27T19:43:30+00:00
    After rebooting, and allowing a few minutes idle:
    Opened Task Mgr, and immediately opened Comodo Dragon browser (one tab open on this site), took this screenshot:
    2014-03-27T19:44:42+00:00
    Executing the following commands
    C:\services.txt
    produced this:
    These Windows services are started:
       Agere Modem Call Progress Audio
       Application Layer Gateway Service
       Automatic Updates
       AVG WatchDog
       AVGIDSAgent
       COM+ Event System
       COMODO Dragon Update Service
       Computer Browser
       Cryptographic Services
       DCOM Server Process Launcher
       DHCP Client
       DNS Client
       Event Log
       Fast User Switching Compatibility
       HID Input Service
       HTTP SSL
       IPSEC Services
       Java Quick Starter
       MBAMScheduler
       Network Connections
       Network Location Awareness (NLA)
       Plug and Play
       Pml Driver HPZ12
       Print Spooler
       Protected Storage
       RealNetworks Downloader Resolver Service
       Remote Access Connection Manager
       Remote Procedure Call (RPC)
       SeaPort
       Secondary Logon
       Security Accounts Manager
       Security Center
       Server
       Shell Hardware Detection
       SSDP Discovery Service
       System Event Notification
       System Restore Service
       TeamViewer 8
       Telephony
       Terminal Services
       Themes
       TimesUpKidz
       vToolbarUpdater18.0.5
       Windows Audio
       Windows Driver Foundation - User-mode Driver Framework
       Windows Firewall/Internet Connection Sharing (ICS)
       Windows Image Acquisition (WIA)
       Windows Live ID Sign-in Assistant
       Windows Management Instrumentation
       Wireless Zero Configuration
       Workstation
    The command completed successfully.
    Image Name                   PID Services
    System Idle Process            0 N/A
    System                         4 N/A
    smss.exe                     632 N/A
    avgrsx.exe                   672 N/A
    avgcsrvx.exe                 712 N/A
    csrss.exe                    916 N/A
    winlogon.exe                 940 N/A
    services.exe                 984 Eventlog, PlugPlay
    lsass.exe                    996 PolicyAgent, ProtectedStorage, SamSs
    svchost.exe                 1160 DcomLaunch, TermService
    svchost.exe                 1232 RpcSs
    svchost.exe                 1328 AudioSrv, Browser, CryptSvc, Dhcp,
                                     EventSystem, FastUserSwitchingCompatibility,
                                     HidServ, lanmanserver, lanmanworkstation,
                                     Netman, Nla, RasMan, seclogon, SENS,
                                     SharedAccess, ShellHWDetection, srservice,
                                     TapiSrv, Themes, winmgmt, wscsvc, wuauserv,
                                     WZCSVC
    svchost.exe                 1368 WudfSvc
    svchost.exe                 1432 Dnscache
    spoolsv.exe                 1572 Spooler
    agrsmsvc.exe                1792 AgereModemAudio
    avgidsagent.exe             1804 AVGIDSAgent
    avgwdsvc.exe                1836 avgwd
    dragon_updater.exe          1884 DragonUpdater
    jqs.exe                     2016 JavaQuickStarterService
    mbamscheduler.exe           2044 MBAMScheduler
    GoogleUpdate.exe             152 N/A
    avgnsx.exe                   580 N/A
    HPZipm12.exe                 596 Pml Driver HPZ12
    avgemcx.exe                  612 N/A
    rndlresolversvc.exe         1128 RealNetworks Downloader Resolver Service
    SeaPort.exe                  396 SeaPort
    svchost.exe                 1184 stisvc
    TeamViewer_Service.exe      1320 TeamViewer8
    ToolbarUpdater.exe          1496 vToolbarUpdater18.0.5
    WLIDSVC.EXE                 1632 wlidsvc
    loggingserver.exe           2132 N/A
    explorer.exe                2200 N/A
    TimesUpKidzServer.exe       2296 TimesUpKidz
    igfxtray.exe                2472 N/A
    hkcmd.exe                   2480 N/A
    igfxpers.exe                2492 N/A
    igfxsrvc.exe                2524 N/A
    WLIDSVCM.EXE                2636 N/A
    vprot.exe                   2728 N/A
    RTHDCPL.EXE                 2768 N/A
    avgui.exe                   2932 N/A
    jusched.exe                 2968 N/A
    FacebookUpdate.exe          2984 N/A
    Lightshot.exe               3064 N/A
    ctfmon.exe                  3108 N/A
    svchost.exe                 3644 SSDPSRV
    alg.exe                     1316 ALG
    avgcsrvx.exe                1668 N/A
    svchost.exe                 3428 HTTPFilter
    wmiprvse.exe                 772 N/A
    taskmgr.exe                 2508 N/A
    dragon.exe                  3004 N/A
    dragon.exe                  3416 N/A
    dragon.exe                  2024 N/A
    dragon.exe                  3944 N/A
    cmd.exe                     4052 N/A
    tasklist.exe                2980 N/A
    wmiprvse.exe                1452 N/A
    2014-03-27T19:52:11+00:00
    So now we don't really know how much RAM was being used after the machine booted because the shot was taken after Dragon was started... the idea behind running the commands and taking the screen shot after a reboot and before opening any programs  was to know what was being started and what RAM used solely by the startup processes.
    John
