Having trouble: Adding RAM with a USB memory stick to a Windows XP desktop that has 4GB installed
2014-03-22T21:13:11+00:00
Short form:
I want to use a 16GB USB flash drive memory stick as RAM, but seem to be unable to use more than 4GB, due to the system requirements, limiting what I can enter for values (size). WHY??
More detail:
The computer is a desktop machine, having a 3.0GHz dual-core processor, and 4GB RAM installed. I believe the hard drive is a 1T.
I have a 16GB USB flash drive memory stick, which I want to use to boost the RAM, for games, and such. There are 3 spare USB ports on the back of the tower. The flash drive is new, with NO files saved on it.
When I go into the Settings; Computer; Virtual Memory, the computer is not allowing me to enter a value greater than 4096 in the field for "Initial Size" or "Maximum Size", for the Page File of the USB drive.
The Value for C: that I see is: "2096-4092".
Main Question:
Is there some reason why I cannot allocate more of the memory stick for RAM?
(Does the flash drive need to be formatted?)
Does the values for C: need to be changed?
I presently have "4090" entered for values "Initial Size" and "Maximum Size" in the custom size, for the Page File of the USB Drive.
Screenshot provided of Virtual Memory Settings screen: (you can see the L: drive settings (selected), and the C: settings, also)
http://prntscr.com/336ocy
Question 2:
Also, is the "4G" of RAM which I have added to the machine, being added to the 4GB which is already installed in the tower?
Question 3:
Does the OS wait until the system RAM is full before using the External RAM?
Thanks!
edit to add:
What I learned from Microsoft article "How To Set Performance Options in Windows XP":
http://support.microsoft.com/kb/308417/en-us
To manually change the size of virtual memory, follow these steps:
...Note After you change the size of the paging file, you may be prompted to restart Windows. If you are prompted to restart, the changes will not take effect until Windows is restarted.
  • To have Windows select the best paging file size, click System managed size. The recommended minimum size is the same as 1.5 times the RAM on your computer, and 3 times that figure for the maximum size. For example, if you have 256 MB of RAM, the minimum size is 384 MB, and the maximum size is 1152 MB.
  • For best performance, do not set the initial size to less than the minimum recommended size under Total paging file size for all drives. The recommended size is the same as 1.5 times the RAM on your computer. It is good practice to leave the paging file at its recommended size as performance can decrease if a paging file is too large. However, you may increase its size if you frequently use programs that use lots of memory, such as graphics programs or games.
What I am unclear of here, is that, as you can see in the screenshot, the Recommended Size under Total paging file size for all drives is 3019M.
And, the values set for the Paging File in C are 2046-4092.
The tower has been rebuilt, and has 4GB RAM.
I do not know if these numbers reflect an original build of 2GB, whereas 3GB (3019M) would be 1.5 times the installed RAM, perhaps.
Under Virtual Memory, I see the following (shown in screenshot):
Drive C
Space available: 725194MB
*Custom Size
Initial Size: 2046
Maximum Size: 4092
Total paging file size for all Drives
Minimum allowed: 2MB
Recommended: 3019MB
Currently Allocated: 2046MB
Given that the system has 4GB RAM installed, shouldn't the minimum be 1.5 times that value, or ~6000MB ? (not 3019MB), and the maximum be 3 times ? (not 4092)
"The recommended minimum size is the same as 1.5 times the RAM on your computer, and 3 times that figure for the maximum size."
Can I change the values on the Virtual memory for C drive to 2046-12000MB ?
That is what I am reading from the article. But, it also says to not have a paging file on the same drive as the programs.
"Try to avoid having a paging file on the same drive as the system files, usually drive C."
Also, why am I unable to enter values greater than 4096 for the USB drive in Initial or Maximum?
I also have a question as to whether I should select "Programs" or "System Cache" in memory usage, due to the cache requirements of games, running very few programs.
edit 2:
I learned that the usb drive needs to be formatted in NTFS, so I did that, which isn't easy, as that isn't a selection in the choices in the Format menu, without going into Device Mgr.
A friend was telling me about formatting a usb drive ex-fat for a newer application, and got me thinking. I had selected FAT32 for this one, and had noticed no change in the page file graph usage after adding the drive, like it wasn't getting any data placed on it.
So, as custom settings for this USB drive, I have the Initial value at 4091 and the Maximum at 4096, with "System Cache" selected as opposed to "Programs" in Memory usage, in Performance settings.
Any answers or tips would be appreciated.
Am I on the right track?
    2014-03-27T00:06:30+00:00
    Contents of the startlist text file:
    These Windows services are started:
       Agere Modem Call Progress Audio
       Application Layer Gateway Service
       Automatic Updates
       AVG WatchDog
       AVGIDSAgent
       COM+ Event System
       COMODO Dragon Update Service
       Computer Browser
       Cryptographic Services
       DCOM Server Process Launcher
       DHCP Client
       DNS Client
       Event Log
       Fast User Switching Compatibility
       HID Input Service
       HTTP SSL
       IPSEC Services
       Java Quick Starter
       MBAMScheduler
       Network Connections
       Network Location Awareness (NLA)
       Plug and Play
       Pml Driver HPZ12
       Print Spooler
       Protected Storage
       RealNetworks Downloader Resolver Service
       Remote Access Connection Manager
       Remote Procedure Call (RPC)
       SeaPort
       Secondary Logon
       Security Accounts Manager
       Security Center
       Server
       Shell Hardware Detection
       SSDP Discovery Service
       System Event Notification
       System Restore Service
       TeamViewer 8
       Telephony
       Terminal Services
       Themes
       TimesUpKidz
       vToolbarUpdater18.0.5
       Windows Audio
       Windows Driver Foundation - User-mode Driver Framework
       Windows Firewall/Internet Connection Sharing (ICS)
       Windows Image Acquisition (WIA)
       Windows Live ID Sign-in Assistant
       Windows Management Instrumentation
       Wireless Zero Configuration
       Workstation
    The command completed successfully.
    2014-03-27T00:26:36+00:00
    Services which I disabled yesterday via services.msc:
    Distributed Link Tracking Client
    Error Reporting Service
    Help & Support
    Indexing Service
    Messenger
    Net Logon
    NetMeeting Remote Desktop Sharing
    Network Provisioning Service
    QoS RSVP
    Remote Desktop Help Session Manager
    Smart Card
    Task Scheduler
    TCP/IP NetBIOS Helper Properties
    Util Mega Browse
    Web Client
    Windows Time
    edit to add:
    I have downloaded and installed the tasklist file, and pasted it into the SYStem 32 folder.
    "tasklist | sort /R /+58 >c:\Memuse.txt  will sort the processes by biggest memory users and pipe the results to the indicated .txt file.  Omit the redirector to see the results at the command console (tasklist | sort /R /+58)"
    When you sat to 'omit the redirector', are you saying to type the 3 commands again, only without the redirectors, and now that I have installed the tasklist file, the mem users will be sorted?
    2014-03-27T01:34:08+00:00
    I get it now. The last line was also a Command Prompt, with and without the redirecter.
       Automatic Updates
       AVG WatchDog
       AVGIDSAgent
       COM+ Event System
       Computer Browser
       DHCP Client
       DNS Client
       Event Log
       HID Input Service
       HTTP SSL
       IPSEC Services
       Java Quick Starter
       MBAMScheduler
       Network Connections
       Plug and Play
       Pml Driver HPZ12
       Print Spooler
       Protected Storage
       SeaPort
       Secondary Logon
       Security Center
       Server
       TeamViewer 8
       Telephony
       Terminal Services
       Themes
       TimesUpKidz
       Windows Audio
       Workstation
    Image Name                   PID Services
    System Idle Process            0 N/A
    System                         4 N/A
    smss.exe                     632 N/A
    avgrsx.exe                   672 N/A
    avgcsrvx.exe                 712 N/A
    csrss.exe                    916 N/A
    winlogon.exe                 940 N/A
    services.exe                 984 Eventlog, PlugPlay
    lsass.exe                    996 PolicyAgent, ProtectedStorage, SamSs
    svchost.exe                 1164 DcomLaunch, TermService
    svchost.exe                 1228 RpcSs
    svchost.exe                 1324 AudioSrv, Browser, CryptSvc, Dhcp,
                                     EventSystem, FastUserSwitchingCompatibility,
                                     HidServ, lanmanserver, lanmanworkstation,
                                     Netman, Nla, RasMan, seclogon, SENS,
                                     SharedAccess, ShellHWDetection, srservice,
                                     TapiSrv, Themes, winmgmt, wscsvc, wuauserv,
                                     WZCSVC
    svchost.exe                 1364 WudfSvc
    svchost.exe                 1448 Dnscache
    spoolsv.exe                 1560 Spooler
    agrsmsvc.exe                1784 AgereModemAudio
    avgidsagent.exe             1796 AVGIDSAgent
    avgwdsvc.exe                1828 avgwd
    dragon_updater.exe          1876 DragonUpdater
    jqs.exe                     2016 JavaQuickStarterService
    mbamscheduler.exe           2044 MBAMScheduler
    GoogleUpdate.exe             236 N/A
    HPZipm12.exe                 504 Pml Driver HPZ12
    avgnsx.exe                   516 N/A
    avgemcx.exe                  584 N/A
    rndlresolversvc.exe          880 RealNetworks Downloader Resolver Service
    SeaPort.exe                  960 SeaPort
    svchost.exe                 2084 stisvc
    TeamViewer_Service.exe      2152 TeamViewer8
    ToolbarUpdater.exe          2260 vToolbarUpdater18.0.5
    WLIDSVC.EXE                 2356 wlidsvc
    loggingserver.exe           2364 N/A
    TimesUpKidzServer.exe       2428 TimesUpKidz
    WLIDSVCM.EXE                2776 N/A
    alg.exe                     2984 ALG
    avgcsrvx.exe                3252 N/A
    explorer.exe                3800 N/A
    igfxtray.exe                3900 N/A
    hkcmd.exe                   3924 N/A
    igfxpers.exe                3952 N/A
    svchost.exe                 3988 SSDPSRV
    igfxsrvc.exe                4016 N/A
    vprot.exe                    648 N/A
    RTHDCPL.EXE                 1128 N/A
    avgui.exe                   1316 N/A
    svchost.exe                 1348 HTTPFilter
    jusched.exe                 1764 N/A
    FacebookUpdate.exe          2096 N/A
    ctfmon.exe                  2832 N/A
    Lightshot.exe                988 N/A
    dragon.exe                   476 N/A
    dragon.exe                  1988 N/A
    dragon.exe                  1856 N/A
    dragon.exe                  2628 N/A
    dragon.exe                  1624 N/A
    dragon.exe                  3556 N/A
    dragon.exe                  3700 N/A
    dragon.exe                  1776 N/A
    dragon.exe                  3896 N/A
    dragon.exe                  4092 N/A
    cmd.exe                     3812 N/A
    tasklist.exe                2752 N/A
    wmiprvse.exe                3056 N/A
    2014-03-27T01:34:40+00:00
    The > redirect operator sends the output of the command to a file or printer, if the file already exists it will be overwritten, the double redirect >> will append the output of the command if the file already exists, if the file doesn't exist it will create it.
    Do run the tasklist /svc >C:\startlist.txt command and post the results here so we can see the  running processes on machine.
    The last command was for your information only, you can run the tasklist | sort /R /+58 at the command prompt and see the results at the console window.
    John
    2014-03-27T02:12:00+00:00
    I was able to see the results in the console window, and also copied both lists.
    When I run tasklist /svc >C:\startlist.txt nothing happens.
