There was an error when attempting to connect to the Windows Live Calendar service
2013-05-01T01:36:54+00:00
"There was an error when attempting to connect to the Windows Live Calendar service. If the error persists, check to see if there's an upgrade of Windows Live Mail available or contact a service representative."
I am running W7 and WLM has been working fine up until this afternoon when it decided that I was not online, would not let me go online and would not allow me to reliably send or receive my email. I repaired the WLM installation and restarted my computer but this problem persists. an occasional Connecting has been hit and miss and I received the error message above. I never use the Calendar service so I don't understand what is going on. I rely on reliable email and help would be deeply appreciated. Thank you in advance.
Windows for home | Other | Email and communications
2013-05-01T08:58:30+00:00
... it decided that I was not online, would not let me go online ...
It sounds as if something (a third-party browser, for example) has set the GlobalUserOffline registry value to True. With Windows Live Mail closed, launch Internet Explorer and press Alt-F to open the File menu. If Work offline is selected, click it to deselect it. If it's not selected, select it, wait a moment then deselect it.
Now try to launch Windows Live Mail again. Do you get the same error?
EDIT 1 May 2016
In 2013, this was a common error caused by interference from third-party browsers. This interference has been dealt with on recent versions of Windows (7, 8.1 and 10) so the cause of the error is now likely to be a different one. This answer no longer applies, except perhaps on XP and Vista.
Please see this wiki article for a likely explanation of the error currently being experienced by many users:**Error when attempting to connect to the Windows Live Calendar service**
50 additional answers
    2016-04-28T19:57:20+00:00
    Version 2011  Build 15.4.3555.0308
    I am using version 2012!! Perhaps you should consider updating?
    2016-04-28T20:53:14+00:00
    I just updated to 2012 as you suggested.  It didn't help, DARN!
    2016-05-14T01:01:41+00:00
    not the solution
    2016-06-13T20:12:31+00:00
    This is the message I'm getting. Running Windows 10. I am still online and receiving emails.
