I do have the error daily when I comes out of sleep,, even though this is a new PC, Asus Extreme 3 mobo, PowerGlo 5450 GPU, AMD 6350 CPU, 8gb ram, and after upgrading to 8.1 (64 bit, which may make a difference) and uninstalling and reinstalling the latest AMD display driver, and updating the BIOS to the most recent firmware (8/2013) and running scans for viruses.
If you Google "The system firmware has changed the processor's memory type range registers' you find this is a common issue, but I have yet to find a fix I can confirm.
It also used to come out of sleep by itself but that was until I changed the adapter settings (Control Panel\Network and Internet\Network Connections>properties) not to wake up the PC.
I am not sure if this issue has any detrimental effect on boot up (which takes almost a full minute despite the 3.9ghz, 6 core CPU), or resume, and I cannot use Fast Boot because sometimes, but very rarely, the PC will not resume come out of sleep, but a blank screen with fans running, thus requiring a hard restart.
But it is not a big deal, and I have lots to be thankful for, including this PC. If I ever get a solution though, I will post it.
More details:
**-** <Event xmlns="**http://schemas.microsoft.com/win/2004/08/events/event**">
**-** <System>
**** <Provider Name="Microsoft-Windows-Kernel-Power" Guid="{331C3B3A-2005-44C2-AC5E-77220C37D6B4}" />
**** <EventID>137</EventID>
**** <Version>0</Version>
**** <Level>2</Level>
**** <Task>0</Task>
**** <Opcode>0</Opcode>
**** <Keywords>0x8000000000000004</Keywords>
**** <TimeCreated SystemTime="2013-10-24T16:47:28.144275300Z" />
**** <EventRecordID>4720</EventRecordID>
**** <Correlation />
**** <Execution ProcessID="4" ThreadID="7144" />
**** <Channel>System</Channel>
**** <Computer>PC_4_GOD</Computer>
**** <Security />
**** </System>
**-** <EventData>
**** <Data Name="SleepState">4</Data>
**** </EventData>
**** </Event>
