touchscreen stopped working in samsung ativ 500t, maybe after upgrade to pro
2013-01-27T19:17:08+00:00
I have Samsung ativ pc 500t. IT was shipped with Windows 8 and worked perfectly. Last Thursday I upgrade it to Windows 8 Pro and few hours later on Friday it lost touchscreen capability partially. I can use stylus (s pen), but I cannot use fingers. I attached the device info about trh device I suspect should be related to touchscreen by fingers.
All help would be very appriciated. Thanks, David
Devices List
Created by using DevManView
Device Name Manufacturer Service Device Type Code Device Type Name Device Instance ID Location Capabilities Config Flags Disabled Connected Device Registry Time 1 Device Registry Time 2 Drive Letter Driver Description Driver Version .inf File .inf Section Driver Date Driver Registry Time
HID-compliant device (Standard system devices) HIDClass HID\ATML1000&Col01\4&2101be6d&0&0000 0x000000e0 0x00000000 No No 13. 12. 2012 0:33:49 13. 12. 2012 0:33:49 HID-compliant device 6.2.9200.16461 input.inf HID_Raw_Inst.NT 21. 6. 2006 26. 1. 2013 11:34:33
2013-03-26T06:33:42+00:00
Hello there,
I use Samsung ATIV XE700T and Win 8.
It happens to me too after I uninstall the current Wacom driver (7.1.0-8 -Win8) and then install (7.0.9-5 -Win 7).
So why I installed Win 7 driver if I have Win 8 as OS?
Well, my stylus pen wasn't working on Adobe Flash Professional (was working anywhere else perfectly). So after I installed the Win 7 driver it started to work on Flash perfect too.
I am not sure if you already discovered but if you plug in any usb device, finger touch works for a while then again stops working. And the same thing happens when you plug out the device you plugged in.
As I am an illustrator, using pen on Flash for drawing is a priority for me so I didn't re-install the driver for Win8 again.
Solution:
1. Go to "Control Panel -> Programs" and uninstall the current driver (ISD Tablet).
2. Restart your computer.
3. Download and install this driver.
4. Restart your computer.
You are done!
Regards,
Kemal KAYA
2013-05-06T10:33:59+00:00
Hi, it was definitely hardware problem in my case. Returned back, they simply changed everything and now is working like a breeze without any issues. BTW I did what you suggest. Touchscreen was not working even during boot, I did reinstall Windows this way at least 5 times.
All the best,
David
46 additional answers
    2013-05-08T00:37:54+00:00
    Just got new ATIV 500T device. Touchscreen was working for almost an hour but than stopped working and never came back. I2C HID device always have exclamation sign and nothing helps to make in on-line. I tried installing Amtel I2C drivers, resetting Windows, etc.
    Is there anyone who solved the issue without going to service center?
    Is it working with stylus pen?
    2013-05-08T04:47:26+00:00
    Yep, S-Pen works.
    2013-05-08T05:16:28+00:00
    I still believe it is hardware related. Battery life also greatly increased after the repair. Samsung should address this.
