Weather gadget not working- Cannot connect to service
2013-01-14T14:07:43+00:00
original title: Weather gadget not working !!
I have Windows 7 Ultimate 64 - bit and my weather gadget is not working, it is displaying a message "Cannot connect to service .
I have also tried by turning off firewall and antivirus but it still don't works for me .
2013-01-15T09:19:57+00:00
Update:
Microsoft has DISABLED the weather and currency gadgets via a recent Security Update, due to concerns over the vulnerability associated with these gadgets running on your computer. You can read more about it here: http://support.microsoft.com/kb/2719662 . Adjusting your computer's settings and all these other "suggestions" people are making, will NOT work. The function has been REMOVED from the operating system. It has also been removed from the Windows 8 operating system. There are "theorists" that either agree that there is a security issue within the gadgets or Microsoft just does not want to support gadgets (usually third party software) and thus, has disabled them in Windows 7 and eliminated them in Windows 8.
Thanks to DaveNYC for the Info. Spread the word because many people are facing this problem just like you.
2015-05-29T15:03:04+00:00
To all having this problem, the following worked for me:
After eading all kind of solutions, I changed the config.xml file according instructions and then I got connected but only to my own location (in my case Amsterdam). Tried everything else, no results, till I only give the exact zip code for the place I like to see the weather in the search menu and guess it worked, then I did the same on my computer in Greece (via teamviewer) and there it worked as well.
I hope it will help you as good as it did for me.
Ron
632 additional answers
    2013-03-07T22:05:54+00:00
    Hi All,
    I have copied the files from a backup from a time when they worked, and yet they still don't work.
    They stopped working on 2 March when a "critical update" was installed - do you think this might have affected it?
    Cheers,
  2. Deleted
    2013-03-07T22:10:28+00:00
    I have the weather gadget broken on TWO PCs.  No working copies for me.  Perhaps your "working" is due to a cache?  Go to %LOCALAPPDATA%\Microsoft\Windows Sidebar\Cache and then reboot.  That will clear all the cache and perhaps "break it."
    I have contacted Microsoft today (March 7, 2013) and the tech support told me:
    I see, well i think the best thing we can do as of the moment is to wait. Our software engineers are currently working  on a resolution for this.
    As of the moment unfortunately there hasn't been an update of a fix. Correct, this is a know issues and glitch with our system.
    http://answers.microsoft.com/en-us/windows/forum/windows_7-winapps/weather-gadget-and-currency-gadget-not-work-in/e6f207aa-aeec-4d70-a694-fa763debadc6
