Weather gadget not working- Cannot connect to service
2013-01-14T14:07:43+00:00
original title: Weather gadget not working !!
I have Windows 7 Ultimate 64 - bit and my weather gadget is not working, it is displaying a message "Cannot connect to service .
I have also tried by turning off firewall and antivirus but it still don't works for me .
2013-01-15T09:19:57+00:00
Update:
Microsoft has DISABLED the weather and currency gadgets via a recent Security Update, due to concerns over the vulnerability associated with these gadgets running on your computer. You can read more about it here: http://support.microsoft.com/kb/2719662 . Adjusting your computer's settings and all these other "suggestions" people are making, will NOT work. The function has been REMOVED from the operating system. It has also been removed from the Windows 8 operating system. There are "theorists" that either agree that there is a security issue within the gadgets or Microsoft just does not want to support gadgets (usually third party software) and thus, has disabled them in Windows 7 and eliminated them in Windows 8.
Thanks to DaveNYC for the Info. Spread the word because many people are facing this problem just like you.
2015-05-29T15:03:04+00:00
To all having this problem, the following worked for me:
After eading all kind of solutions, I changed the config.xml file according instructions and then I got connected but only to my own location (in my case Amsterdam). Tried everything else, no results, till I only give the exact zip code for the place I like to see the weather in the search menu and guess it worked, then I did the same on my computer in Greece (via teamviewer) and there it worked as well.
I hope it will help you as good as it did for me.
Ron
632 additional answers
    2015-02-28T08:37:03+00:00
    Still running OK with this MSN Weather Gadget upgrade 2.0
    (If you're able to download it)
    2015-03-01T01:54:46+00:00
    I don't see any "Weather Upgrade" link on the MSN webpage (www.msn.com).  Would you please explain how this can help with my weather gadgets not being able to connect to the weather service?
    Thanks.
    FEJ
    2015-03-01T02:00:45+00:00
    What exactly works like a charm?  This is not your fault, but the way Microsoft handles all the replies.  They list the replies alone without the original suggested action.  I received your reply above but not what the reply was to. If you reply to this, I would appreciate your stating what you did to make it work.
    FEJ
