Weather gadget not working- Cannot connect to service
2013-01-14T14:07:43+00:00
original title: Weather gadget not working !!
I have Windows 7 Ultimate 64 - bit and my weather gadget is not working, it is displaying a message "Cannot connect to service .
I have also tried by turning off firewall and antivirus but it still don't works for me .
2013-01-15T09:19:57+00:00
Update:
Microsoft has DISABLED the weather and currency gadgets via a recent Security Update, due to concerns over the vulnerability associated with these gadgets running on your computer. You can read more about it here: http://support.microsoft.com/kb/2719662 . Adjusting your computer's settings and all these other "suggestions" people are making, will NOT work. The function has been REMOVED from the operating system. It has also been removed from the Windows 8 operating system. There are "theorists" that either agree that there is a security issue within the gadgets or Microsoft just does not want to support gadgets (usually third party software) and thus, has disabled them in Windows 7 and eliminated them in Windows 8.
Thanks to DaveNYC for the Info. Spread the word because many people are facing this problem just like you.
2015-05-29T15:03:04+00:00
To all having this problem, the following worked for me:
After eading all kind of solutions, I changed the config.xml file according instructions and then I got connected but only to my own location (in my case Amsterdam). Tried everything else, no results, till I only give the exact zip code for the place I like to see the weather in the search menu and guess it worked, then I did the same on my computer in Greece (via teamviewer) and there it worked as well.
I hope it will help you as good as it did for me.
Ron
632 additional answers
    2015-02-24T16:12:50+00:00
    hi there
    understand your frustration. :( this is a pain.
    Yep... now see the same against the 2nd link....
    however, as the download button still works for me on the original URL, I have saved the file to my hotmail cloud open-share:
    Go to
    https://onedrive.live.com/?cid=A29DF203567F213D&id=A29DF203567F213D!283
    (and hope it works!)
    That opens an open-share folder. I have renamed the file to put it to the top;
    click "a MSN Weather 2_0.gadget" and on my computer it immediately opens As a Run file or select to Save (depending on how you've set your Dowloads default)
    Hope this works! (y) ^_^
    finally!
    2015-02-24T16:54:27+00:00
    here bud you leading me a wild goose chase with this thing or what? this is what I get once I log in
    This item might not exist or is no longer available
    this item may have been deleted, expired or you might not have permission to view it. Contact the owner of this item for more information.
    2015-02-24T18:54:13+00:00
    I did the save XML file without saving bit above but it didn't work. I then decided to download another weather gadget:
    http://gallery-live.com/sidebar-gadgets/BBC%20Weather%20Gadget%20v1.1
    Installed it and presto! The original MS weather gadget started working again. I can now disable to new one and keep it as a backup in case the MS one stops working again.
