Weather gadget not working- Cannot connect to service
2013-01-14T14:07:43+00:00
original title: Weather gadget not working !!
I have Windows 7 Ultimate 64 - bit and my weather gadget is not working, it is displaying a message "Cannot connect to service .
I have also tried by turning off firewall and antivirus but it still don't works for me .
2013-01-15T09:19:57+00:00
Update:
Microsoft has DISABLED the weather and currency gadgets via a recent Security Update, due to concerns over the vulnerability associated with these gadgets running on your computer. You can read more about it here: http://support.microsoft.com/kb/2719662 . Adjusting your computer's settings and all these other "suggestions" people are making, will NOT work. The function has been REMOVED from the operating system. It has also been removed from the Windows 8 operating system. There are "theorists" that either agree that there is a security issue within the gadgets or Microsoft just does not want to support gadgets (usually third party software) and thus, has disabled them in Windows 7 and eliminated them in Windows 8.
Thanks to DaveNYC for the Info. Spread the word because many people are facing this problem just like you.
2015-05-29T15:03:04+00:00
To all having this problem, the following worked for me:
After eading all kind of solutions, I changed the config.xml file according instructions and then I got connected but only to my own location (in my case Amsterdam). Tried everything else, no results, till I only give the exact zip code for the place I like to see the weather in the search menu and guess it worked, then I did the same on my computer in Greece (via teamviewer) and there it worked as well.
I hope it will help you as good as it did for me.
Ron
632 additional answers
    2015-02-13T04:15:01+00:00
    I found a quick fix on another website for the issue. I have confirmed it worked on my computer.
    Go to "C:\Users\USERNAME\AppData\Local\Microsoft\Windows Live\Services\Cache", open "Config.xml" (RMB -> Edit) and save it (File -> Save) without doing any changes. After 10-20 seconds restart the gadget!
    It didn't work for me  :(
    2015-02-13T06:47:18+00:00
    It looks like MS sent an update to disable all the gadgets that look at the net for their data. Their fear is about some gadgets have been malicious, or modified by rogue malicious software to be a vehicle for security compromise.
    I found a work around that worked for me.  It deals with going to  http://win7gadgets.com/  and downloading other types of weather, and other net access type gadgets.
    I tried one called Weather Monitor   http://win7gadgets.com/weather/weather_monitor_24.html   It has been working for me on four computers that I tried it on. This one takes the weather from AccuWeather from what I read. It has a fairly extensive setup capability.  There is an Information icon that shows a flyout displaying daily weather.
    Another weather gadget that I found works well is AccuWeather Mini Forcast   http://win7gadgets.com/weather/accu_weather_mini.html
    As for more of these explore the site. They have a lot of terrific gadgets of many types. You would have to try them to know if they will work or not. Some are blocked because they use the same data path or ports that are blocked by MS for this.
    2015-02-13T09:44:16+00:00
    The reason MS disabled its Weather Gadget is due to that it might be used to infect your computer.
    Then WHAT do you think those Other Gadget CAN be used for, those that doesn't even come from MS themself ...
    BEWARE of all other Gadgets than those that came from Microsoft!
