Weather gadget not working- Cannot connect to service
2013-01-14T14:07:43+00:00
original title: Weather gadget not working !!
I have Windows 7 Ultimate 64 - bit and my weather gadget is not working, it is displaying a message "Cannot connect to service .
I have also tried by turning off firewall and antivirus but it still don't works for me .
2013-01-15T09:19:57+00:00
Update:
Microsoft has DISABLED the weather and currency gadgets via a recent Security Update, due to concerns over the vulnerability associated with these gadgets running on your computer. You can read more about it here: http://support.microsoft.com/kb/2719662 . Adjusting your computer's settings and all these other "suggestions" people are making, will NOT work. The function has been REMOVED from the operating system. It has also been removed from the Windows 8 operating system. There are "theorists" that either agree that there is a security issue within the gadgets or Microsoft just does not want to support gadgets (usually third party software) and thus, has disabled them in Windows 7 and eliminated them in Windows 8.
Thanks to DaveNYC for the Info. Spread the word because many people are facing this problem just like you.
2015-05-29T15:03:04+00:00
To all having this problem, the following worked for me:
After eading all kind of solutions, I changed the config.xml file according instructions and then I got connected but only to my own location (in my case Amsterdam). Tried everything else, no results, till I only give the exact zip code for the place I like to see the weather in the search menu and guess it worked, then I did the same on my computer in Greece (via teamviewer) and there it worked as well.
I hope it will help you as good as it did for me.
Ron
632 additional answers
    2015-02-11T07:02:00+00:00
    pal, in my case, which I think is not just mine, the path does not even exist, so I can't do any changes to those lines you mentioned above, no win live products installed, don't think I'm gonna need them..
    If you don't even use this Gadget - then why do you bother to write here at all ...
    don't get me wrong, I was talking about the gadget ok?
    C:\Users\your name\AppData\Local\Microsoft*Windows Live*\Services\Cache
    this path shan't exist if you have no Windows Live products installed!!that's why I said I couldn't rewrite those lines in what you said config.xml
    instead I did modify the .js file in the gadget a bit to get it work so you don't have to find a known good win7 to copy cache files from or do any changes to the cache file
    2015-02-11T09:47:58+00:00
    Thx...
    2015-02-11T14:45:21+00:00
    Worked for me as well - thanks
