Weather gadget not working- Cannot connect to service
2013-01-14T14:07:43+00:00
original title: Weather gadget not working !!
I have Windows 7 Ultimate 64 - bit and my weather gadget is not working, it is displaying a message "Cannot connect to service .
I have also tried by turning off firewall and antivirus but it still don't works for me .
2013-01-15T09:19:57+00:00
Update:
Microsoft has DISABLED the weather and currency gadgets via a recent Security Update, due to concerns over the vulnerability associated with these gadgets running on your computer. You can read more about it here: http://support.microsoft.com/kb/2719662 . Adjusting your computer's settings and all these other "suggestions" people are making, will NOT work. The function has been REMOVED from the operating system. It has also been removed from the Windows 8 operating system. There are "theorists" that either agree that there is a security issue within the gadgets or Microsoft just does not want to support gadgets (usually third party software) and thus, has disabled them in Windows 7 and eliminated them in Windows 8.
Thanks to DaveNYC for the Info. Spread the word because many people are facing this problem just like you.
2015-05-29T15:03:04+00:00
To all having this problem, the following worked for me:
After eading all kind of solutions, I changed the config.xml file according instructions and then I got connected but only to my own location (in my case Amsterdam). Tried everything else, no results, till I only give the exact zip code for the place I like to see the weather in the search menu and guess it worked, then I did the same on my computer in Greece (via teamviewer) and there it worked as well.
I hope it will help you as good as it did for me.
Ron
632 additional answers
    2015-02-10T03:09:22+00:00
    Hi Karan Deep,
    Thank you for posting your query in Microsoft Community.
    From your issue description I understand that, Gadgets does not work.
    Let’s follow these methods and check if it fixes the issue.
    Method 1: This may be caused due to the corruption of the gadget. You may try restoring the gadget.
    a.    Right click on the gadget.
    b.    Go to Properties.
    c.    At the bottom of the window you will find a tab to Restore Gadgets Installed with Windows, click on it.
    d.    This will restore it back to the default setting. This should get your weather Gadget working.
    Method 2: Try changing the system locale to English (United States). Sometimes, simply changing system language locale alone is enough to solve the Weather gadget issue.
    To change system locale,
    a.    Open Region and Language by clicking the Start button, clicking Control Panel, clicking Clock, Language, and Region, and then clicking Region and Language.
    b.    Click the Formats tab, and then, in the Format list, select the locale to use for the display of the date, time, currency, and measurements.
    Also, refer to the suggestions from this link.
    Windows 7 gadgets may not work or be displayed correctly
    http://support.microsoft.com/kb/2515657
    Hope this will be helpful. If you still have further queries, please reply us and we will be happy to help you.
    Part b.  "Go to Properties"  Does not exist!
    2015-02-10T04:24:42+00:00
    But when one uninstalls Internet Explorer 11, how does one get IE10 back as the browser?
    Will IE automatically revert to IE10 if one uninstalls IE11?
    Thank you.
    2015-02-10T07:16:55+00:00
    Gee,that's funny! lmao!!! When you right click the gadget,all you get is a list all of which states NOTHING about properties!!! When you click on options all you do is go back to enter your location. :/
    Yet another fool who obviously knows nothing about what to do or how to actually fix this BS!!!
