Weather gadget not working- Cannot connect to service
2013-01-14T14:07:43+00:00
original title: Weather gadget not working !!
I have Windows 7 Ultimate 64 - bit and my weather gadget is not working, it is displaying a message "Cannot connect to service .
I have also tried by turning off firewall and antivirus but it still don't works for me .
2013-01-15T09:19:57+00:00
Update:
Microsoft has DISABLED the weather and currency gadgets via a recent Security Update, due to concerns over the vulnerability associated with these gadgets running on your computer. You can read more about it here: http://support.microsoft.com/kb/2719662 . Adjusting your computer's settings and all these other "suggestions" people are making, will NOT work. The function has been REMOVED from the operating system. It has also been removed from the Windows 8 operating system. There are "theorists" that either agree that there is a security issue within the gadgets or Microsoft just does not want to support gadgets (usually third party software) and thus, has disabled them in Windows 7 and eliminated them in Windows 8.
Thanks to DaveNYC for the Info. Spread the word because many people are facing this problem just like you.
2015-05-29T15:03:04+00:00
To all having this problem, the following worked for me:
After eading all kind of solutions, I changed the config.xml file according instructions and then I got connected but only to my own location (in my case Amsterdam). Tried everything else, no results, till I only give the exact zip code for the place I like to see the weather in the search menu and guess it worked, then I did the same on my computer in Greece (via teamviewer) and there it worked as well.
I hope it will help you as good as it did for me.
Ron
632 additional answers
    2013-03-06T22:25:03+00:00
    Gold Star for you, sir.
    This is kind of a brute force approach and requires a known good machine, but we all have plenty, right?
    2013-03-06T23:34:07+00:00
    Astonishing! Your solution worked for me as well.  Thank you very much.
    Since March 1st, tried "100" other tricks published on the Internet and nothing else worked.
    I gave up and tried to install other weather gadgets, widgets, apps and weather software and  I was not happy with them: too much memory usage or to big displays or they dragin  a lot of extra gimmicky toolbars. I know about security exposure, but nothing happened via that gadget last 8 yrs and Symantec hopefully can catch intruder.
    Same as your father, I (70 years old women, previously also IT specialist) use the weather gadget a lot. Live in Calgary were temperature can drop or rise a lot: Chinook winds have been observed to raise winter temperature often from below -20°C (-4°F) to as high as 10-20°C (50-68°F) for a few hours or days, then temperatures plummet to their base levels.  My outdoor thermometer is behind a window covered in ice and I have to go out with my dogs a lot. That old weather gadget is a winner for me.
    Thank you again.
    2013-03-07T00:33:32+00:00
    Hi Sting251
    Very interesting to read your reply :) I'm desperate to try this for myself but just one thing, where do I get the particular files/folders from which you've listed 1-3 please? I can't do it until I find them....Aaaghh!!
    Thanks.
    Unfortunately you need to have a second computer with windows 7...a computer whose weather gadget is working correctly. Either that or you could ask a friend or family member who has a windows 7 machine to copy the two files as well as the weather gadget cache directory to a flash drive or even burn them to a CD for you. Then you simply overwrite the files and the directory on the effected machine.
