Weather gadget not working- Cannot connect to service
2013-01-14T14:07:43+00:00
original title: Weather gadget not working !!
I have Windows 7 Ultimate 64 - bit and my weather gadget is not working, it is displaying a message "Cannot connect to service .
I have also tried by turning off firewall and antivirus but it still don't works for me .
2013-01-15T09:19:57+00:00
Update:
Microsoft has DISABLED the weather and currency gadgets via a recent Security Update, due to concerns over the vulnerability associated with these gadgets running on your computer. You can read more about it here: http://support.microsoft.com/kb/2719662 . Adjusting your computer's settings and all these other "suggestions" people are making, will NOT work. The function has been REMOVED from the operating system. It has also been removed from the Windows 8 operating system. There are "theorists" that either agree that there is a security issue within the gadgets or Microsoft just does not want to support gadgets (usually third party software) and thus, has disabled them in Windows 7 and eliminated them in Windows 8.
Thanks to DaveNYC for the Info. Spread the word because many people are facing this problem just like you.
2015-05-29T15:03:04+00:00
To all having this problem, the following worked for me:
After eading all kind of solutions, I changed the config.xml file according instructions and then I got connected but only to my own location (in my case Amsterdam). Tried everything else, no results, till I only give the exact zip code for the place I like to see the weather in the search menu and guess it worked, then I did the same on my computer in Greece (via teamviewer) and there it worked as well.
I hope it will help you as good as it did for me.
Ron
632 additional answers
    2015-02-03T20:53:20+00:00
    Just installed copies from my work computer (win 7 Professional- x64) per the instructions in to my home computer (win 7 ultimate -x64) rebooted and everything is back working......
      Yes you must have another working copy to get the files from but it works the first time.
    One suggestion just for safety sake. Close all copies of any gadgets before doing any pasting of the replacement files AND re-name the files/folders with a "_OLD"  added to the existing name. Helps if you have to undo the changes.
    2015-02-04T17:20:31+00:00
    Two things worked for me.
    I copied this file to a non working machine from a working machine:
    %localappdata%\affected user\local\microsoft\windows\windows live\services\cache\config.xml
    On a non working machine, just the act of editing the file and saving it with no changes did the trick.
    2015-02-04T22:35:06+00:00
    SADLY (and maybe like others)
    I *LOVE* the weather gadget and would gladly risk having it back
    BUT i am not a technie and your advice means nothing to me (it presumes you have a certain level of computer systems literacy)
    As a step by step guide it seriously fails the novice user, i dont recognise any points of reference
    and to suggest, copy a working gagdet = the whole point is, it has STOPPED working.....
    This is all highly frustrating
    WonderWabbit Stephen
