Weather gadget not working- Cannot connect to service
2013-01-14T14:07:43+00:00
original title: Weather gadget not working !!
I have Windows 7 Ultimate 64 - bit and my weather gadget is not working, it is displaying a message "Cannot connect to service .
I have also tried by turning off firewall and antivirus but it still don't works for me .
2013-01-15T09:19:57+00:00
Update:
Microsoft has DISABLED the weather and currency gadgets via a recent Security Update, due to concerns over the vulnerability associated with these gadgets running on your computer. You can read more about it here: http://support.microsoft.com/kb/2719662 . Adjusting your computer's settings and all these other "suggestions" people are making, will NOT work. The function has been REMOVED from the operating system. It has also been removed from the Windows 8 operating system. There are "theorists" that either agree that there is a security issue within the gadgets or Microsoft just does not want to support gadgets (usually third party software) and thus, has disabled them in Windows 7 and eliminated them in Windows 8.
Thanks to DaveNYC for the Info. Spread the word because many people are facing this problem just like you.
2015-05-29T15:03:04+00:00
To all having this problem, the following worked for me:
After eading all kind of solutions, I changed the config.xml file according instructions and then I got connected but only to my own location (in my case Amsterdam). Tried everything else, no results, till I only give the exact zip code for the place I like to see the weather in the search menu and guess it worked, then I did the same on my computer in Greece (via teamviewer) and there it worked as well.
I hope it will help you as good as it did for me.
Ron
632 additional answers
    2017-04-11T19:06:00+00:00
    this is what worked for me
    Until yours there hadn't been a reply to this thread in six months.
    If someone is still dealing with this, the question is why are you still using Windows 7?  Hopefully not just because you want a weather gadget.  I know people will say Win 7 is so much better, blah, blah.  Sure, feel free to keep using an outdated, and essentially not supported (mainstream support ended over two years ago) OS.
    2017-04-11T19:34:12+00:00
    Microsoft stopped support for gadgets a few years ago because of conflicts they caused with other programs. That said, Windows 7 still has a lot of life left in it. Vista's support just ended today.
    The Difference Between End of Mainstream Support and End of Extended Support
    http://www.networkworld.com/article/2453561/microsoft-subnet/the-difference-between-end-of-mainstream-support-and-end-of-extended-support.html
    Windows End Of Life
    http://windows.microsoft.com/en-us/windows/lifecycle
  3. Deleted
