Weather gadget not working- Cannot connect to service
2013-01-14T14:07:43+00:00
original title: Weather gadget not working !!
I have Windows 7 Ultimate 64 - bit and my weather gadget is not working, it is displaying a message "Cannot connect to service .
I have also tried by turning off firewall and antivirus but it still don't works for me .
2013-01-15T09:19:57+00:00
Update:
Microsoft has DISABLED the weather and currency gadgets via a recent Security Update, due to concerns over the vulnerability associated with these gadgets running on your computer. You can read more about it here: http://support.microsoft.com/kb/2719662 . Adjusting your computer's settings and all these other "suggestions" people are making, will NOT work. The function has been REMOVED from the operating system. It has also been removed from the Windows 8 operating system. There are "theorists" that either agree that there is a security issue within the gadgets or Microsoft just does not want to support gadgets (usually third party software) and thus, has disabled them in Windows 7 and eliminated them in Windows 8.
Thanks to DaveNYC for the Info. Spread the word because many people are facing this problem just like you.
2015-05-29T15:03:04+00:00
To all having this problem, the following worked for me:
After eading all kind of solutions, I changed the config.xml file according instructions and then I got connected but only to my own location (in my case Amsterdam). Tried everything else, no results, till I only give the exact zip code for the place I like to see the weather in the search menu and guess it worked, then I did the same on my computer in Greece (via teamviewer) and there it worked as well.
I hope it will help you as good as it did for me.
Ron
632 additional answers
    2016-08-21T20:26:07+00:00
    lacal weather report is not functioning.how it can be solved
    2016-08-22T14:01:21+00:00
    This is a very old fix ... it only works for a short time
    2016-08-22T14:22:38+00:00
    This issue is moot for me and I assume many others.  All my computers are now Windows 10.  I miss my clock, weather and CPU gadgets. I'm sure there are third party options but I am a little leery.  I am open to suggestions.
