Weather gadget not working- Cannot connect to service
2013-01-14T14:07:43+00:00
original title: Weather gadget not working !!
I have Windows 7 Ultimate 64 - bit and my weather gadget is not working, it is displaying a message "Cannot connect to service .
I have also tried by turning off firewall and antivirus but it still don't works for me .
2013-01-15T09:19:57+00:00
Update:
Microsoft has DISABLED the weather and currency gadgets via a recent Security Update, due to concerns over the vulnerability associated with these gadgets running on your computer. You can read more about it here: http://support.microsoft.com/kb/2719662 . Adjusting your computer's settings and all these other "suggestions" people are making, will NOT work. The function has been REMOVED from the operating system. It has also been removed from the Windows 8 operating system. There are "theorists" that either agree that there is a security issue within the gadgets or Microsoft just does not want to support gadgets (usually third party software) and thus, has disabled them in Windows 7 and eliminated them in Windows 8.
Thanks to DaveNYC for the Info. Spread the word because many people are facing this problem just like you.
2015-05-29T15:03:04+00:00
To all having this problem, the following worked for me:
After eading all kind of solutions, I changed the config.xml file according instructions and then I got connected but only to my own location (in my case Amsterdam). Tried everything else, no results, till I only give the exact zip code for the place I like to see the weather in the search menu and guess it worked, then I did the same on my computer in Greece (via teamviewer) and there it worked as well.
I hope it will help you as good as it did for me.
Ron
632 additional answers
  1. Deleted
    2013-03-07T22:40:31+00:00
    I tried copying and pasting those files and directories from files of an Acronis backup from several weeks ago when my Weather was working ... but it won't allow a copy or paste to the folders.  Says 'currently in use' .. and I know sidebar.exe was not running.
    Won't let me overwrite the files.
    What now??
    Try terminating "sidebar.exe" in task manager.  Also, I would highly recommend to wait for Microsoft.
    @MicrosoftHelps on Twitter said:  @tyw7 Thank you for the update. This is a known issue and our team is working on it. Please check back to your post for updates. ^KE
    https://twitter.com/MicrosoftHelps/status/309790216649052160
    Edit: I have created a new thread, which I will keep up to date with responses from Microsoft.  In an attempt to "consolidate" the threads, please post there.
    2013-03-07T22:50:08+00:00
    I finally gave up on the Microsoft weather gadget and installed this one instead  -  http://www.wunderground.com/download/vista.asp
    If you only want 1 city you can download and install.   If you want multiple cities like I did, install from the web page.  Enjoy!
