restore printer icon on toolbar
2013-01-18T19:01:53+00:00
I cannot print from from printer.  How do I restore printer icon?
Thank you.
Don Varnau 19,930 Reputation points Volunteer Moderator
2015-06-25T19:28:12+00:00
I think what the two people are referring to- the printer icon in the command bar is gone in IE.  I deleted my too along with all other icons under the command bar because I wanted to make room for the favorite bar.
Try this...
Right-click on the Command Bar> Customize> Add or remove commands> select Print then click on Add.
Don
82 additional answers
    2017-04-06T22:10:30+00:00
    Thank you.
    cannot find printer icon
  2. Don Varnau 19,930 Reputation points Volunteer Moderator
    2017-04-06T23:27:11+00:00
    See if my post, just above your post, on this page helps.
    Please ask any additional questions you have about adding a Printer icon.
    Don
    2017-07-25T15:45:30+00:00
    insert print on message bar
  4. Deleted
