restore printer icon on toolbar
2013-01-18T19:01:53+00:00
I cannot print from from printer.  How do I restore printer icon?
Thank you.
Don Varnau 19,930 Reputation points Volunteer Moderator
2015-06-25T19:28:12+00:00
I think what the two people are referring to- the printer icon in the command bar is gone in IE.  I deleted my too along with all other icons under the command bar because I wanted to make room for the favorite bar.
Try this...
Right-click on the Command Bar> Customize> Add or remove commands> select Print then click on Add.
Don
82 additional answers
  1. Don Varnau 19,930 Reputation points Volunteer Moderator
    2015-09-24T12:35:59+00:00
    Yes windows 10. My printer will print but not what I highlight for it to print. I cannot isolate a paragraph I get the whole page.
    If this is happening with the Edge browser, try Internet Explorer.
    More information below.
    If happening with other programs, go to the printer manufacturers website to see if there are updated drivers available for Windows 10.
    Access IE11 in Windows 10:
    If you are using Edge and want to use IE11, click on the 3 dots at the upper right corner and select Open with Internet Explorer.
    How to put an IE icon on the Desktop
    http://answers.microsoft.com/en-us/ie/forum/ie11-iewindows\_10/ie11-in-windows-10-how-do-i-put-an-ie-icon-on-the/d9be6ac2-8bc0-41e5-acd5-287ac1171fdd
    Other options:
    Type Internet Explorer into the search box at the bottom of the screen. Find Internet Explorer in the list of results, right-click it to either  Pin to taskbar or Pin to Start.
    To make IE the default browser:
    Start button> Settings> System> left side menu, select Default Apps then select Set Defaults by App. Select Internet Explorer.
    Don
    2015-09-24T13:42:08+00:00
    Cannot thank you enough! Printer restored like windows 8 have all my tool bars back! IE 11 was the trick. I feel like I am home again. Thanks, Sarah
  3. Don Varnau 19,930 Reputation points Volunteer Moderator
    2015-09-24T22:34:06+00:00
    Glad that IE11 resolved the printing issue. Thanks for the feedback.
    Don
    2016-01-08T18:47:38+00:00
    Since uploading to Wdos 10, my printer icon is not on taskbar. The printer is on my apps but I cannot print
