restore printer icon on toolbar
2013-01-18T19:01:53+00:00
I cannot print from from printer.  How do I restore printer icon?
Thank you.
Don Varnau 19,930 Reputation points Volunteer Moderator
2015-06-25T19:28:12+00:00
I think what the two people are referring to- the printer icon in the command bar is gone in IE.  I deleted my too along with all other icons under the command bar because I wanted to make room for the favorite bar.
Try this...
Right-click on the Command Bar> Customize> Add or remove commands> select Print then click on Add.
Don
82 additional answers
    2015-09-23T02:22:55+00:00
    I need to use printer
  2. Deleted
  3. Don Varnau 19,930 Reputation points Volunteer Moderator
    2015-09-23T10:03:43+00:00
    1. Are you using Windows 10?
    2. Are you unable to print from Internet Explorer, Edge or another program?
    3. What exact problem are you having?
    4. If there is an error message, what's the message?
    Don
    2015-09-24T11:52:38+00:00
    Yes windows 10. My printer will print but not what I highlight for it to print. I cannot isolate a paragraph I get the whole page. I have no "selection" button. My only choices are 1 page or several pages.  However I have a tablet with windows 8 & I have the neat box that gives me selection choice & prints my highlighted areas. All this from the same HP printer. Windows 10 has a very different print box. I hope this can be fixed as printing in this manner is worthless to me. Thanks for any help, Sarah
