restore printer icon on toolbar
2013-01-18T19:01:53+00:00
I cannot print from from printer.  How do I restore printer icon?
Thank you.
Don Varnau 19,930 Reputation points Volunteer Moderator
2015-06-25T19:28:12+00:00
I think what the two people are referring to- the printer icon in the command bar is gone in IE.  I deleted my too along with all other icons under the command bar because I wanted to make room for the favorite bar.
Try this...
Right-click on the Command Bar> Customize> Add or remove commands> select Print then click on Add.
Don
82 additional answers
    2015-06-25T19:01:50+00:00
    I think what the two people are referring to- the printer icon in the command bar is gone in IE.  I deleted my too along with all other icons under the command bar because I wanted to make room for the favorite bar.  I now want the icon back but don't know how.  I do know that one can print under File, Print, etc.
    2015-08-10T19:36:49+00:00
    My grandaughter is in homeschool and needs the printer to do schoolwork,i see no printer icon,please help
  3. Don Varnau 19,930 Reputation points Volunteer Moderator
    2015-08-10T19:53:53+00:00
    My granddaughter is in homeschool and needs the printer to do schoolwork ,i see no printer icon
    Try this...
    You can also print from nearly any program with the key combo [Ctrl + p] or File> Print.
    If unsuccessful with those suggestions... Which versions of Windows and Internet Explorer are you running?
    Don
    2015-08-13T18:56:36+00:00
    Working with new W10, and printer disappeared.. The tip worked beautifully...tnx dlw
