restore printer icon on toolbar
2013-01-18T19:01:53+00:00
I cannot print from from printer.  How do I restore printer icon?
Thank you.
Don Varnau 19,930 Reputation points Volunteer Moderator
2015-06-25T19:28:12+00:00
I think what the two people are referring to- the printer icon in the command bar is gone in IE.  I deleted my too along with all other icons under the command bar because I wanted to make room for the favorite bar.
Try this...
Right-click on the Command Bar> Customize> Add or remove commands> select Print then click on Add.
Don
82 additional answers
    2019-09-12T03:19:22+00:00
    there is no command bar on my think or swim platform
  2. Don Varnau 19,930 Reputation points Volunteer Moderator
    2019-09-12T07:43:34+00:00
    1. What browser are you running on which version of Windows?
    2. Or... You can also print from nearly any program with the shortcut [Ctrl + p] or from File > Print.
    Don
