restore printer icon on toolbar
2013-01-18T19:01:53+00:00
I cannot print from from printer.  How do I restore printer icon?
Thank you.
Don Varnau 19,930 Reputation points Volunteer Moderator
2015-06-25T19:28:12+00:00
I think what the two people are referring to- the printer icon in the command bar is gone in IE.  I deleted my too along with all other icons under the command bar because I wanted to make room for the favorite bar.
Try this...
Right-click on the Command Bar> Customize> Add or remove commands> select Print then click on Add.
Don
82 additional answers
    2019-06-25T16:12:15+00:00
    Where do I find the command bar?
  2. Don Varnau 19,930 Reputation points Volunteer Moderator
    2019-06-25T18:16:28+00:00
    1. Which version of Windows are you running?
    2. Which version of Internet Explorer or are you using another browser like Edge or Chrome or Firefox?
    3. If running Windows 10, are you using the Edge browser or Internet Explorer?
    Don
    2019-06-25T20:31:46+00:00
    Windows 10
    Internet Explorer
  4. Don Varnau 19,930 Reputation points Volunteer Moderator
    2019-06-25T22:13:02+00:00
    Patricia A Batka  wrote:
    Windows 10
    Internet Explorer
    Hold down Alt then hit v then hit t and check Menu Bar and Command Bar.
    Then, right-click on the Command Bar> Customize> Add or remove commands> select Print then click on Add.
    You can also print from nearly any program with the shortcut [Ctrl + p] or from File > Print.
    Don
