restore printer icon on toolbar
2013-01-18T19:01:53+00:00
I cannot print from from printer.  How do I restore printer icon?
Thank you.
Don Varnau 19,930 Reputation points Volunteer Moderator
2015-06-25T19:28:12+00:00
I think what the two people are referring to- the printer icon in the command bar is gone in IE.  I deleted my too along with all other icons under the command bar because I wanted to make room for the favorite bar.
Try this...
Right-click on the Command Bar> Customize> Add or remove commands> select Print then click on Add.
Don
82 additional answers
  1. Don Varnau 19,930 Reputation points Volunteer Moderator
    2018-12-09T23:03:26+00:00
    SadieMorris wrote:
    I do not have the same Brother  printer. the Brother MFC-J885DW PRINTER has been deleted from my computer. I now have a Brother HL-L2395DWwhich I cannot seem to get picked up on the screen either.  Imagine that!!! However, I can print with it.
    You can't simply add a Print icon to the Desktop.
    On which program/app do you want a Print icon?
    Note: You can print from almost any program from the key shortcut
    [Ctrl + p] or from File > Print.
    Don
  2. Deleted
    2019-04-27T16:19:45+00:00
    How can I find the icon descriptions on my printer I lost my printer manual
  4. LemP 74,970 Reputation points Volunteer Moderator
    2019-04-27T16:37:38+00:00
    You should be able to download the User Guide for your unidentified printer at the website of the printer's manufacturer.
